×Hi Team,
I want to create a custom application (python/ any) with UI like a template with details like name of project, key etc., so the users who want to have a JIRA project can enter the values and submit. Once submitted it will be reviewed by JIRA Admin and approves.
Once it is approved it automatically creates a JIRA project for and emails the url to the requester.
So I would like if any one can give your inputs or suggestions to start.
thanks
Hi @Sid
I suggest you use the rest api for creating projects
see
https://developer.atlassian.com/cloud/jira/platform/rest/v3#api-api-3-project-post
For your starter
I also recommend the REST API browser for experimenting easily with api calls
I think you should have a look at Jira REST API. Here is a REST call to create a project in Jira:
Thanks @Alexey Matveev ,
But I want some time of approval involved. Is there any thing I need to consider like permissions?
If you want to create a custom application, then you should handle the approval process in your application. If you want to handle the approval process in Jira, then I do not understand why you want to write an application in Python.
