While creating a new Board with the existing project, can see "epics" but cannot see and issues related to "epsic"... tried to find any points related to that in setting... but nothing special found.
How I can change it ? What is the existing rule for issues (existing project) to be view in the new board ?
Many thanks,
First, go check the filter that the board is based on - that might be excluding stuff you need. It's in board -> configure and on the far left-hand tab once you're into the config of the board.
To stop Answers reminders, mark the best answer you got correct - there's a tick to the left of each answer.
