JIRA Reindexing Script is not working in 5.2.11
Ravichandran Sundaramurthy July 7, 2013
I have automated Reindexing script in JIRA 4.3.4 version, the same script when i use in 5.2.11 version i am getting the following error log.
In Jelly Runner i am getting this error.
Jelly script ran and produced the following messages.
<JiraJelly xmlns:jira='jelly:com.atlassian.jira.jelly.enterprise.JiraTagLib' xmlns:email='jelly:email' xmlns:j='jelly:core' xmlns:log='jelly:log'>
<Error action='User: Xbbj551 does not exist'>
<TagContents>(Login(username=Xbbj551)(password=Welcome20))</TagContents>
<ExecutedAs>user=xbbj551</ExecutedAs>
<ErrorMessage>Login</ErrorMessage>
</Error>
<log:INFO trim='true'>day : 2</log:INFO>
<log:INFO trim='true'>hour : 4</log:INFO>
</JiraJelly>
ID (xbbj551) shows does not exist, but this is my correct id.
Please provide your suggestion on this.
Ravi
Ravichandran Sundaramurthy July 14, 2013
The issue is resolved now, error throwed due to userid LDAP validation from Siteminder. Found the cause and fixed it.
Hence, Closing this issue.
Ravichandran Sundaramurthy July 8, 2013
Hi Renjith.
Thanks for your quick response.
I tried to run the below index class in 4.3.4 it worked perfectly, the same script when i run in 5.2.11 i am getting error.
<j:invokeStatic className="com.atlassian.jira.ComponentManager" method="getInstance" var="componentManager"/>
<j:invoke on="${componentManager}" method="getIndexManager" var="indexManager"/>
<j:invoke on="${indexManager}" method="reIndexAll" var="millis"/>
Ravi
Renjith Pillai
July 7, 2013
In fact, there is no need to automatically trigger re-indexing. You should be looking at what is causing an issue in the index and correct it.
And what is the contents of this Reindexing script, can you post it?
