JIRA Automation plugin
Marek Vejrosta October 19, 2016
Please add any details that might help us help you.
Hi, I use JIRA plugin Automation (https://marketplace.atlassian.com/plugins/com.atlassian.plugin.automation.jira-automation-plugin/server/overview). This plugin use for a series of events. I can not but set one crucial. Setting the action "edit issue action". For this event I need to update the custom field "multi-level cascading select" (com.sourcesense.jira.plugin.cascadingselect).
I am able to update Level1 level, but not another. What should I use sintax when, for example for example: Level 1: Navision (10200) Level 2: Error Inbox- Outbox (10201)
Is Used to update Level1 "customfield_10503 = (10200)" This runs great.
Thanks for advice
Marek Vejrosta February 27, 2017
Hello, unfortunately, there is no progress. We've recommended the use of a standard field cascade select (it has only two levels).
Atlassian unfortunately does not respond.
Thomas Scheibelhofer
I have the same issue, have you ever found a solution?
Best regards
Thomas
