JIRA Automation Plugin Setting Component
randyz
I'm trying to set component hierarchy in a project via JIRA automation PluginAgile Classic Boards had the ability to associate one component with another and add a "parent" component when a "child" component was added.
Post Agile update, Classic boards are gone so now I'm trying to set the component via JIRA Automation Plugin.
I already tried Edit Issue Action --> "component=componentname"; with no success.
What is the correct Edit fields expression?
Thank you all
3 votes
Benjamin Dombrowsky [catWorkX]
you must use the id instead of the component name.
e.g. components=10601
Benjamin
Gary Smart
August 10, 2015
Did you ever resolve this? I'm trying to add a component based on Automation also.
Gary
