JIRA 6.1.5 DOA - SQL Exception looking for KEY column in customfield table
Neal Culiner
April 21, 2016
I just updated to JIRA 6.15, HUGE MISTAKE once again jumping on Atlassian upgrades as they are POORLY TESTED and Q/A is a total failure!  Beyond that, the error in my log file is:
2016-04-21 19:42:23,320 JiraTaskExectionThread-2 WARN neal007 1181x651x1 1m5o77x 100.7.52.33 /secure/admin/IndexReIndex.jspa [c.a.jira.index.AccumulatingResultBuilder] com.atlassian.cache.CacheException: com.atlassian.cache.CacheException: com.atlassian.cache.CacheException: com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericDataSourceException: SQL Exception while executing the following:SELECT KEY, CUSTOMFIELDTYPEKEY, CUSTOMFIELDSEARCHERKEY, cfname, DESCRIPTION, defaultvalue, FIELDTYPE, PROJECT, ISSUETYPE FROM dbo.customfield WHERE ID=? (Incorrect syntax near the keyword 'KEY'.)
I looked in the SQL Database schema for the table "customfield" and there is no column "KEY" defined.  Was one supposed to be added or is this a bad SQL statement in JIRA 6.1.5 that kills it???
I'm dead in the water, again!
Neal Culiner
April 21, 2016
Neal Culiner
April 21, 2016
Haha - gotta love seeing Atlassian uses JIRA 7.1.2.  Hmmmm
Nic Brough -Adaptavist-
April 22, 2016
Ahh, nicely spotted!  I wonder why I'm not running into it!
Neal Culiner
April 22, 2016
This is a perfect example of Atlassian's lack of Q/A in testing new releases. Had anyone actually run an upgrade from 6.1.4 to 6.1.5 using MS-SQL or MySQL it would have failed.  They rely too much on automated testing and distribution which is why I personally, as a software developer and software company owner despise when people rely solely on automated Q/A.  This is the second time in recent past they have broken an upgrade against MS-SQL at least.
April 22, 2016
I've only done it with MySQL.  I'll need to see why I had it work!  I don't run MS-SQL generally.
Neal Culiner
April 21, 2016
The SELECT statement should be:
SELECT [KEY], CUSTOMFIELDTYPEKEY, CUSTOMFIELDSEARCHERKEY, cfname, DESCRIPTION, defaultvalue, FIELDTYPE, PROJECT, ISSUETYPE FROM dbo.customfield WHERE ID=?
Neal Culiner
April 21, 2016
Which database are you using?  I'm using MS SQL Server 2014
April 21, 2016
Sadly, I was intrigued and tried the upgrade.  It worked for me with a plain 6.1.4 and a spot of random data going to 6.1.5.  So I wonder what's different about your install?
Neal Culiner
April 21, 2016
I'm still working with support but the first problem is their ALTER statement to add a new column "KEY" to customfields is incorrect. It should be:
INCORRECT:
ALTER TABLE dbo.customfield ADD KEY NVARCHAR(255)
CORRECT:
ALTER TABLE dbo.customfield ADD [KEY] NVARCHAR(255)
April 21, 2016
From what version did you upgrade?  And what documentation did you follow?
Neal Culiner
April 21, 2016
6.1.4, standard upgrade process.
