I have a Scrum project, and within a current sprint, when I move an issue within my workflow to "Resolved," it disappears.
I recently changed the workflow on this project (and all projects within this board) and then immediately changed the workflow back to the original one and now I seem to be having this problem.
The reason I originally changed the workflow was that I was trying to set a post-action to my "Resolved" status in the Workflow to actually "Close" the issue. I had realized all my issues said "unresolved" in the "Resolution" field within the issues and weren't actually showing when I used the side navigation within the Issues section to see "Done Issues" or "Resolved Recently." But even though my original workflow did not have this post function, my sprint board was still allowing me to view my issues in the last "Resolved" column. Now it is not...
Kindly check your board filter. Maybe you filter out all issues with resolution set.
