JIRA Custom Field Name for JIRA Synchonizer
Leonard Kong
October 4, 2013
I am trying to setup the TFS configuration side of TFS4JIRA Synchronizer configuration profile. Everything seems to work except for the JIRA Custom Field name. I created the custom field per documentation (Tools\Process Editor\Work Item Types\Open WIT from Server\My Collection\MyProject\Bug but when I attempt to enter the name in the JIRA Custom Field Name, nothing appears in the drop down, . . . so I'm guessing It isn't finding the custom name. I created the custom field name under WorkItem Type Bug, it didn't work, so also created one under Work Item Type Issue. The Configuration field cant find either one.
Balraj kokkanti
October 23, 2017
Hi did you fix this problem.
PetraPensky May 29, 2014
Did you fix that problem?
We are evaluating tfs4jira and have the same problem...
Thanks in advance.
