Issues with LDAP and Group in JIRA
Michelle Larson
September 18, 2015
I am trying to use LDAP with JIRA I am getting the following when I test:
Test get user's memberships : Failed
org.springframework.ldap.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100238, problem 2001 (NO_OBJECT), data 0, best match of: 'OU=JIRA,OU=OTS Services,DC=WINDOM,DC=OUTREACH,DC=PSU,DC=EDU' ]; nested exception is javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100238, problem 2001 (NO_OBJECT), data 0, best match of: 'OU=JIRA,OU=OTS Services,DC=WINDOM,DC=OUTREACH,DC=PSU,DC=EDU' ]; remaining name 'OU=JIRA Users,OU=JIRA,OU=OTS Services,DC=WINDOM,DC=OUTREACH,DC=PSU,DC=EDU'
For more information regarding LDAP error codes see Troubleshooting LDAP Error Codes.
Test get group members : Failed
  Test user can authenticate : Failed
See attached screen shot
Arthur Gonçalves
September 18, 2015
Hi Michelle,
Please check this Knowledge Base article and try the resolution listed there. I hope it helps! smile
-- Arthur Gonçalves
