Hi all,
I'm using JIRA version v6.4.2 on my own server and Hip Chat in the cloud.
I've done the last Hip Chat add-on update on my JIRA server and it has broken the integration. Now when I click on the Project / HipChat Integration system page I got an error 500 and the logs:
com.google.template.soy.tofu.SoyTofuException: In template JIRA.Templates.HipChat.Project.Admin.configurePage: When evaluating "length(keys($projectConfiguration.configuration)) > 0": Error while computing function "keys($projectConfiguration.configuration)": Argument to keys() function is not SoyMapData.
com.google.template.soy.tofu.SoyTofuException: In template JIRA.Templates.HipChat.Project.Admin.configurePage: When evaluating "length(keys($projectConfiguration.configuration)) > 0": Error while computing function "keys($projectConfiguration.configuration)": Argument to keys() function is not SoyMapData. at com.google.template.soy.tofu.internal.BaseTofu.renderMainHelper(BaseTofu.java:341) at com.google.template.soy.tofu.internal.BaseTofu.renderMain(BaseTofu.java:300) at com.google.template.soy.tofu.internal.BaseTofu.access$100(BaseTofu.java:56) at com.google.template.soy.tofu.internal.BaseTofu$RendererImpl.render(BaseTofu.java:427) at com.atlassian.soy.impl.DefaultSoyManager.render(DefaultSoyManager.java:118)
Any clue for this problem?
Sébastien
Finally fixed with the new add-on version 7.8.3 !
Hey Sébastien!
In digging around a bit, I haven't found exactly the issue you're seeing, but check out these links:
Viewing a Project or an Issue throws: com.google.template.soy.tofu.SoyTofuException
And this issue, specifically because the fixVersion is newer than the version you're running, v6.4.2:
https://jira.atlassian.com/browse/JRA-42411
Let me know if those get you anywhere!
Thanks for your answer. The log gives more information. Should I remove some add-ons?
/rest/hipchat/integrations/1.0/configuration/status [common.error.jersey.ThrowableExceptionMapper] Uncaught exception thrown by REST service: bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin]
com.atlassian.activeobjects.internal.ActiveObjectsInitException: bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin]
at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:105)
at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:92)
at com.atlassian.sal.core.executor.ThreadLocalDelegateCallable.call(ThreadLocalDelegateCallable.java:42)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.atlassian.activeobjects.internal.ActiveObjectsSqlException: There was a SQL exception thrown by the Active Objects library:
Database:
- name:Oracle
- version:Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
- minor version:2
- major version:11
Driver:
- name:Oracle JDBC driver
- version:11.2.0.2.0
java.sql.SQLException: ORA-01408: such column list already indexed
at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.migrate(EntityManagedActiveObjects.java:54)
at com.atlassian.activeobjects.internal.AbstractActiveObjectsFactory$1.doInTransaction(AbstractActiveObjectsFactory.java:91)
at com.atlassian.activeobjects.internal.AbstractActiveObjectsFactory$1.doInTransaction(AbstractActiveObjectsFactory.java:85)
at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:25)
at com.atlassian.jira.DefaultHostContextAccessor.doInTransaction(DefaultHostContextAccessor.java:34)
at sun.reflect.GeneratedMethodAccessor142.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:134)
at com.sun.proxy.$Proxy171.doInTransaction(Unknown Source)
Thanks for the log!
The big error that stands out to me is java.sql.SQLException: ORA-01408: such column list already indexed, which led me to this:
But this doesn't make sense, as you're on a much newer version of JIRA. Could you try a lock and index rebuild anyways? Or have you?
Did you try the permissions fix in the links above?
Nothing better ![]()
Is there any official list of indexes I should have with my version? (I guess no)
