Issues in Groovy Script.
mehala n
July 17, 2013
The script failed : javax.script.ScriptException: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.crowd.embedded.ofbiz.OfBizUser.getPropertySet() is applicable for argument types: () values: []
Possible solutions: getProperties()
2013-07-16 07:46:12,495 http-6443-2 ERROR wb391456 466x18x1 6s8xt0 10.185.5.137,10.185.160.15 /secure/QuickCreateIssue.jspa [onresolve.jira.groovy.GroovyFunctionPlugin] Error executing post-function
Script is
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.jira.security.roles.ProjectRoleActors
import com.atlassian.jira.project.Project
import com.atlassian.jira.issue.customfields.CustomFieldType
import com.atlassian.jira.user.util.UserManager
import org.apache.log4j.Category
log = Category.getInstance("com.onresolve.jira.groovy.PostFunction")
MutableIssue myIssue = issue
ComponentManager componentManager = ComponentManager.getInstance()
CustomFieldManager customFieldManager = componentManager.getCustomFieldManager()
ProjectRoleManager projectRoleManager = (ProjectRoleManager) ComponentManager.getComponentInstanceOfType(ProjectRoleManager.class)
UserManager userManager = (UserManager) ComponentManager.getComponentInstanceOfType(UserManager.class)
Project myProject = myIssue.getProjectObject()
def techLead = myIssue.getProjectObject().getLead()
String projectKey = myIssue.getProjectObject().getKey()
String compKey = ""
String appCriticality = ""
def componentLeads = myIssue.getComponentObjects()
def businessLead
myIssue.getComponentObjects().each{ c ->
if (c.getLead()) {
techLead = userManager.getUser(c.getLead())
if ( c.getDescription() != null && c.getDescription().indexOf('{') != null) {
compKey = c.getDescription()
compKey = compKey.substring(compKey.indexOf('{') + 1,compKey.indexOf('}') )
compKey = compKey?:projectKey
//Get the first business lead
ProjectRole projectRole = projectRoleManager.getProjectRole('Business Lead')
Collection businessLeads = new ArrayList()
ProjectRoleActors projectRoleActors = projectRoleManager.getProjectRoleActors(projectRole , myProject)
projectRoleActors.getRoleActors().each {
businessLeads.add(it.getUsers())
61
62 try {
63 businessLead = businessLeads[0]
64 } catch(Throwable e){}
65 try {
66 if ( userManager.getUser("appowner").getPropertySet().getString("jira.meta." + compKey) != null ) {
67 businessLead = userManager.getUser(userManager.getUser("appowner").getPropertySet().getString("jira.meta." + compKey ))
68 }
69 } catch(Throwable e) {}
70
71 CustomField cfTechLead = customFieldManager.getCustomFieldObjectByName( "Technical Lead" )
72 CustomField cfBusLead = customFieldManager.getCustomFieldObjectByName( "Business Lead" )
73 CustomField cfAppCriticality = customFieldManager.getCustomFieldObjectByName( "Criticality of the App" )
74 CustomField cfIssueSubType = customFieldManager.getCustomFieldObjectByName( "Issue sub-type" )
75
76 myIssue.setCustomFieldValue(cfTechLead, techLead)
77 myIssue.setCustomFieldValue(cfBusLead, businessLead)
78 if( myIssue.issueType.name == "xxx")
79 {
80 appCriticality = userManager.getUser("appcriticality").getPropertySet().getString("jira.meta." + compKey )
81 try {
82 myIssue.setCustomFieldValue(cfAppCriticality , appCriticality.substring( 0,appCriticality.indexOf(':') ))
83 }catch(Throwable e){}
84 }
85 else {
86 myIssue.setCustomFieldValue(cfIssueSubType , myIssue.issueType.name )
87 }
JamieA
July 18, 2013
Try userManager.getUserByKey("appcriticality")
JamieA
July 18, 2013
Nothing works out because the API has changed, so your code needs to change. For the full story see https://developer.atlassian.com/display/JIRADEV/Renamable+Users+in+JIRA+6.0
mehala n
July 23, 2013
you mean to say ,the plugin has nothing to do with this kind of exception?
I really dont get any errors in atlassia-jira.log file.
Also I routed down and found that ClassClassException is from OSWorkFlowManager.java
public void validateIssue(String remoteUserName, Map fields) throws WorkflowException {
77 try {
78 // Determine the workflow for the issue to use
79 Issue issue = (Issue) fields.get("issue");
80 final Workflow workflow = makeWorkflow(remoteUserName); 81 final ActionDescriptor actionDescriptor = getEditActionDescriptor(issue);
82 if (actionDescriptor != null) {
83 long wfId = issue.getLong("workflowId").longValue();
84 workflow.doAction(wfId, actionDescriptor.getId(), fields);
85 }
86 // return ManagerFactory.getIssueManager().getIssueByWorkflow(new Long(wfId));
87 } catch (InvalidRoleException e) {
88 log.error("Error occurred while creating issue.", e);
89 throw new WorkflowException(e);
90 } catch (InvalidInputException e) {
91 log.error("Error occurred while creating issue.", e);
92 throw new WorkflowException(e);
93 } catch (InvalidEntryStateException e) {
94 log.error("Error occurred while creating issue.", e);
95 throw new WorkflowException(e);
96 } catch (com.opensymphony.workflow.WorkflowException e) {
97 log.error("Error occured while creating issue.", e);
98 throw new WorkflowException(e);
99 } catch (ClassCastException e) {
100 String message = "Error occurred while creating issue. This could be due to a plugin being incompatible with this version of JIRA. For more details please consult the logs, and see: "
101 + http://confluence.atlassian.com/x/3McB;
Got stuck up and not sure how to proceed.. Please help
mehala n
July 22, 2013
I couldnt see any errors/exceptions in log. May be is it bcoz of the jira-misc-workflow-extensions-3.0.0.jar ? The latest I see as 3.0.1 in Market Place?My JIRA version is 5.2.10.
I am working with my team to add this plugin since it requires admin rights.
JamieA
July 23, 2013
Don't see why that plugin has anything to do with it.
mehala n
July 22, 2013
Using userPropertyManager.getPropertySet works and there is no exceptions now.
String usera= userPropertyManager.getPropertySet( userManager .getUser("appcriticality")).getString("jira.meta." + compKey )
But Getting Error: "Error creating issue. Error occurred while creating issue. This could be due to a plugin being incompatible with this version of JIRA. For more details please consult the logs, and see http://confluence.atlassian.com/x/3McB"
Note :using latest groovy plugins fom market place(groovy-all-1.8.5.jar,groovyrunner-2.1.3.jar)
No exceptions were seen in log
Kindly help
JamieA
July 22, 2013
There will be something in the log.
mehala n
July 18, 2013
import com.atlassian.jira.user.UserPropertyManager
import com.atlassian.crowd.embedded.api.User
UserPropertyManager userManager=ComponentAccessor.getComponent(UserPropertyManager.class)
String compKey = ""
appCriticality = ComponentAccessor.getUserPropertyManager().getPropertySet(userManager.getUser("appcriticality")).getString.("jira.meta." + compKey )
I tried what ever I know..just removed all other logics and trying to get thru this line alone.. Nothing works out.
JamieA
July 17, 2013
Come on, play the game, at least reference the other issue where I told you to use com.atlassian.jira.user.UserPropertyManager#getPropertySet.
You can get UserPropertyManager from ComponentAccessor.
