JIRA 6.1.9 : moving fields on screen does not work
Rafal Sojka
I finally upgraded my old JIRA 6.0.1 to next major release : 6.1.9 and to my amazement moving fields on screens does not work. When I hover over a field, no the dotted part of the field does not appear.
In 6.0.1 it works fine.
Do you know how to fix it  or which next version solves this problem ?
Thank you
Rafal Sojka
Yes, right. But because of compatibility issues and plugins it was safer to upgrade to 6.1.9 first.
Unfortunately, cleaning cache hasn't helped.
Thx
Volodymyr Krupach
November 22, 2016
6.1.9 is still very old JIRA smile.
Did you try to clean the browser cache?
Rafal Sojka
No, I upgraded my JIRA to next major release 6.1.9.
Screenshot from 6.1.9 :
and screenshot from old version (6.0.1) :
Volodymyr Krupach
November 22, 2016
Probably you mean 7.1.9. Screenshot will be helpful.
