JIRA - Custom Project Types
Mirek
Hi all,
In new versions of JIRA example - 6.1.x) there is a new way of creating projects. Now we can choose what type of a project we want to create and this will automatically associate project with different configuration schemes. Great!
My question is short and simple.. Is it possible (or will be possible in the near future) to somehow (from the UI or by modify a file) add a custom Project Type next to the default types?
Mirek
richie_gee
November 5, 2013
There is also a feature request on similar functions, please vote on it if you would like to see it implemented.
https://jira.atlassian.com/browse/JRA-7020
JulianA
November 5, 2013
AFAIK you can create your own template by following this doc:
https://developer.atlassian.com/display/JIRADEV/Creating+a+Project+Template
Cheers Julian
Jaro Sat
June 15, 2015
So coding is the only possible solution? How about coding plugin for JIRA onDemand?
