Issues not displayed for release
MOHAMOD Shah March 1, 2022
I have a created a "release" in JIRA which I have referenced in my issues using the "Affects Version/s" field.
I was expecting to see metrics about issues referenced by my release but unfortunately all release counters (issues in progress, todo etc) are at zero.
Does anyone has a hint regarding my problem ?
Fabio Racobaldo _Catworkx_
Hi @MOHAMOD Shah ,
welcome to the Atlassian community!
Release is based on field "Fix Version/s". Affect Version/s is usually used for bug tracking, btw, what you will release should be in fix version.
Hope this helps,
Fabio
Thank you very much for your quick reply @Fabio Racobaldo _Catworkx_
Your suggestion solved my problem.
Kind regards.
Sh@h
you're welcome @MOHAMOD Shah !
