Hi, I just encountered an issues from JIRA agile, it creates duplicate broken issues type which can not be deleted after creating a scrum project.
Environment:
CentOS 7.1, MySQL 5.6.26, bash lcoale is set to: LC_ALL="zh_CN.UTF-8"
JIRA:v6.4.11, JIRA:6.7.11
Repeat Steps:
Results:
please refer this screenshot
Delete Issue Type: {0} | |
Confirm that you want to delete this issue type, and specify what is to be done with the issues currently attached to it. Note: This issue type will be removed from all field configuration, issue type screen and workflow schemes. There are currently matching issues, that must be changed to another issue type. |
this issue is reproduced in a brand new installation of JIRA, so that no issue had been created in the system, no issue had been assigned to any issue type.
and errors can be seen in JIRA log file:
2015-09-25 15:56:44,753 http-bio-8080-exec-22 ERROR admin 956x4275x1 1unn2o6 10.26.30.29 /secure/admin/DeleteIssueType!default.jspa [webwork.util.ValueStack] query="matchingIssues/empty" {[id="matchingIssues" type="8" values=""]} {[id="empty" type="8" values=""]}
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor921.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMet
Expected Results:
I expected that JIra Agile will create issue type in English irrespective of users/system's locale, so that users will provide translation under different language (from that translate link)
and
Please tell me how can i delete this ignoring broken issue type?
thanks
Can you try to do a re-index and see if that fixes your problem.
Also run integrity checker to fix any database integrity issues.
I would do these first before looking for other causes.
Pilar
I have provide more details from the support ticket https://support.atlassian.com/servicedesk/customer/portal/22/JSP-249726 but i don't think he really get my point about this behavior.
No, If jira default language(from system setting )is English, it won't create new issue type, resolution when creating scrum project. JIRA Agile only creates them with S-Chinese names if default language from jira system setting is set to Chinese.
Hi there, does the behaviour persists if you are using English language in your instance?
