JIRA - GitHub: Is it possible to transition issues on Jira, when a GitHub label is changed?
Rita Elyanova January 20, 2020
Thanks for the help in advance here!
Question: Is there an integration between JIRA and GitHub, which would automatically transition issues on Jira through the workflow, when a GitHub label is changed for the ticket on GitHub?
Example: The label for a ticket is changed from code review to testing. Now, the developer has to go to ticket on JIRA and change its status there as well.
It would be great though, to not have the developer do this step and have the ticket being automatically transitioned on JIRA.
Thanks!
Ganesh Babu
Hi @Rita Elyanova
You can have look at the plugin named "git integration for jira" which will help you to get insync with github and jira.
Link that gives an overview on the plugin: https://bigbrassband.com/overview.html
Rita Elyanova January 29, 2020
Thank you for that!
