Hi Bob!
I am using the following user-groups1.csv file to import new users to specified groups:
userId,userPassword,userEmail,userFullName,group
sero1,Pa$$w0rd,sergejk1@mymail.com,Sergej1 Kleva1,group1
With the command:
jira --action runFromCsv --common "--action addUser" --file "C:\Temp\user-groups1.csv"
But all created users are in all groups ! No matter what i write in "group" field!
OUPUT:
Run: --action addUser --userId "sero1" --userPassword *** --userEmail "sergejk1@mymail.com" --
userFullName "Sergej1 Kleva1" --group "group1"
User with id 'sero1' already in group 'group1'. Ignore.
User 'sero1' added.
Run completed successfully. 1 actions were successful from file: C:\Temp\user-groups1.csv
I want newly created users to be in group(s) which i write in "group" field in csv.
Is that possible?
Thanks in advance!!!
Brgds,
Sero
I have come to workaround this problem by:
creating new jira-imported-users group
Disable all other default application access group and leave only "jira-imported-users" group in your JIRA -> Administration -> Applications -> Application Access
btw: if you want to add user to multiple groups you should have the right syntax in csv:
ie:
userId, userPassword, userEmail, userFullName, group
user1, Pa$$w0rd, user1@my.company.com, John Doe, "group1, group2, group3"
group1, group2 and group3 should exist before you trigger the command!
