JIRA OnDemand and SAML connectivity
Abdoul Abdoulla
June 9, 2013
My company is exploring the option for using Jira/Greenhopper on demand which looks good.
We would like to know if JIRA OnDemand supports SAML V2 protocol to communicate with our internal Identity Management system running on SAFE.
Any clue would be appreciated. Thanks.
Regards
Abdoul
Harry Chan
June 9, 2013
If this feature is critical, the best to do would be to look at an existing Crowd plugin or extend Crowd to support this yourself. It'll have to be the downloaded / 3rd party hosted version and not OnDemand though.
Dave
June 25, 2013
Hi Abdoul,
There's actually an existing feature request for this in the OnDemand project. I would suggest you check that out and vote/comment on it to help raise the priority - https://jira.atlassian.com/browse/AOD-1837
Best,
-dave
Timothy
June 9, 2013
No. No feature exists at the moment for OnDemand.
