JIRA Insight advanced query
diego_confalonieri
October 16, 2020
Hi all,
I try to ask an help.
I’m using the search function but I can not extract in the result the ‘inboud object’ columns.
In my example I use 'Hosted on server' as filter correctly but I don’t see the value of that column in the result.
Any ideas?
Diego
Matt October 20, 2020
I always specify the initial object type in the query.
objectType="XXXX" AND etc
Then I click Column and filter by that object type and choose the fields.
