It is possible to auto-sync automatically a JIRA directory or LDAP directory ?
jmsantam February 17, 2013
I use a LDAP directory and a JIRA server directory to manage users from LDAP and JIRA both in JIRA and confluence .
Is there a way to automatice the Syncronization of users ?
with a script or configuration change in a file ?
I have sometimes to make it by hand :)
thanks a lot
David Skreiner
October 15, 2014
Even if directory synchronization is set to run every 60 minutes, it may stop working for no obvious reason.
(I just found out that my JIRA didn't synch LDAP users for three weeks, despite being set to 60 minute intervals.)
Faisal
February 17, 2013
Hi Jose,
May I know which directory type you added to your JIRA instance? If you are using either the LDAP connector or Microsoft Active Directory, then supposedly JIRA will periodically synchronize the user directory automatically.
By default, the directory synchronization will run every 60 minutes. But you can configure this by editing the LDAP directory, expand the Advanced Settings section and look for the Synchronization Interval (minutes) configuration.
I hope that this will help!
Cheers.
jmsantam February 18, 2013
Yes I got it, I didnt see it xd.. :)
Faisal
February 18, 2013
Great! Since this is the case Jose, can you kindly mark this question as answered?
Thanks!
Shinjani Gaur February 12, 2015
I am using Jira 6.3.1 and I don't see the option in Advanced Settings to synchronize. Is this option available some where else now?
Deleted user March 5, 2018
Jira 7.3 - I am also not able to see if that is a direct checkbox in Advance Settings. But I see that   the value is being set like as folllows when I click on
- Additional configuration
Overview directory configuration
"directory.cache.synchronise.interval": "3600".
But somehow suddenly the Sync is not completing automatically, which was not the case earlier.
How can we troubleshoot what can be the Problem? The same LDAP Settings (Server) which is being used in TEST instance is synchronising it automatically in every 1 Hour.
Any help would be appreciated.
Deleted user March 6, 2018
We had to reboot the Jira Server once and it worked for us. Now LDAP is synchronising automatically in every 1 Hour.
