JIRA Component Watcher details and general knowledge
Infinera November 17, 2015
Just to get more details with this plugin. Please be so kind to answer below topics...
1) We will upgrade to JIRA 7 Q1 next year and we need to know if until then a new version will be released to be compatible?
2) This Plugin is available via REST API? The use case is if project admins want to add user to watch a component but with no need to go via GUI and API.
3) When we add users to watch a component were is this data stored? (DB, file, cache)
4) Does this plugin will change some existing table?
5) Regarding Backups. Is the Component Watcher stored in the JIRA XML backup or via direct DB backup? Or we should backup other folder or file.
6) Regarding the recovery. If we recover the full JIRA instance via DB or via (ZIP with XML) all the watched will be recovered?
Regards
OlgaP January 17, 2016
We also interested in plugin upgrade for JIRA 7 or is there any alternative plugin with the same functionality  . Does Atlassian support team can answer ?
Infinera November 25, 2015
Can someone answer my doubts.
Regards
