×Hi all,
One feature that I really thought JIRA would support would be a copy or clone function for project creation.
we go through projects pretty swiftly at my company and I find it quite tedious having to fill out the same parameters over and over for each project; workflow scheme, issue scheme, components, notification scheme etc etc. There are clone plug-in's available, but they're old and now unsupported. Really I believe this kind of functionality should be native to JIRA.
I was wondering if anyone out there has found the same problem or even a solution?
Adam
Copy project from the script runner plugin works with jira 5. That works for me... but probably agree with you that it should be a core function.
A feature request has been created for this, please vote for it: https://jira.atlassian.com/browse/AOD-6722
