JIRA 5.2.10 head banner show issue
Junjie Mars August 25, 2013
I'd installed JIRA 5.2.10 successed, and it just works. But the head banner show has issues,
just like the follow screenshot. I browse the jira page via Chrome 8.0.1500.71 (Developer Build 28.0.1500.71-0ubuntu1.12.04.1) Ubuntu 12.04, another I test via Fixfox the issue is the same.
vkharisma
August 26, 2013
Thanks for your clarification, sorry that I missed that. I would suggest to rebuild the Tomcat's work directory as per following steps:
  • Shutdown JIRA
  • Remove the content of $JIRA-INSTALL/work directory
  • Restart JIRA
Hope this helps.
Junjie Mars August 26, 2013
Hi, Vicky,
I'd tried another version 5.2.11, the issue is same. I'll try shutdown/remove/restart.
Thank u for ur reply.
It's helpness.
Junjie Mars September 11, 2013
Yep, I'd rebuild tomcat, it's ok. Thanks.
Theinvisibleman
August 26, 2013
Hi Junjie,
Hmm, in that case, could you try enabling Plugin Safe Mode? Please note that this would disable all third-party plugins, so you might want to schedule some downtime before trying that out.
Also, if possible, to follow-up on my previously posted suggestions, would it be possible to comment on the post instead of posting new answers? I'm worried that doing so would make this thread rather confusing/long
Hi, Joe,
I'd tried Firefox v23.0, the issue is same.
Theinvisibleman
August 26, 2013
Hi Junjie,
Have you tried using a different browser? If possible, please try testing this with other browsers as well, and see if the problem persists :)
Hi, all,
How to descript the issue that I'd met, the Header has not toggled and splited 2 areas.
JIRA 5.2.10 is just works, but the Header does not toggled, it is like wrong javascript.
Hi, Vicky,
Do u see the upper banner and lower banner should be toggled?
vkharisma
August 25, 2013
Hi Junjie,
Can you translate what the error is about?
