I'm not sure where this comes from, as I haven't build the app, but when I added JIRA mobile connect to the app, and connected a button to open the Feedback view, the text in the description field is white, on white background.
How can I fix this?
Hi Hans,
Unfurtunatelly this is a known problem and the bug report is being tracked here: https://jira.atlassian.com/browse/JRA-31874
I strongly recommend you to vote for it (so it increases it's priority), add yourself as a watcher (in order to get updates) and if you have the time please add a brief comment so the DEVs can get the customer's point of view on how this should be implemented.
Hope this information helps!
Marlon Aguiar
That is not the same issue unfortunately, but I'll close this anyway since we don't use Jira connect anymore.
