JIRA mobile connect - why my feedback is not sending? it always say "Feedback in Transit! This feedback is still on its way! Please try again soon." all setup are done. or maybe i still missed something? Thanks
I am having this same issue, the jiraconnectuser was not created, I manually created it but this does not seem to help. What do I need to do in order to have this user created?
Good to hear Tuan. I will try and update the jira plugin to avoid this in the future.
Or at least to print a more descriptive error message.
Nick
Hi Nick,
I solved the problem. It turns out I have to add jiraconnectuser into the project that I want to enable JIRA Connect. I do this by go to Administration area --> <MY Project> --> People, then add jiraconnectuser into the project.
Tuan.
Hi Tuan,
You don't need to create a new user. The jiraconnectuser (Remote Mobile User) should already exist in your instance.
For some reason however, that user does not have the 'Create Issue' permission.
Can you please add the Create Issue permission for that user in the Permission Scheme for your project and let us know if that fixes this error.
UPDATE: Please ensure that user is in the jira-users group.
Nick
Hi Nick,
I have the same issues as iMackoy. Here is my log when I run it in simulator:
[JMCTransportOperation connection:didFailWithError:] Request failed: Error occurred while creating issue through workflow: User 'jiraconnectuser' doesn't have the 'Create Issue' permission URL: http://jira.niceagency.co.uk:8080/rest/jconnect/1.0/issue/create?project=JIRACONNECTTEST&apikey=c5f9414c-18b7-4bb2-92c6-974f04a331f9, response code: 401
Do I need to create a new user in "jiraconnectuser". I tried to create a new user on JIRA under that name, however JIRA ask me to provide password for that user, on iOS project where should I assign the user's details.
Tuan.
Hi iMackoy,
Are you testing this in the simulator ? If so, you should see some log messages in the logs as to why the request is failing.
JMC queues any messages that fail to send (due to a server issue, or if the user has no connectivity) and tries sending these at a later time.
Some things to check:
I would check the logs to begin with however. Let me know how you go.
Nick
Hi NIck,
Thanks for your reply.
Anyway both logs(Device and simulator) are not so helpfull.
Front and Backend setup are done.
BTW, I'm using VPN network
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.181793]: Client apsd set type to background application
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.187509]: Enable WoW requested by "apsd"
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.190971]: Unable to dispatch WowStateChanged message to client lockdownd (268435460)
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.193805]: Unable to dispatch WowStateChanged message to client SpringBoard (268435460)
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.194192]: Unable to dispatch WowStateChanged message to client dataaccessd (268435460)
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.207509]: Client dataaccessd set type to background application
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.213300]: Enable WoW requested by "dataaccessd"
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.213821]: Unable to dispatch WowStateChanged message to client lockdownd (268435460)
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.214189]: Unable to dispatch WowStateChanged message to client SpringBoard (268435460)
Oct 20 11:36:42 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774602.214532]: Unable to dispatch WowStateChanged message to client dataaccessd (268435460)
Oct 20 11:36:43 SCB-iPhone-3GS configd[14] <Notice>: network configuration changed.
Oct 20 11:36:43 SCB-iPhone-3GS UserEventAgent[12] <Warning>: Unable to cancel system wake for 2011-10-20 11:36:32 +0800. IOPMCancelScheduledPowerEvent() returned 0xe00002c2
Oct 20 11:36:48 SCB-iPhone-3GS UserEventAgent[12] <Warning>: Unable to cancel system wake for 2011-10-20 11:36:33 +0800. IOPMCancelScheduledPowerEvent() returned 0xe00002c2
Oct 20 11:37:11 SCB-iPhone-3GS com.apple.locationd[45] <Notice>: NOTICE,Potentially setting system time zone to Asia/Kuala_Lumpur
Oct 20 11:37:12 SCB-iPhone-3GS timed[3347] <Notice>: (Note ) CoreTime: Received timezone "Asia/Kuala_Lumpur" from "Location"
Oct 20 11:37:12 SCB-iPhone-3GS timed[3347] <Notice>: (Note ) CoreTime: Not setting time zone to Asia/Kuala_Lumpur from Location
DEVICE LOG:
Oct 20 11:36:00 SCB-iPhone-3GS kernel[0] <Debug>: launchd[3344] Builtin profile: container (sandbox)
Oct 20 11:36:00 SCB-iPhone-3GS kernel[0] <Debug>: launchd[3344] Container: /private/var/mobile/Applications/21D0B8F7-BA51-4976-9675-2B39D2FF008B [69] (sandbox)
Oct 20 11:36:01 SCB-iPhone-3GS TradePortMobile[3344] <Warning>: App launched with options - 0
Oct 20 11:36:01 SCB-iPhone-3GS TradePortMobile[3344] <Warning>: TVOutManager: startTVOut failed (no external screens detected)
Oct 20 11:36:01 SCB-iPhone-3GS TradePortMobile[3344] <Warning>: Application did become active.
Oct 20 11:36:33 SCB-iPhone-3GS UserEventAgent[12] <Warning>: Unable to cancel system wake for 2011-10-20 11:36:23 +0800. IOPMCancelScheduledPowerEvent() returned 0xe00002c2
Oct 20 11:36:33 SCB-iPhone-3GS kernel[0] <Debug>: AppleSerialMultiplexer: mux-ad(eng)::setLinkQualityMetricGated: Setting link quality metric to 50
Oct 20 11:36:38 SCB-iPhone-3GS UserEventAgent[12] <Warning>: Unable to cancel system wake for 2011-10-20 11:36:23 +0800. IOPMCancelScheduledPowerEvent() returned 0xe00002c2
Oct 20 11:36:41 SCB-iPhone-3GS configd[14] <Notice>: network configuration changed.
Oct 20 11:38:39 SCB-iPhone-3GS configd[14] <Notice>: network configuration changed.
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.101608]: Client apsd set type to background application
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.106607]: Enable WoW requested by "apsd"
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.109237]: Unable to dispatch WowStateChanged message to client lockdownd (268435460)
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.111107]: Unable to dispatch WowStateChanged message to client SpringBoard (268435460)
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.113508]: Unable to dispatch WowStateChanged message to client dataaccessd (268435460)
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.127282]: Client dataaccessd set type to background application
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.136868]: Enable WoW requested by "dataaccessd"
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.137349]: Unable to dispatch WowStateChanged message to client lockdownd (268435460)
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.137696]: Unable to dispatch WowStateChanged message to client SpringBoard (268435460)
Oct 20 11:38:40 SCB-iPhone-3GS wifid[26] <Error>: WiFi:[340774720.143469]: Unable to dispatch WowStateChanged message to client dataaccessd (268435460)
Oct 20 11:38:40 SCB-iPhone-3GS timed[3353] <Notice>: (Note ) CoreTime: Want active time in 18.00hrs. Need active time in 101.34hrs.
Hi iMackoy,
Are you able to run your App in the simulator ? JMC will log messages when the DEBUG flag is defined.
If you wish to enable JMC logging in your app on the device, then remove the if/else here, and just pass the log message through to NSLog directly: https://bitbucket.org/atlassian/jiraconnect-ios/src/fc3c729f37e4/JIRAConnect/JMCClasses/JMCMacros.h#cl-25
Or, when you build for the device, ensure the DEBUG flag is set in Xcode.
Nick
