JIRA Standalone SSL behind F5 Load Balancer
Royden Ngan
April 30, 2012
I'm running JIRA 4.3.4 Standalone and I'm trying to utilize an F5 load balancer with a wildcard SSL certificate. Keep in mind I am not load balancing JIRA. It will be a single server behind a single VIP. I'm just trying to avoid installing an SSL cert directly on the server.
FYI, I was able to get Confluence running behind the F5 with Wildcard SSL cert:
https://answers.atlassian.com/questions/26075/run-confluence-behind-f5-load-balancer
I am trying to find a similar solution for JIRA.
PauloP
September 10, 2012
Hi Royn
Knowing that BIGIP is based on Apache structure, I believe that you should review JIRA and Apache basic integration. After that, you my try to specify the SSL settings.
1. Integrating JIRA and Apache > http://confluence.atlassian.com/display/JIRA/Integrating+JIRA+with+Apache
2. Apache and JIRA integration with SSL connection > http://confluence.atlassian.com/display/JIRA/Integrating+JIRA+with+Apache+using+SSL
Pay attention to the tags proxyName and proxyPort in the server.xml file. I believe that your main configuration is there.
Paulo Renato
