Hi All,
We are using rest/api2/issue/issuenumber/comment. The body which is returned is not in a readable format and when we display it in a a label using asp.net it shows some special characters. could you please help us understand how to get it in a better format or make it readable
some examples
1. tickets._+\n * *User Experience
2. ed format.* *{color:#00875a}- DONE{color}*\n * *
I think the problem here is not that Jira is returning stuff in an unreadable format, it's that your asp.net code does not know how to read it.
The examples you've given here look like rendered text - it contains control characters that are telling you how the text is formatted (bold, coloured, etc)
You will need to code your asp.net application so that it can parse and render the markup into the format you want (or ignore it and strip the markup out)
More details are available in the above link. Still unable to proceed
There is not a lot more we can tell you, other than you will need to code your application to understand the markup it is fetching from Jira.
Hi @Nitesh Kala ,
Welcome to the community .
Can you please check the field configuration schema. (which is mapped to the issue type on which you have commented). Please check renderer which is associated to the comment field in the field config schema. If it is default text renderer , please change it to wiki style render and check.
Our administrator does not allow us to change field configuration. is it possible to render the ouput recieved from the api and display it in a readable format?
