×Hi All,
I am using JIRA 4.2.3 where importing subtask and link to parent issue is not available,
so i imported the subtasks and parent issues, and want to you CLI to link them.
I have the subtasks issue key and parent issue key, but i do not know how to link them.
Can kindly advice me on this problem?
It appears as the subtasks.
The subtasks can be sucessfully imported without parent in the JIRA 4.2.3, so the next step is to link the subtask to the parent issue (ideally with issue id), however i do not know how to link them using CLI?
Or any work around?
After you imported the data do your subtasks mentioned above show up as subtasks or as issues?
Are you asking how to convert an issue (not a subtast) into a subtask of another issue like Convert to Subtask on the UI? If so, this is not possible via the CLI or available remote APIs.
The subtasks without parent as well as the issue items are sucessfully imported in the JIRA 4.2.3 (because the feature of indicating parent id and issue id is not available), so the next step is to link the subtask to the parent issue (ideally with issue id), however i do not know how to link them using CLI?
Or any work around?
or how do i use the "createIssue" cmd line, when i want to set 'due date', 'date created', 'status' and other custom field? because i do not see the duedate and the rest in the parameters.
i can use this command line to create the sub tasks associate with issue items if i can set those above. Thanks.
Issues |
Create a new issue or subtask for a project. |
parent, priority, reporter, assignee,description, components, affectsVersions,fixVersions, environment, security, field,values, field2, values2, asVersion,asComponent, asCascadeSelect, date,dateFormat, custom, autoVersion, autoComponent, comment, group, role,findReplace, findReplaceRegex, file,encoding |
and may i know how to more than 2 fields (field, field2) in one command line?
Examples can often be used to help with this type of question. Specifically to your questions
Hi may i know how to insert date into custom field that is in date format? i keep on getting java null pointer exception. below is the command:
An example would be appreciated.
Thanks in advanced.
Create an issue and follow steps to Provide problem determination information
It works fine after a JIRA restart
bash-3.00$ ./jira.sh --action updateIssue --issue "EQAPSTAB-1090" --custom "'GERR Sub-Task Due Date:01/Jan/12'"
Thx bob, you are a life saver.
