JIRA-Filter will not show every open issue
Adrian K_ February 8, 2017
in the attached picture you can see my Workflow.
If an issue is in the state "Bearbeitung" it will list in the JIRA-Standardsearch "all open Issues". If the state is "Erledigt" the issue don´t listed in the filter "all open issues".-> everything is fine.
If the user marked the issue to "Prüfung" from the state "Erledigt" it don´t listed in the search "all open issues". Why?
How can i fix or configure the standardsearch?
Thank´s
Adrian
Thanks for our feedback.
I have found an other alternative. i clear the field resolution automaticly
https://confluence.atlassian.com/jirakb/how-to-clear-the-resolution-field-when-the-issue-is-reopened-648381467.html
Alain C_ Boss
The standard search "Open Issues" is implemented as "resolution = Unresolved order by priority DESC,updated DESC". So the search uses the resolution and not the status to find open issues. When you change the status from "Erledigt" to "Prüfung" the resolution will, obviously, not been changed and your issue won't show up as open (because the resolution is resolved).
I don't know how to change the standard filter. However, you can create your own like
status in (offen, bearbeitung, rückfrage, prüfung) order by priority desc, updated desc
then mark it as favourite
Alain
