JIRA-Python: How can I pass user inputs in Jira issue search?
Lakshveer Singh July 19, 2017
I'm trying to get information based on the input provided by user and then passing it in a function which gives back the issues created. But I'm not able to pass the objects in search_issue query?
def issuecreated(projectname, reportername, datefrom, dateto):
print projectname, reportername, datefrom, dateto
for i in jira.search_issues('project = projectname AND reporter = reportername AND created > datefrom and created < dateto'):
return i
projectname=raw_input("Please give the project name: ")
reportername=raw_input("Please provide the name of creator: ")
datefrom=raw_input("Please provide the time interval for which you want issues: From ")
dateto=raw_input("Please provide the time interval for which you want issues: To ")
I'm able to see the inputs in the function by it is not getting passed in jira.search_issues.
Please help.
Thanks!
MattS
July 19, 2017
Create a string that is made up of the JQL you know and the input from users. Then pass that string to jira.search_issues()
"Static text %s" % variablename
Thanks for the input!
I tried to pass the string into jira.search_issues(), but it throws error, jira.exceptions.JIRAError on jira.search_issue() line. Here is what I did.
query = 'project = projectname AND reporter = reportername AND created > datefrom and created < dateto'
for i in jira.search_issues(query):
print i
I have given the encoding magic comments to convert Unicode.
Lakshveer Singh July 23, 2017
It works now, thanks!
Anto Praveen January 21, 2019
How it worked , i am facing the same issue.
worked now :)
rithwik_poleneni March 6, 2020
@Lakshveer Singh @Anto Praveen Can you help me I am facing similar problem
here is my line : issues_in_project = jira.search_issues('status = "Pending QA Deployment" AND projectname = ALPHA', startAt=0, maxResults=2000, validate_query=True, fields=None, expand=None, json_result=None)
I want to pass projectname as parameter. I am seeing issue while running code
papiha
August 20, 2021
hi @Lakshveer Singh
can you hep me out. I am also looking for parameter to project. when i hard coded the project name as < project in (x,y,z) > it work. now i want to give this X,Y,Z project in excell and in query i want to read from excel.
