JIRA - ScriptRunner - Insight - Groovy - get Insight custom field value
Markus May 29, 2018
I try to pre-fill an Insight custom field with ScripRunner Behaviours.
Basically I am struggeling getting the options out of the custom field I want to prefill. Here's the code I use so far (with some logging)
import com.atlassian.jira.issue.CustomFieldManager
def field = getFieldByName("SP Anzahl RAM")
def optionsManager = ComponentAccessor.getOptionsManager()
def customField = customFieldManager.getCustomFieldObject(field.getFieldId())
def config = customField.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
Debugging this I get the following content of config: "com.atlassian.jira.issue.fields.config.FieldConfigImpl@d59871da"
and options seems to be empty "[]"
what am I missing?
Thank you
Markus
Daniel Yelamos [Adaptavist]
May 30, 2018
Hi Markus.
Currently we do not support behaviours for JIRA. I'm actually the developer assigned to this feature.
You can follow the development of this issue here:
https://productsupport.adaptavist.com/browse/SRJIRA-2563
Cheers!
DYelamos
Markus May 30, 2018
Hi Daniel,
thanks for the update. Sad to hear, that this isn't working, but good to hear, that it's already adressed. I will watch the issue.
Cheers
Markus
May 30, 2018
Hi Markus.
No problem. Could you please accept my answer so that other users know that this question has been solved?
Cheers
DYelamos
Mario Gerlach
June 9, 2024
Assets / Insights have the key of the Insightobject therefore:
  1. Search the Key
  2. Set the Key as FormFieldValue
def asset = Assets.search(/objectType ="YOUROBJ" AND Name  = "YOURLABEL"/)
def key = asset.next()?.getObjectKey()
   getFieldByName("YOURFIELD").tap{
      setDescription(key)
      setFormValue(key)
