It's possible to use automatic SSO between JIRA et Confluence
Geoffrey Gobert April 3, 2014
It's possible when I am connected to JIRA to connect to confluence automatically?
Application Links is configured between JIRA and Confluence.
I use the Remote Jira Directory in Confluence.
Thanks a lot for your reply,
Geoffrey
Nic Brough -Adaptavist-
April 3, 2014
Not directly, you need some SSO software. The easiest one for these two is Crowd - you'll be able to import directly from Jira, tell Jira and Confluence to use Crowd instead of the Jira internal database and then tick the SSO flag.
Setor de TI - VN November 21, 2014
Hello, @Nic Brough [Adaptavist], could you tell me if Crowd requires some sort of interaction with the local network user configurations?
November 21, 2014
I don't know what you mean by "local network user"?
Setor de TI - VN November 23, 2014
Hi, I mean domain users. I was told that to use Crowd I'm supposed to integrated it with the AD configurations, which is something I wouldn't want to. I've tried to find an answer to this doubt, but I couldn't.
November 23, 2014
It'll work fine with domain users as they're pulled from AD.
Geoffrey Gobert November 23, 2014
However, there is a problem with the use of the "Domain Users" group.
