JIRA Memory Issue
santosh reddy December 12, 2013
Hi, We are running jira4.3.3 and have been noticing some memory issues.To analyze for any memory leaks I have taken a heapdump and run an analyzer tool,
The results returns with com.google.common.collect.MapMaker as the heavily used object,
can anyone please let me know which section JIRA uses this or is part of any gadget?
Theinvisibleman
December 12, 2013
Heap Dumps are usually only helpful if you are experiencing OutOfMemory errors though. Is your JIRA instance facing any of those?
RambanamP
December 12, 2013
following doc may help you to performance tunning the jira application
https://confluence.atlassian.com/display/JIRAKB/JIRA+Performance+Tuning
Mizan
December 12, 2013
(On a test env.) Try running the analyzer tool with plugins disabled. Then enable the plugins one by one , for each plugin run the analyzer . Even a plugin can cause performance issues .
