i've the following Problem:
We're deleting some Custom Fields, which are (or are not) referenced by different Column Order Gadgets in different Dashboards. I want to find out on which gadget the custom fields are displayed, so i can replace the deleted column with a different customfield.
Is there DB-Entry (for example referencing the portletconfiguration-Table) or some configuration files?
Thanks for you help.
See the comment above, the data is stored in the gadgetuserprference.
I think if find the table: in gadgetuserpreference in the column userprefvalue i can find the customfields referenced by the gadget
