×Hi,
I would like to add an attachment to an issue right after it has been created (in the Create postfunction).
The attachement is copied from a file that is located at a given path in the server's filesystem (In JIRA HOME directory for instance).
This is Jira Server. I know this can be accomplish with a groovy scriptrunner postfunction, but I am not familiar with the API involved in this case.
Thanks in advance,
The api you need is the AttachmentManager to create a new attachment.
This can be created using the ComponentAccessor.getAttachmentManager
see
I’m not sure how familiar you are with groovy and scriptrunner so if you need more detail post specific questions on the thread
