Having trouble getting JIRA to start up again after stopping / starting the service on Windows. Getting the following message:
JIRA Startup Failed |
You cannot access JIRA at present. Look at the table below to identify the reasons | ||
I've looked around on this site and followed the instructions given but no avail. The steps I've taken so far are:
Totally stuck now - below is my log.
Thanks in advance!
2013-04-10 14:23:58,784 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml 2013-04-10 14:24:01,507 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] **************** JIRA starting... **************** 2013-04-10 14:24:01,642 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] ___ Environment _____________________________ JIRA Build : 5.2.10#853-sha1:c0ba2680a6a588d5657e1aadb3169a8dbf69984f Build Date : Tue Apr 02 00:00:00 BST 2013 JIRA Installation Type : Standalone Application Server : Apache Tomcat/7.0.29 - Servlet API 3.0 Java Version : 1.6.0_43 - Sun Microsystems Inc. Current Working Directory : C:\Program Files\Atlassian\JIRA\bin Maximum Allowable Memory : 742MB Total Memory : 247MB Free Memory : 217MB Used Memory : 30MB Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 1770688(1729K) committed = 2555904(2496K) max = 50331648(49152K) Memory Pool: Eden Space : Eden Space: init = 71630848(69952K) used = 25926024(25318K) committed = 71630848(69952K) max = 214827008(209792K) Memory Pool: Survivor Space : Survivor Space: init = 8912896(8704K) used = 1454072(1419K) committed = 8912896(8704K) max = 26804224(26176K) Memory Pool: Tenured Gen : Tenured Gen: init = 178978816(174784K) used = 4042248(3947K) committed = 178978816(174784K) max = 536870912(524288K) Memory Pool: Perm Gen : Perm Gen: init = 21757952(21248K) used = 20445784(19966K) committed = 21757952(21248K) max = 268435456(262144K) JVM Input Arguments : -Dcatalina.base=C:\Program Files\Atlassian\JIRA -Dcatalina.home=C:\Program Files\Atlassian\JIRA -Djava.endorsed.dirs=C:\Program Files\Atlassian\JIRA\endorsed -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dmail.mime.decodeparameters=true -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Djava.io.tmpdir=C:\Program Files\Atlassian\JIRA\temp -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.util.logging.config.file=C:\Program Files\Atlassian\JIRA\conf\logging.properties -XX:MaxPermSize=256m -Xms256m -Xmx768m ___ Java System Properties ________________ awt.toolkit : sun.awt.windows.WToolkit catalina.base : C:\Program Files\Atlassian\JIRA catalina.home : C:\Program Files\Atlassian\JIRA catalina.useNaming : true common.loader : ${catalina.base}/lib, ${catalina.base}/lib/*.jar, ${catalina.home}/lib, ${catalina.home}/lib/*.jar file.encoding : Cp1252 file.encoding.pkg : sun.io java.awt.graphicsenv : sun.awt.Win32GraphicsEnvironment java.awt.headless : true -Datlassian.standalone=JIRA -Dmail.mime.decodeparameters=true java.awt.printerjob : sun.awt.windows.WPrinterJob java.class.version : 50.0 java.home : C:\PROGRA~1\ATLASS~1\JIRA\jre java.io.tmpdir : C:\Program Files\Atlassian\JIRA\temp java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory java.naming.factory.url.pkgs : org.apache.naming java.runtime.name : Java(TM) SE Runtime Environment java.runtime.version : 1.6.0_43-b01 java.specification.name : Java Platform API Specification java.specification.vendor : Sun Microsystems Inc. java.specification.version : 1.6 java.util.logging.config.file : C:\Program Files\Atlassian\JIRA\conf\logging.properties java.util.logging.manager : org.apache.juli.ClassLoaderLogManager java.vendor : Sun Microsystems Inc. java.vendor.url : http://java.sun.com/ java.vendor.url.bug : http://java.sun.com/cgi-bin/bugreport.cgi java.version : 1.6.0_43 java.vm.info : mixed mode java.vm.name : Java HotSpot(TM) 64-Bit Server VM java.vm.specification.name : Java Virtual Machine Specification java.vm.specification.vendor : Sun Microsystems Inc. java.vm.specification.version : 1.0 java.vm.vendor : Sun Microsystems Inc. java.vm.version : 20.14-b01 org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true os.arch : amd64 os.name : Windows 7 os.version : 6.1 package.access : sun., org.apache.catalina., org.apache.coyote., org.apache.tomcat., org.apache.jasper. package.definition : sun., java., org.apache.catalina., org.apache.coyote., org.apache.tomcat., org.apache.jasper. server.loader : shared.loader : sun.arch.data.model : 64 sun.boot.library.path : C:\PROGRA~1\ATLASS~1\JIRA\jre\bin sun.cpu.endian : little sun.cpu.isalist : amd64 sun.desktop : windows sun.io.unicode.encoding : UnicodeLittle sun.jnu.encoding : Cp1252 sun.management.compiler : HotSpot 64-Bit Tiered Compilers sun.os.patch.level : tomcat.util.buf.StringCache.byte.enabled : true tomcat.util.scan.DefaultJarScanner.jarsToSkip : bootstrap.jar, commons-daemon.jar, tomcat-juli.jar, annotations-api.jar, el-api.jar, jsp-api.jar, servlet-api.jar, catalina.jar, catalina-ant.jar, catalina-ha.jar, catalina-tribes.jar, jasper.jar, jasper-el.jar, ecj-*.jar, tomcat-api.jar, tomcat-util.jar, tomcat-coyote.jar, tomcat-dbcp.jar, tomcat-jni.jar, tomcat-spdy.jar, tomcat-i18n-en.jar, tomcat-i18n-es.jar, tomcat-i18n-fr.jar, tomcat-i18n-ja.jar, tomcat-juli-adapters.jar, catalina-jmx-remote.jar, catalina-ws.jar, tomcat-jdbc.jar, commons-beanutils*.jar, commons-codec*.jar, commons-collections*.jar, commons-dbcp*.jar, commons-digester*.jar, commons-fileupload*.jar, commons-httpclient*.jar, commons-io*.jar, commons-lang*.jar, commons-logging*.jar, commons-math*.jar, commons-pool*.jar, jstl.jar, geronimo-spec-jaxrpc*.jar, wsdl4j*.jar, ant.jar, ant-junit*.jar, aspectj*.jar, jmx.jar, h2*.jar, hibernate*.jar, httpclient*.jar, jmx-tools.jar, jta*.jar, log4j*.jar, mail*.jar, slf4j*.jar, xercesImpl.jar, xmlParserAPIs.jar, xml-apis.jar, dnsns.jar, ldapsec.jar, localedata.jar, sunjce_provider.jar, sunmscapi.jar, sunpkcs11.jar, jhall.jar, tools.jar, sunec.jar, zipfs.jar, apple_provider.jar, AppleScriptEngine.jar, CoreAudio.jar, dns_sd.jar, j3daudio.jar, j3dcore.jar, j3dutils.jar, jai_core.jar, jai_codec.jar, mlibwrapper_jai.jar, MRJToolkit.jar, vecmath.jar, junit.jar, junit-*.jar, ant-launcher.jar user.country : GB user.dir : C:\Program Files\Atlassian\JIRA\bin user.home : C:\ user.language : en user.name : S8JIRA$ user.timezone : Europe/London user.variant : 2013-04-10 14:24:01,874 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks. 2013-04-10 14:24:02,350 localhost-startStop-1 INFO [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory 'C:\Program Files\Atlassian\Application Data\JIRA' is validated and locked for exclusive use by this instance. 2013-04-10 14:24:02,355 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully. 2013-04-10 14:24:04,314 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml 2013-04-10 14:24:05,133 localhost-startStop-1 INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Database Checklist Launcher 2013-04-10 14:24:21,661 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Name is MySQL 2013-04-10 14:24:21,662 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Version is 5.5.27 2013-04-10 14:24:21,662 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Name is MySQL-AB JDBC Driver 2013-04-10 14:24:21,662 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Version is mysql-connector-java-5.1.23 ( Revision: ${bzr.revision-id} ) 2013-04-10 14:24:32,432 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseChecklistLauncher] JIRA database startup checks completed successfully. 2013-04-10 14:24:32,440 localhost-startStop-1 INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Post database-configuration launchers 2013-04-10 14:24:42,092 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml 2013-04-10 14:24:50,183 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseLauncher] Database transactions enabled: true 2013-04-10 14:24:50,191 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2 2013-04-10 14:24:50,196 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] Database configuration OK ___ Database Configuration ________________ Loading entityengine.xml from : file:/C:/Program%20Files/Atlassian/JIRA/atlassian-jira/WEB-INF/classes/entityengine.xml Entity model field type name : mysql Entity model schema name : Database Version : MySQL - 5.5.27 Database Driver : MySQL-AB JDBC Driver - mysql-connector-java-5.1.23 ( Revision: ${bzr.revision-id} ) Database URL : jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB Database JDBC config : mysql jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB 2013-04-10 14:24:54,794 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] ___ Starting the JIRA Plugin System _________________ 2013-04-10 14:24:54,799 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Initialising the plugin system 2013-04-10 14:25:55,698 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\activeobjects-jira-spi-0.19.16.jar (1364883414000) created 2013-04-10 14:25:56,010 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\activeobjects-plugin-0.19.16.jar (1364883412000) created 2013-04-10 14:25:56,939 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\applinks-plugin-3.10.4.jar (1364883384000) created 2013-04-10 14:25:57,058 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-admin-quicksearch-jira-1.1.1.jar (1364883410000) created 2013-04-10 14:25:57,069 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-bot-killer-1.7.2.1.jar (1364883410000) created 2013-04-10 14:25:57,089 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-custom-apps-plugin-1.15.jar (1364883414000) created 2013-04-10 14:25:57,132 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-dashboard-plugin-3.2.0-m2-1.jar (1364883412000) created 2013-04-10 14:25:57,153 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-directory-plugin-3.2.0-m2-1.jar (1364883414000) created 2013-04-10 14:25:57,168 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-embedded-plugin-3.2.0-m2-1.jar (1364883414000) created 2013-04-10 14:25:57,187 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-oauth-service-provider-plugin-3.2.0-m2-1.jar (1364883414000) created 2013-04-10 14:25:57,306 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-opensocial-plugin-3.2.0-m2-1.jar (1364883414000) created 2013-04-10 14:25:57,524 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-publisher-plugin-3.2.0-m2-1.jar (1364883414000) created 2013-04-10 14:25:57,760 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-jira-rpc-plugin-5.1.3.jar (1364883414000) created 2013-04-10 14:25:57,813 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-nav-links-plugin-1.3.16.jar (1364883414000) created 2013-04-10 14:25:57,851 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-admin-plugin-1.6.1.jar (1364883414000) created 2013-04-10 14:25:57,863 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-consumer-plugin-1.6.1.jar (1364883412000) created 2013-04-10 14:25:57,933 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-consumer-spi-1.6.1.jar (1364883282000) created 2013-04-10 14:25:57,961 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-service-provider-plugin-1.6.1.jar (1364883414000) created 2013-04-10 14:25:58,020 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-service-provider-spi-1.6.1.jar (1364883278000) created 2013-04-10 14:25:58,102 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-rest-module-compat25-5.2.10.jar (1364883848000) created 2013-04-10 14:25:58,139 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-template-renderer-api-1.4.2.2.jar (1364883266000) created 2013-04-10 14:25:58,435 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-template-renderer-velocity16-plugin-1.4.2.2.jar (1364883266000) created 2013-04-10 14:25:58,641 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-universal-plugin-manager-plugin-2.7.10.jar (1364883410000) created 2013-04-10 14:25:58,932 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\auiplugin-5.0-m10.jar (1364883412000) created 2013-04-10 14:25:58,957 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\com.springsource.com.sun.syndication-0.9.0.jar (1364883410000) created 2013-04-10 14:25:58,982 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\com.springsource.org.jdom-1.0.0.jar (1364883410000) created 2013-04-10 14:25:59,016 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\crowd-rest-application-management-2.4.9.jar (1364883324000) created 2013-04-10 14:25:59,033 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\crowd-rest-plugin-2.4.9.jar (1364883324000) created 2013-04-10 14:25:59,063 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\embedded-crowd-admin-plugin-1.4.5.jar (1364883414000) created 2013-04-10 14:25:59,086 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\hipchat-for-jira-plugin-1.1.13.jar (1364883410000) created 2013-04-10 14:25:59,158 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\httpclient-osgi-4.0.jar (1364883414000) created 2013-04-10 14:25:59,215 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\httpcore-osgi-4.0.jar (1364883412000) created 2013-04-10 14:25:59,271 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\icu4j-3.8-1.jar (1364883412000) created 2013-04-10 14:25:59,306 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-admin-helper-plugin-1.6.jar (1364883414000) created 2013-04-10 14:25:59,342 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-admin-summary-plugin-5.2.10.jar (1364883870000) created 2013-04-10 14:25:59,369 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-application-properties-plugin-5.2.10.jar (1364883870000) created 2013-04-10 14:25:59,565 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-bamboo-plugin-5.2.1.jar (1364883412000) created 2013-04-10 14:25:59,576 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-baseurl-plugin-1.9.jar (1364883414000) created 2013-04-10 14:25:59,979 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-fisheye-plugin-5.2.9.jar (1364883412000) created 2013-04-10 14:26:00,029 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-gadgets-plugin-5.2.10.jar (1364883866000) created 2013-04-10 14:26:00,073 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-header-plugin-5.2.10.jar (1364883894000) created 2013-04-10 14:26:00,091 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-help-tips-0.29.jar (1364883410000) created 2013-04-10 14:26:00,100 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-ical-feed-1.0.12.jar (1364883410000) created 2013-04-10 14:26:00,216 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-importers-plugin-5.0.3.jar (1364883414000) created 2013-04-10 14:26:00,237 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-invite-user-plugin-1.6.jar (1364883414000) created 2013-04-10 14:26:00,293 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-collector-plugin-1.2.9.jar (1364883410000) created 2013-04-10 14:26:00,369 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-applinks-common-plugin-5.2.10.jar (1364883902000) created 2013-04-10 14:26:00,477 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-confluence-plugin-5.2.10.jar (1364883908000) created 2013-04-10 14:26:00,542 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-remote-jira-plugin-5.2.10.jar (1364883902000) created 2013-04-10 14:26:00,566 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-web-plugin-5.2.10.jar (1364883904000) created 2013-04-10 14:26:00,759 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-nav-plugin-1.1.25.21.jar (1364883414000) created 2013-04-10 14:26:00,780 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-json-rpc-plugin-1.0.4.jar (1364883410000) created 2013-04-10 14:26:00,918 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-de_DE-5.2.8-v2r5721-2013-03-15.jar (1364883412000) created 2013-04-10 14:26:00,938 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-es_ES-5.2.8-v2r12795-2013-03-15.jar (1364883412000) created 2013-04-10 14:26:01,094 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-fr_FR-5.2.8-v2r2373-2013-03-15.jar (1364883412000) created 2013-04-10 14:26:01,109 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-ja_JP-5.2.8-v2r15554-2013-03-18.jar (1364883410000) created 2013-04-10 14:26:01,125 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-languages-5.2.10-en_UK.jar (1364883832000) created 2013-04-10 14:26:01,134 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-languages-5.2.10-en_US.jar (1364883832000) created 2013-04-10 14:26:01,164 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-lookandfeel-plugin-5.2.10.jar (1364883874000) created 2013-04-10 14:26:01,232 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-mail-plugin-5.2.21.1.jar (1364883414000) created 2013-04-10 14:26:01,259 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-monitoring-plugin-05.5.4.jar (1364883414000) created 2013-04-10 14:26:01,275 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-my-home-plugin-5.2.10.jar (1364883898000) created 2013-04-10 14:26:01,282 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-oauth-consumer-spi-plugin-5.2.10.jar (1364883852000) created 2013-04-10 14:26:01,292 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-oauth-service-provider-spi-plugin-5.2.10.jar (1364883850000) created 2013-04-10 14:26:01,450 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-project-config-plugin-5.2.10.jar (1364883868000) created 2013-04-10 14:26:01,469 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-quick-edit-plugin-1.0.54.jar (1364883414000) created 2013-04-10 14:26:01,501 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-rest-plugin-5.2.10.jar (1364883864000) created 2013-04-10 14:26:01,519 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-sal-plugin-5.2.10.jar (1364883868000) created 2013-04-10 14:26:01,536 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-share-plugin-5.2.10.jar (1364883900000) created 2013-04-10 14:26:01,545 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-soy-plugin-5.2.10.jar (1364883870000) created 2013-04-10 14:26:01,560 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-tzdetect-plugin-1.6.jar (1364883414000) created 2013-04-10 14:26:01,577 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-user-profile-plugin-1.1.0.jar (1364883414000) created 2013-04-10 14:26:02,278 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-view-issue-plugin-5.2.10.jar (1364883872000) created 2013-04-10 14:26:02,383 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-webhooks-plugin-1.0.8.jar (1364883410000) created 2013-04-10 14:26:02,412 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-welcome-plugin-1.1.34.jar (1364883410000) created 2013-04-10 14:26:02,436 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\json-20070829-1.jar (1364883410000) created 2013-04-10 14:26:02,478 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\mywork-common-plugin-1.1.9.jar (1364883412000) created 2013-04-10 14:26:02,490 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\mywork-jira-provider-plugin-1.1.9.jar (1364883410000) created 2013-04-10 14:26:02,512 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\nekohtml-1.9.12-1.jar (1364883412000) created 2013-04-10 14:26:02,568 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\remoteapps-plugin-0.4.518.3.jar (1364883412000) created 2013-04-10 14:26:02,604 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\rome-1.0.jar (1364883410000) created 2013-04-10 14:26:02,648 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\soy-template-plugin-1.1.3.jar (1364883312000) created 2013-04-10 14:26:02,686 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\stp-3.0.11.jar (1364883410000) created 2013-04-10 14:26:03,093 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-aggregator-plugin-5.2.0.jar (1364883414000) created 2013-04-10 14:26:03,109 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-api-5.2.0.jar (1364883304000) created 2013-04-10 14:26:03,119 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-core-plugin-5.2.0.jar (1364883414000) created 2013-04-10 14:26:03,132 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-inline-actions-plugin-5.2.0.jar (1364883414000) created 2013-04-10 14:26:03,145 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-jira-inline-actions-plugin-5.2.0.jar (1364883414000) created 2013-04-10 14:26:03,558 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-jira-plugin-5.2.0.jar (1364883410000) created 2013-04-10 14:26:03,603 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-spi-5.2.0.jar (1364883304000) created 2013-04-10 14:26:03,618 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-thirdparty-plugin-5.2.0.jar (1364883414000) created 2013-04-10 14:26:03,647 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\workflow-designer-plugin-3.0.0-m14.jar (1364883410000) created 2013-04-10 14:26:49,883 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.jira.rpc.jira-json-rpc-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-header-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-monitoring-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 59 seconds remaining 2013-04-10 14:26:50,959 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-monitoring-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 58 seconds remaining 2013-04-10 14:26:52,680 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 57 seconds remaining 2013-04-10 14:26:53,979 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 55 seconds remaining 2013-04-10 14:26:55,218 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 54 seconds remaining 2013-04-10 14:26:56,285 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 53 seconds remaining 2013-04-10 14:26:57,323 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 52 seconds remaining 2013-04-10 14:26:58,388 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 51 seconds remaining 2013-04-10 14:26:59,396 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 50 seconds remaining 2013-04-10 14:27:00,495 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 49 seconds remaining 2013-04-10 14:27:01,562 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 48 seconds remaining 2013-04-10 14:27:02,637 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 47 seconds remaining 2013-04-10 14:27:04,152 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 45 seconds remaining 2013-04-10 14:27:05,390 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 44 seconds remaining 2013-04-10 14:27:06,600 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 43 seconds remaining 2013-04-10 14:27:07,851 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 42 seconds remaining 2013-04-10 14:27:08,962 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 40 seconds remaining 2013-04-10 14:27:11,260 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 38 seconds remaining 2013-04-10 14:27:12,546 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 37 seconds remaining 2013-04-10 14:27:13,658 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 36 seconds remaining 2013-04-10 14:27:15,043 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 34 seconds remaining 2013-04-10 14:27:16,131 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 33 seconds remaining 2013-04-10 14:27:17,154 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 32 seconds remaining 2013-04-10 14:27:18,299 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 31 seconds remaining 2013-04-10 14:27:19,364 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 30 seconds remaining 2013-04-10 14:27:18,819 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:20,482 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.collector.plugin.jira-issue-collector-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,979 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory) 2013-04-10 14:27:20,979 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory) 2013-04-10 14:27:20,979 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.collector.plugin.jira-issue-collector-plugin org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,980 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,981 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:20,982 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.directory], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.directory' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,983 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.directory' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory) 2013-04-10 14:27:20,983 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.directory org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.directory' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,984 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.directory' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,985 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.opensocial, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:20,986 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.opensocial], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&appLinksService]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.opensocial' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,988 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&appLinksService' for plugin 'com.atlassian.gadgets.opensocial' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService) 2013-04-10 14:27:20,988 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.opensocial org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.opensocial' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,989 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.opensocial, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.opensocial' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,990 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:20,991 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.embedded], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)] (from bean [&securityTokenFactory]), Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.embedded' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,992 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&securityTokenFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.view.SecurityTokenFactory) 2013-04-10 14:27:20,992 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory) 2013-04-10 14:27:20,992 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.embedded org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.embedded' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,992 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.embedded' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:20,993 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:20,550 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 29 seconds remaining 2013-04-10 14:27:21,128 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.oauth.serviceprovider], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.oauth.serviceprovider' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,129 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory) 2013-04-10 14:27:21,129 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory) 2013-04-10 14:27:21,129 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.oauth.serviceprovider org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.oauth.serviceprovider' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,130 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.oauth.serviceprovider' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,176 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.dashboard, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:21,177 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.dashboard], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker)] (from bean [&gadgetSpecUrlChecker]), Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)] (from bean [&renderedGadgetUriBuilder]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.dashboard' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,177 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecUrlChecker' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker) 2013-04-10 14:27:21,178 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory) 2013-04-10 14:27:21,178 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory) 2013-04-10 14:27:21,178 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&renderedGadgetUriBuilder' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder) 2013-04-10 14:27:21,178 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory) 2013-04-10 14:27:21,178 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.dashboard org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.dashboard' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,179 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.dashboard, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.dashboard' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,179 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:21,179 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.gadgets-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.dashboard.DashboardService)] (from bean [&dashboardService]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.gadgets-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,180 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory) 2013-04-10 14:27:21,180 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&dashboardService' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.dashboard.DashboardService) 2013-04-10 14:27:21,180 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory) 2013-04-10 14:27:21,180 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.gadgets org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.gadgets-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,181 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.gadgets-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,181 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-applinks-common-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:21,181 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.issue-link-applinks-common-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.issue-link-applinks-common-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,182 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.jira.jira-issue-link-applinks-common-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService) 2013-04-10 14:27:21,182 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.jira-issue-link-applinks-common-plugin org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.issue-link-applinks-common-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:21,182 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-applinks-common-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.issue-link-applinks-common-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:22,277 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 27 seconds remaining 2013-04-10 14:27:23,525 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 26 seconds remaining 2013-04-10 14:27:25,308 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 24 seconds remaining 2013-04-10 14:27:26,190 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.lookandfeel-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:26,568 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.plugins.atlassian-nav-links-plugin], 23 seconds remaining 2013-04-10 14:27:27,524 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.lookandfeel-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.soy.renderer.SoyTemplateRenderer)] (from bean [&soyTemplateRenderer]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.lookandfeel-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:27,530 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&soyTemplateRenderer' for plugin 'com.atlassian.jira.lookandfeel' with filter (objectClass=com.atlassian.soy.renderer.SoyTemplateRenderer) 2013-04-10 14:27:27,530 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.lookandfeel org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.lookandfeel-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:27,530 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.lookandfeel-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.lookandfeel-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:28,619 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 21 seconds remaining 2013-04-10 14:27:29,824 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 20 seconds remaining 2013-04-10 14:27:30,942 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 18 seconds remaining 2013-04-10 14:27:32,815 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 17 seconds remaining 2013-04-10 14:27:33,924 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 15 seconds remaining 2013-04-10 14:27:35,105 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 14 seconds remaining 2013-04-10 14:27:36,192 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 13 seconds remaining 2013-04-10 14:27:37,518 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.streams, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 12 seconds remaining 2013-04-10 14:27:37,735 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:38,413 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.inline-actions-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)] (from bean [&streamsLocaleProvider]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:38,414 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsLocaleProvider' for plugin 'com.atlassian.streams.actions' with filter (objectClass=com.atlassian.streams.spi.StreamsLocaleProvider) 2013-04-10 14:27:38,414 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.actions org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:38,416 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:38,538 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.streams, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 11 seconds remaining 2013-04-10 14:27:38,610 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:38,611 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.aggregator-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)] (from bean [&formatPreferenceProvider]), Dependency on [(objectClass=com.atlassian.streams.spi.EntityResolver)] (from bean [&entityResolvers]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:38,612 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&formatPreferenceProvider' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.FormatPreferenceProvider) 2013-04-10 14:27:38,612 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityResolvers' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.EntityResolver) 2013-04-10 14:27:38,612 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:38,612 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:39,444 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:39,445 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.thirdparty-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.UserProfileAccessor)] (from bean [&userProfileAccessor]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:39,447 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userProfileAccessor' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.spi.UserProfileAccessor) 2013-04-10 14:27:39,449 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-thirdparty-plugin org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:39,557 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:39,558 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml)] 2013-04-10 14:27:39,559 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.jira-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:39,560 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory) 2013-04-10 14:27:39,561 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory) 2013-04-10 14:27:39,562 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-jira-plugin org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:39,568 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 10 seconds remaining 2013-04-10 14:27:39,614 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) 2013-04-10 14:27:40,794 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 9 seconds remaining 2013-04-10 14:27:41,822 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin], 8 seconds remaining 2013-04-10 14:27:46,884 localhost-startStop-1 INFO [jira.plugins.monitor.MonitoringScheduler] Scheduling metrics collector to run every 10000ms... 2013-04-10 14:27:46,976 localhost-startStop-1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\Program Files\Atlassian\Application Data\JIRA\monitor\ConnectionPoolGraph.rrd4j 2013-04-10 14:27:47,135 localhost-startStop-1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\Program Files\Atlassian\Application Data\JIRA\monitor\DatabaseReadWritesGraph.rrd4j 2013-04-10 14:27:47,137 localhost-startStop-1 INFO [jira.plugins.monitor.MonitorLauncher] Started JIRA monitoring 2013-04-10 14:27:56,931 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] No plugins found to be deployed 2013-04-10 14:27:57,073 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Plugin system started in 0:03:02.258 2013-04-10 14:27:57,277 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] ___ Plugin System Started _________________ 2013-04-10 14:27:58,720 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml 2013-04-10 14:27:58,815 localhost-startStop-1 INFO [jira.instrumentation.external.DatabaseExternalGauges] Installing DBCP monitoring instruments: DatabaseExternalGauges.JiraDbcpInstruments[instruments=[DBCP_MAX, DBCP_ACTIVE, DBCP_IDLE],objectName=com.atlassian.jira:name=BasicDataSource] 2013-04-10 14:28:11,401 localhost-startStop-1 INFO [atlassian.jira.upgrade.ConsistencyCheckImpl] Checking JIRA consistency 2013-04-10 14:28:11,479 localhost-startStop-1 INFO [atlassian.jira.upgrade.ConsistencyCheckImpl] The Server ID for this JIRA instance is: [BGV6-KFMN-LT5P-GTK1] 2013-04-10 14:28:13,394 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] ___ User Directories (Ordered) ______________ INTERNAL : JIRA Internal Directory Implementing Class : com.atlassian.crowd.directory.InternalDirectory Allowed Operations : CREATE_GROUP, CREATE_ROLE, CREATE_USER, DELETE_GROUP, DELETE_ROLE, DELETE_USER, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_ROLE, UPDATE_ROLE_ATTRIBUTE, UPDATE_USER, UPDATE_USER_ATTRIBUTE Encryption Type : atlassian-security Active : true Attributes : user_encryption_method : atlassian-security ___ Core Application Properties ___________ Version : 5.2.10 Build # : 853 Build Date : Tue Apr 02 00:00:00 BST 2013 Installation Type : Standalone Server ID : BGV6-KFMN-LT5P-GTK1 Base URL : http://s8jira:8080 Default Language : English (United Kingdom) External User Management : OFF ___ Application Properties ________________ AO_4AEACD_# : 1 com.atlassian.activeobjects.admin.ActiveObjectsPluginToTablesMapping : null com.atlassian.jira.jira-mail-plugin:build : 1 com.atlassian.jira.lookandfeel.customizeColors : false com.atlassian.jira.lookandfeel.logoChoice : UPLOAD com.atlassian.jira.lookandfeel:build : 1 com.atlassian.jira.lookandfeel:customDefaultFaviconHiresURL : /images/64jira.png com.atlassian.jira.lookandfeel:customDefaultFaviconURL : /favicon.ico com.atlassian.jira.lookandfeel:faviconHeight : 64 com.atlassian.jira.lookandfeel:faviconWidth : 64 com.atlassian.jira.lookandfeel:isDefaultFavicon : false com.atlassian.jira.lookandfeel:usingCustomFavicon : false com.atlassian.jira.lookandfeel:usingCustomLogo : true com.atlassian.jira.plugin.ext.bamboo:build : 1 com.atlassian.jira.plugins.jira-importers-plugin:build : 1 com.atlassian.jira.plugins.jira-workflow-designer:build : 1 com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin:build : 1 com.atlassian.sal.jira:build : 2 com.atlassian.upm.atlassian-universal-plugin-manager-plugin:build : 1 com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR8bdca18bb1b7389d0a2d834a01247d76 : null com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRepository:licenses:plugin.jep : null com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRfdbfad06c2f1036a60cb955d7e285d69 : #java.util.List com.pyxis.greenhopper.jira plugin.jep com.atlassian.upm.log.PluginSettingsAuditLogService:log:upm_audit_log_v2 : null com.atlassian.upm:notifications:dismissal-evaluation.expired : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.expired:com.eazybi.jira.plugins.eazybi-jira : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired:c6186ce90eb33d166f155aaa75fdcff10 : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.expired:com.eazybi.jira.plugins.eazybi-jira : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired:32539fe8238209d3041c0f97a1d95665 : #java.util.List com.atlassian.upm:notifications:dismissal-update : #java.util.List com.atlassian.upm:notifications:dismissal-update:com.eazybi.jira.plugins.eazybi-jira : #java.util.List com.atlassian.upm:notifications:dismissal-user.mismatch:com.eazybi.jira.plugins.eazybi-jira : #java.util.List com.atlassian.upm:notifications:notification-edition.mismatch : #java.util.List com.atlassian.upm:notifications:notification-evaluation.expired : #java.util.List com.atlassian.upm:notifications:notification-evaluation.nearlyexpired : #java.util.List com.atlassian.upm:notifications:notification-maintenance.expired : #java.util.List com.atlassian.upm:notifications:notification-maintenance.nearlyexpired : #java.util.List com.atlassian.upm:notifications:notification-plugin.request : #java.util.List com.atlassian.upm:notifications:notification-update : #java.util.List com.atlassian.upm:notifications:notification-user.mismatch : #java.util.List com.pyxis.greenhopper.jira:build : 24 eazybi.database : #java.util.Map adapter?mysql host?localhost database?eazybi_jira username?root eazybi.license_type : atlassian_marketplace jira.ajax.autocomplete.issuepicker.enabled : true jira.ajax.autocomplete.labelsuggestion.limit : 20 jira.ajax.autocomplete.limit : 20 jira.alertheader.visibility : private jira.assignee.change.is.sent.to.both.parties : true jira.attachment.allow.zip.support : true jira.attachment.do.not.expand.as.zip.extensions.list : docx, docm, dotx, dotm, xlsx, xlsm, xltx, xltm, xlsb, xlam, pptx, pptm, potx, potm, ppam, ppsx, ppsm, sldx, sldm, thmx, odt, odp, ods, odg, odb, odf, ott, otp, ots, otg, odm, sxw, stw, sxc, stc, sxi, sti, sxd, std, sxg jira.attachment.download.mime.sniffing.workaround : workaround jira.attachment.number.of.zip.entries : 30 jira.autoexport : true jira.avatar.default.id : 10011 jira.avatar.megapixels : 10 jira.avatar.user.anonymous.id : 10123 jira.avatar.user.default.id : 10122 jira.baseurl : http://s8jira:8080 jira.browser.unsupported.warnings.disabled : false jira.bulk.edit.limit.issue.count : 1000 jira.chart.days.previous.limit.daily : 300 jira.chart.days.previous.limit.hourly : 10 jira.chart.days.previous.limit.monthly : 7500 jira.chart.days.previous.limit.quarterly : 22500 jira.chart.days.previous.limit.weekly : 1750 jira.chart.days.previous.limit.yearly : 36500 jira.clone.linktype.name : Cloners jira.clone.prefix : CLONE - jira.comment.level.visibility.groups : false jira.constant.default.resolution : 1 jira.contact.administrators.message : null jira.dashboard.max.gadgets : 20 jira.databasequery.batch.size : 100 jira.date.picker.java.format : d/MMM/yy jira.date.picker.javascript.format : %e/%b/%y jira.date.time.picker.java.format : dd/MMM/yy h:mm a jira.date.time.picker.javascript.format : %e/%b/%y %I:%M %p jira.date.time.picker.use.iso8061 : false jira.db.txns.disabled : false jira.default.jndi.name : java:comp/env/jdbc/JiraDS jira.disable.login.gadget : false jira.disable.multipart.get.http.request : true jira.edition : enterprise jira.email.fromheader.format : ${fullname} (JIRA) jira.enabled.dark.features : jira.export.fetchsize : -1 jira.exportimport.cleanxml : true jira.home : jira.i18n.include.meta-data : true jira.i18n.language.index : english jira.import.maxqueuesize : 100 jira.import.threads : 10 jira.index.background.batch.size : 1000 jira.index.batch.maxbuffereddocs : 300 jira.index.batch.maxmergedocs : 2147483647 jira.index.batch.mergefactor : 50 jira.index.interactive.maxbuffereddocs : 300 jira.index.interactive.maxmergedocs : 2147483647 jira.index.interactive.mergefactor : 4 jira.index.issue.maxqueuesize : 1000 jira.index.issue.minbatchsize : 50 jira.index.issue.threads : 10 jira.index.lock.waittime : 30000 jira.index.max.reindexes : 2147483647 jira.index.maxfieldlength : 10000 jira.index.mergepolicy.expungedeletespctallowed : 10 jira.index.mergepolicy.floorsegmentmb : 2 jira.index.mergepolicy.maxmergeatonce : 10 jira.index.mergepolicy.maxmergeatonceexplicit : 30 jira.index.mergepolicy.maxmergedsegmentmb : 512 jira.index.mergepolicy.nocfspct : 10 jira.index.mergepolicy.segmentspertier : 10 jira.index.mergepolicy.usecompoundfile : true jira.index.sharedentity.maxqueuesize : 1000 jira.index.sharedentity.minbatchsize : 50 jira.index.sharedentity.threads : 10 jira.index.update.bulk.optimization : 400 jira.issue.actions.order : asc jira.issue.inline.edit.disabled : false jira.issueindex.fetch.size : 200 jira.issuenav.criteria.autoupdate : true jira.jql.autocomplete.disabled : false jira.lf.application.id : jira jira.lf.date.complete : dd/MMM/yy h:mm a jira.lf.date.day : EEEE h:mm a jira.lf.date.dmy : dd/MMM/yy jira.lf.date.relativize : true jira.lf.date.time : h:mm a jira.lf.favicon.hires.url : /images/64jira.png jira.lf.favicon.url : /favicon.ico jira.lf.gadget.color1 : #369 jira.lf.gadget.color2 : #900925 jira.lf.gadget.color3 : #d94625 jira.lf.gadget.color4 : #346006 jira.lf.gadget.color5 : #003366 jira.lf.gadget.color6 : #411E66 jira.lf.gadget.color7 : #bbb jira.lf.hero.button.base.bg.colour : #3b7fc4 jira.lf.hero.button.text.colour : #ffffff jira.lf.logo.height : 47 jira.lf.logo.show.application.title : false jira.lf.logo.url : /jira-logo-scaled.png jira.lf.logo.width : 142 jira.lf.menu.bgcolour : #326ca6 jira.lf.menu.separator : #f0f0f0 jira.lf.menu.textcolour : #ffffff jira.lf.text.activelinkcolour : #326ca6 jira.lf.text.headingcolour : #292929 jira.lf.text.linkcolour : #326ca6 jira.lf.top.bgcolour : #205081 jira.lf.top.hilightcolour : #296CA3 jira.lf.top.separator.bgcolor : #2E3D54 jira.lf.top.textcolour : #ffffff jira.lf.top.texthilightcolour : #f0f0f0 jira.mail.fetch.disabled : false jira.mail.send.disabled : true jira.max.AdminPage.history.items : 5 jira.max.Issue.history.items : 50 jira.max.JQLQuery.history.items : 10 jira.max.history.items : 10 jira.max.issue.filter.dropdown.items : 10 jira.max.issue.history.dropdown.items : 6 jira.maximum.authentication.attempts.allowed : 3 jira.mode : public jira.option.allowattachments : true jira.option.allowcookies : true jira.option.allowsubtasks : true jira.option.allowthumbnails : true jira.option.allowunassigned : true jira.option.captcha.on.signup : false jira.option.emailvisible : show jira.option.ignore.url.with.key : true jira.option.indexing : true jira.option.issuelinking : true jira.option.logoutconfirm : never jira.option.precedence.header.exclude : false jira.option.rpc.allow : true jira.option.timetracking : true jira.option.user.externalmanagement : false jira.option.voting : true jira.option.watching : true jira.option.web.usegzip : true jira.path.attachments : C:\Program Files\Atlassian\Application Data\JIRA\data\attachments jira.path.attachments.use.default.directory : true jira.path.backup : C:\Program Files\Atlassian\Application Data\JIRA\export jira.path.index.use.default.directory : true jira.plugin.state-.com.atlassian.jira.welcome.jira-welcome-plugin:show-whats-new-flag : true jira.project.summary.max.issues : 3 jira.projectkey.description : admin.projects.key.description jira.projectkey.pattern : ([A-Z][A-Z]+) jira.projectkey.reservedwords.list : PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7, COM8, COM9, CON, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, LPT9 jira.projectkey.warning : admin.errors.must.specify.unique.project.key jira.releasenotes.default : Html jira.releasenotes.templatenames : Html, Text jira.releasenotes.templates : releasenotes-html.vm, releasenotes-text.vm jira.scheme.default.issue.type : 10000 jira.schemes.comparison.max : 5 jira.screenshotapplet.enabled : true jira.screenshotapplet.linux.enabled : false jira.search.fullcontentview.pagebreaks : true jira.search.maxclauses : 65000 jira.search.views.default.max : 1000 jira.search.views.max.limit : 1000 jira.search.views.max.unlimited.group : jira.sendmail.recipient.batch.size : 100 jira.setup : true jira.show.contact.administrators.form : false jira.subscription.email.max.issues : 200 jira.table.cols.dashboard : issuetype, issuekey, summary, priority jira.table.cols.subtasks : issuetype, status, assignee, progress jira.table.cols.voted : issuetype, issuekey, summary, priority, status jira.table.cols.watched : issuetype, issuekey, summary, priority, status jira.table.gadget.max.rows : 50 jira.text.field.character.limit : 0 jira.thumbnail.maxheight : 200 jira.thumbnail.maxwidth : 200 jira.timetracking.copy.comment.to.work.desc.on.transition : true jira.timetracking.days.per.week : 5 jira.timetracking.default.unit : MINUTE jira.timetracking.estimates.legacy.behaviour : false jira.timetracking.format : pretty jira.timetracking.hours.per.day : 8 jira.title : SIMUL8 JIRA jira.trustedapp.key.private.data : null jira.trustedapp.key.public.data : null jira.trustedapp.uid : jira:7959625 jira.trustedapps.timeout.default : 10000 jira.trustedapps.urlmatch.default : /sr/jira.issueviews:searchrequest /secure/RunPortlet /rest /rpc/soap /plugins/servlet/streams /plugins/servlet/applinks jira.user.avatar.gravatar.enabled : false jira.usermanagement.maxdisplaymembers : 200 jira.version.patched : 853 jira.view.issue.links.sort.order : type, status, priority jira.view.issue.show.quicksubtask.when.no.subtasks : false jira.viewcvs.root.type : cvsroot jira.webresource.flushcounter : 4 jira.webresource.superbatch.flushcounter : 1 jira.websudo.is.disabled : false jira.websudo.timeout : 10 jira.whitelist.disabled : false jira.whitelist.rules : null jira.xsrf.enabled : true notification.instance.upgrade.date : 1365590264507 remoteapps.lastVersion.remoteapps : 0.4.518.3 remoteapps.lastVersion.server : 853 show.plugin.marketing.hints : true user.default.share.private : true user.issues.per.page : 50 user.keyboard.shortcuts.disabled : false user.notifications.mimetype : html user.notify.own.changes : false user.show.actions.in.navigator : true webwork.i18n.encoding : UTF-8 webwork.multipart.maxSize : 10485760 ___ License Details _______________________ License Set : true Entitled To Support : true Evaluation : false Description : JIRA 10 Users: Starter License SEN : SEN-2387720 Organisation : SIMUL8 Corporation Partner : Maximum Number Of Users : 10 ___ Database Statistics ___________________ Issues : 448 Projects : 6 Custom Fields : 12 Workflows : 8 Users : 10 Groups : 3 Attachments : 62 Comments : 173 ___ Upgrade History _______________________ 5.2.10#853 Time Performed : 2013-04-10 11:37:45.0 Original Version : 5.1.6#785 5.1.6#785 Time Performed : 2012-10-16 16:19:52.0 ___ File Paths ____________________________ JIRA Home : C:\Program Files\Atlassian\Application Data\JIRA Location of atlassian-jira.log : C:\Program Files\Atlassian\Application Data\JIRA\log\atlassian-jira.log Index Path : C:\Program Files\Atlassian\Application Data\JIRA\caches\indexes Attachment Path : C:\Program Files\Atlassian\Application Data\JIRA\data\attachments ___ User Plugins ____________________________ Number : 0 ___ System Plugins __________________________ Number : 98 ActiveObjects Plugin - OSGi Bundle : com.atlassian.activeobjects.activeobjects-plugin Version : 0.19.16 Status : enabled Vendor : Atlassian Description : An OSGi bundle that provides a service that allows plugins to persist objects using the ActiveObjects framework Apache HttpClient OSGi bundle : org.apache.httpcomponents.httpclient-4.0 Version : 4.0 Status : enabled Vendor : Apache Software Foundation Description : HttpComponents Client (OSGi bundle) Apache HttpCore OSGi bundle : org.apache.httpcomponents.httpcore-4.0 Version : 4.0 Status : enabled Vendor : Apache Software Foundation Description : HttpComponents Core (OSGi bundle) Applinks Product Plugin : com.atlassian.applinks.applinks-plugin Version : 3.10.4 Status : enabled Vendor : Atlassian Description : Plugin that facilitates discovery, connections and authentication with remote applications Atlassian - Administration - Quick Search - JIRA : com.atlassian.administration.atlassian-admin-quicksearch-jira Version : 1.1.1 Status : enabled Vendor : Atlassian Description : Administration Quick Search plugin for JIRA Atlassian Bot Session Killer : com.atlassian.labs.atlassian-bot-killer Version : 1.7.2.1 Status : enabled Vendor : Atlassian Description : This will remove unwanted http sessions for requests that exhibit Bot like behaviour. That is they make a single request, don't preserve cookies and never call again. Atlassian Custom Apps Plugin : com.atlassian.plugins.atlassian-custom-apps-plugin Version : 1.15 Status : enabled Vendor : Atlassian Description : Create and edit custom applications shown in the application switcher. Atlassian Embedded Crowd - Administration Plugin : com.atlassian.crowd.embedded.admin Version : 1.4.5 Status : enabled Vendor : Atlassian Description : Provides the administration of local and remote user directories. Atlassian Gadgets OAuth Service Provider Plugin : com.atlassian.gadgets.oauth.serviceprovider Version : 3.2.0-m2-1 Status : disabled Vendor : Atlassian Description : Plugin that makes OAuth Service Providers Gadget aware. Atlassian JIRA - Admin Helper Plugin : com.atlassian.jira.plugins.jira-admin-helper-plugin Version : 1.6 Status : enabled Vendor : Atlassian Pty Ltd Description : The Admin Helper plugin helps admins determine visibility of custom fields and also provides reasons for why a user does not have certain permissions on an issue or does not receive notifications for that issue. Atlassian JIRA - Plugins - Admin Summary Component : com.atlassian.jira.jira-admin-summary-plugin Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Supplies Content to the JIRA Administration Summary Page Atlassian JIRA - Plugins - Application Properties : com.atlassian.jira.jira-application-properties-plugin Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Provides advanced application properties configuration Atlassian JIRA - Plugins - Closure Template Renderer : com.atlassian.jira.jira-soy-plugin Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Provides renderer for Closure templates Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin : com.atlassian.jira.jira-issue-link-applinks-common-plugin Version : 5.2.10 Status : disabled Vendor : ${project.organization.name} Description : Provides the common utilities for AppLinks based issue link plugins Atlassian JIRA - Plugins - Confluence Link : com.atlassian.jira.jira-issue-link-confluence-plugin Version : 5.2.10 Status : enabled Vendor : ${project.organization.name} Description : Provides creation and rendering of issue links to Confluence pages Atlassian JIRA - Plugins - Gadgets Plugin : com.atlassian.jira.gadgets Version : 5.2.10 Status : disabled Vendor : Atlassian Description : Provides Gadgets and REST endpoints bundled with JIRA Atlassian JIRA - Plugins - Header Plugin : com.atlassian.jira.jira-header-plugin Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Provides markup/styles/behaviour/plugin points for the header Atlassian JIRA - Plugins - Invite User : com.atlassian.jira.jira-invite-user-plugin Version : 1.6 Status : enabled Vendor : Atlassian Description : Allows administrators to invite users to sign up for an account Atlassian JIRA - Plugins - Issue Navigation : com.atlassian.jira.jira-issue-nav-plugin Version : 1.1.25.21 Status : enabled Vendor : Atlassian Description : Provides issue search and navigation Atlassian JIRA - Plugins - Issue Web Link : com.atlassian.jira.jira-issue-link-web-plugin Version : 5.2.10 Status : enabled Vendor : ${project.organization.name} Description : Provides creation and rendering of issue links to web pages Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin : com.atlassian.jira.lookandfeel Version : 5.2.10 Status : disabled Vendor : Atlassian Description : Provides logo upload capabilities Atlassian JIRA - Plugins - Mail Plugin : com.atlassian.jira.jira-mail-plugin Version : 5.2.21.1 Status : enabled Vendor : Atlassian Description : Handles incoming and outgoing mail Atlassian JIRA - Plugins - My JIRA Home : com.atlassian.jira.jira-my-home-plugin Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Lets the user pick a landing page. Atlassian JIRA - Plugins - OAuth Consumer SPI : com.atlassian.jira.oauth.consumer Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Provides the Consumer SPI implementation required for OAuth in JIRA. Atlassian JIRA - Plugins - OAuth Service Provider SPI : com.atlassian.jira.oauth.serviceprovider Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Provides the OAuth Service Provider SPI implementation required for OAuth in JIRA. Atlassian JIRA - Plugins - Project Config Plugin : com.atlassian.jira.jira-project-config-plugin Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Provides easier project administration with JIRA Atlassian JIRA - Plugins - Quick Edit Plugin : com.atlassian.jira.jira-quick-edit-plugin Version : 1.0.54 Status : enabled Vendor : Atlassian Description : This is the com.atlassian.jira:jira-quick-edit-plugin plugin for Atlassian JIRA. Atlassian JIRA - Plugins - REST Plugin : com.atlassian.jira.rest Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Provides a REST interface for JIRA Atlassian JIRA - Plugins - Remote JIRA Link : com.atlassian.jira.jira-issue-link-remote-jira-plugin Version : 5.2.10 Status : enabled Vendor : ${project.organization.name} Description : Provides creation and rendering of links to local and remote JIRA issues Atlassian JIRA - Plugins - SAL Plugin : com.atlassian.sal.jira Version : 5.2.10 Status : enabled Vendor : Atlassian Software Systems Description : JIRA implementation of the Shared Application Access Layer (SAL) Atlassian JIRA - Plugins - Share Content Component : com.atlassian.jira.jira-share-plugin Version : 5.2.10 Status : enabled Vendor : Atlassian Description : Allows users to share issue and searches Atlassian JIRA - Plugins - User Profile Plugin : com.atlassian.jira.jira-user-profile-plugin Version : 1.1.0 Status : enabled Vendor : Atlassian Description : Plugin uses web-panels to encapsulate details and preferences modules from user profile page. Atlassian JIRA - Plugins - View Issue Panels : com.atlassian.jira.jira-view-issue-plugin Version : 5.2.10 Status : enabled Vendor : ${project.organization.name} Description : Provides WebPanels for the View Issue Page Atlassian Navigation Links Plugin : com.atlassian.plugins.atlassian-nav-links-plugin Version : 1.3.16 Status : enabled Vendor : Atlassian Description : Capabilities and Navigation API client and server implementation Atlassian OAuth Admin Plugin : com.atlassian.oauth.admin Version : 1.6.1 Status : enabled Vendor : Atlassian Description : Plugin that provides a single tabbed view for administering OAuth consumers and service provider information. Atlassian OAuth Consumer Plugin : com.atlassian.oauth.consumer Version : 1.6.1 Status : enabled Vendor : Atlassian Description : Plugin that makes it possible for applications to become Consumers. Atlassian OAuth Consumer SPI : com.atlassian.oauth.atlassian-oauth-consumer-spi-1.6.1 Version : 1.6.1 Status : enabled Vendor : Atlassian Description : Consumer SPIs to allow applications to provide custom implementations of storing token and consumer info Atlassian OAuth Service Provider Plugin : com.atlassian.oauth.serviceprovider Version : 1.6.1 Status : enabled Vendor : Atlassian Description : Plugin that makes it possible for applications to become Service Providers. Atlassian OAuth Service Provider SPI : com.atlassian.oauth.atlassian-oauth-service-provider-spi-1.6.1 Version : 1.6.1 Status : enabled Vendor : Atlassian Description : Service Provider SPIs to allow applications to provide custom implementations of storing token consumer info Atlassian REST - Module Types : com.atlassian.plugins.rest.atlassian-rest-module Version : 2.7.1 Status : enabled Vendor : Atlassian Description : A plugin that contains REST module types Atlassian Remote Apps - Plugin : com.atlassian.labs.remoteapps-plugin Version : 0.4.518.3 Status : enabled Vendor : Atlassian Description : This is the parent for the Atlassian Remote Apps project Atlassian Soy Templates - Plugin : com.atlassian.soy.soy-template-plugin Version : 1.1.3 Status : enabled Vendor : Atlassian Description : Base POM for Atlassian projects Atlassian Template Renderer API : com.atlassian.templaterenderer.api Version : 1.4.2.2 Status : enabled Vendor : Atlassian Description : API and plugins for easily rendering content from different template engines. Atlassian Template Renderer Velocity 1.6 Plugin : com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin Version : 1.4.2.2 Status : enabled Vendor : Atlassian Description : API and plugins for easily rendering content from different template engines. Atlassian UI Plugin : com.atlassian.auiplugin Version : 5.0-m10 Status : enabled Vendor : Atlassian Description : An Atlassian plugin that contains the core javascript files used in Atlassian products. Atlassian Universal Plugin Manager Plugin : com.atlassian.upm.atlassian-universal-plugin-manager-plugin Version : 2.7.10 Status : enabled Vendor : Atlassian Description : This is the plugin that provides the Atlassian Universal Plugin Manager. Crowd REST API : crowd-rest-application-management Version : 1.0 Status : enabled Vendor : Atlassian Software Systems Description : Crowd REST API - Application Management Crowd REST API : crowd-rest-plugin Version : 1.0 Status : enabled Vendor : Atlassian Software Systems Description : Crowd REST API Crowd System Password Encoders : crowd.system.passwordencoders Version : 1.0 Status : enabled Vendor : Atlassian Software Systems Description : Crowd Password Encoders shipped with Crowd Embedded Gadgets Plugin : com.atlassian.gadgets.embedded Version : 3.2.0-m2-1 Status : disabled Vendor : Atlassian Description : Plugin which allows gadgets to be embedded in pages English (United Kingdom) Language Pack : com.atlassian.jira.jira-languages.en_UK Version : 5.2.10 Status : enabled Vendor : Atlassian Description : This plugin contains translations the core keys in JIRA for English (United Kingdom). English (United States) Language Pack : com.atlassian.jira.jira-languages.en_US Version : 5.2.10 Status : enabled Vendor : Atlassian Description : This plugin contains translations the core keys in JIRA for English (United States). FishEye Plugin : com.atlassian.jirafisheyeplugin Version : 5.2.9 Status : enabled Vendor : Atlassian Software Systems Description : JIRA Fisheye Plugin Gadget Dashboard Plugin : com.atlassian.gadgets.dashboard Version : 3.2.0-m2-1 Status : disabled Vendor : Atlassian Description : Plugin which renders a dashboard of gadgets Gadget Directory Plugin : com.atlassian.gadgets.directory Version : 3.2.0-m2-1 Status : disabled Vendor : Atlassian Description : Plugin which renders a directory of gadgets Gadget Spec Publisher Plugin : com.atlassian.gadgets.publisher Version : 3.2.0-m2-1 Status : enabled Vendor : Atlassian Description : Plugin which provides a way to publish gadget specs found in plugins HipChat : com.atlassian.labs.hipchat.hipchat-for-jira-plugin Version : 1.1.13 Status : enabled Vendor : Atlassian Description : This is the HipChat plugin for JIRA. ICU4J : com.atlassian.bundles.icu4j-3.8.0.1 Version : 3.8.0.1 Status : enabled Vendor : Atlassian Pty Ltd Description : ICU4J as an OSGi bundle JDOM DOM Processor : com.springsource.org.jdom-1.0.0 Version : 1.0.0 Status : enabled Vendor : SpringSource Description : JIRA Active Objects SPI implementation : com.atlassian.activeobjects.jira.spi Version : 0.19.16 Status : enabled Vendor : Atlassian Software Systems Description : A plugin that provides the DataSourceProvider service JIRA Activity Stream Plugin : com.atlassian.streams.streams-jira-plugin Version : 5.2.0 Status : disabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. JIRA Bamboo Plugin : com.atlassian.jira.plugin.ext.bamboo Version : 5.2.1 Status : enabled Vendor : Atlassian Software Systems Pty Ltd Description : Allows you to see builds and telemetry from a remote Bamboo server JIRA Base URL Plugin : com.atlassian.jira.jira-baseurl-plugin Version : 1.9 Status : enabled Vendor : Atlassian Description : Detects incorrectly-set base URLs in JIRA. JIRA French (France) Language Pack : tac.jira.languages.fr_FR Version : 5.2.8-v2r2373-2013-03-15 Status : enabled Vendor : Atlassian Community Description : This plugin contains translations for fr_FR JIRA German (Germany) Language Pack : tac.jira.languages.de_DE Version : 5.2.8-v2r5721-2013-03-15 Status : enabled Vendor : Atlassian Community Description : This plugin contains translations for de_DE JIRA Importers Plugin (JIM) : com.atlassian.jira.plugins.jira-importers-plugin Version : 5.0.3 Status : enabled Vendor : Atlassian Description : A plugin (originally part of JIRA 4.2 and older) which provides capability to import to JIRA issues from 3rd party issue trackers: Bugzilla, FogBugz and Mantis. JIRA Issue Collector Plugin : com.atlassian.jira.collector.plugin.jira-issue-collector-plugin Version : 1.2.9 Status : disabled Vendor : Atlassian Description : This plugin provides the ability to create issues from remote applications JIRA JSON-RPC Plugin : com.atlassian.jira.rpc.jira-json-rpc-plugin Version : 1.0.4 Status : enabled Vendor : Atlassian Software Description : Exposes JIRA SOAP services using JSON-RPC JIRA Japanese (Japan) Language Pack : tac.jira.languages.ja_JP Version : 5.2.8-v2r15554-2013-03-18 Status : enabled Vendor : Atlassian Community Description : This plugin contains translations for ja_JP JIRA Monitoring Plugin : com.atlassian.jira.jira-monitoring-plugin Version : 05.5.4 Status : enabled Vendor : Atlassian Description : Records and exposes JIRA key performance metrics JIRA Spanish (Spain) Language Pack : tac.jira.languages.es_ES Version : 5.2.8-v2r12795-2013-03-15 Status : enabled Vendor : Atlassian Community Description : This plugin contains translations for es_ES JIRA Streams Inline Actions Plugin : com.atlassian.streams.jira.inlineactions Version : 5.2.0 Status : enabled Vendor : Atlassian Software Systems Pty Ltd Description : JIRA Streams Inline Actions Plugin JIRA Time Zone Detection plugin : com.atlassian.jira.jira-tzdetect-plugin Version : 1.6 Status : enabled Vendor : Atlassian Description : Performs client-side time zone detection for JIRA. JIRA Usage Hints : jira.usage.hints Version : 1.0 Status : enabled Vendor : Atlassian Description : This library includes the web fragments for JIRA usage hints displayed on issue operation dialogs. It should never be disabled. JIRA WebHooks Plugin : com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin Version : 1.0.8 Status : enabled Vendor : Atlassian Description : This plugin provides the ability to register Web Hooks for events in JIRA JIRA Welcome Plugin : com.atlassian.jira.welcome.jira-welcome-plugin Version : 1.1.34 Status : enabled Vendor : Atlassian Description : Displays a welcome dialog for first-time usage of JIRA, as well as a whats new dialog for users just having upgraded to this version of JIRA. JIRA iCalendar Plugin : com.atlassian.jira.extra.jira-ical-feed Version : 1.0.12 Status : enabled Vendor : Atlassian Description : Provides an iCal feed of JIRA issues and versions JQL Functions : jira.jql.function Version : 1.0 Status : enabled Vendor : Atlassian Description : This plugin implements a JQL function in JIRA. JSON Library : com.atlassian.bundles.json-20070829.0.0.1 Version : 20070829.0.0.1 Status : enabled Vendor : Atlassian Pty Ltd Description : Library for manipulating JSON Keyboard Shortcuts Plugin : jira.keyboard.shortcuts Version : 1.0 Status : enabled Vendor : Atlassian Description : A plugin that defines a number of keyboard shortcuts. Neko HTML : com.atlassian.bundles.nekohtml-1.9.12.1 Version : 1.9.12.1 Status : enabled Vendor : Atlassian Pty Ltd Description : Neko HTML library as an OSGi bundle Notifications and Tasks - Common Plugin : com.atlassian.mywork.mywork-common-plugin Version : 1.1.9 Status : enabled Vendor : Atlassian Description : Provides Common Services to Notifications and Tasks Notifications and Tasks - JIRA Provider Plugin : com.atlassian.mywork.mywork-jira-provider-plugin Version : 1.1.9 Status : enabled Vendor : Atlassian Description : Generates Notifications and Tasks from JIRA Opensocial Plugin : com.atlassian.gadgets.opensocial Version : 3.2.0-m2-1 Status : disabled Vendor : Atlassian Description : Plugin for OpenSocial API Support and Gadget Rendering ROME, RSS and atOM utilitiEs for Java : rome.rome-1.0 Version : 1.0 Status : enabled Vendor : Sun Microsystems Description : All Roads Lead to ROME. ROME is a set of Atom/RSS Java utilities that make it easy to work in Java with most syndication formats. Today it accepts all flavors of RSS (0.90, 0.91, 0.92, 0.93, 0.94, 1.0 and 2.0), Atom 0.3 and Atom 1.0 feeds. Rome includes a set of parsers and generators for the various flavors of feeds, as well as converters to convert from one format to another. The parsers can give you back Java objects that are either specific for the format you want to work with, or a generic normalized SyndFeed object that lets you work on with the data without bothering about the underlying format. ROME: RSS/Atom syndication and publishing tools : com.springsource.com.sun.syndication-0.9.0 Version : 0.9.0 Status : enabled Vendor : SpringSource Description : RPC JIRA Plugin : com.atlassian.jira.ext.rpc Version : 5.1.3 Status : enabled Vendor : Atlassian Description : The standard JIRA RPC services, both SOAP and XML-RPC. Streams API : com.atlassian.streams.streams-api-5.2.0 Version : 5.2.0 Status : enabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. Streams Core Plugin : com.atlassian.streams.core Version : 5.2.0 Status : enabled Vendor : Atlassian Software Systems Pty Ltd Description : Streams Core Plugin Streams Inline Actions Plugin : com.atlassian.streams.actions Version : 5.2.0 Status : disabled Vendor : Atlassian Software Systems Pty Ltd Description : Streams Inline Actions Plugin Streams Plugin : com.atlassian.streams Version : 5.2.0 Status : disabled Vendor : Atlassian Software Systems Pty Ltd Description : Streams Plugin Streams SPI : com.atlassian.streams.streams-spi-5.2.0 Version : 5.2.0 Status : enabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. Streams Third Party Provider Plugin : com.atlassian.streams.streams-thirdparty-plugin Version : 5.2.0 Status : disabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. Support Tools Plugin : com.atlassian.support.stp Version : 3.0.11 Status : enabled Vendor : Atlassian Support Description : This is the Support Tools Plugin, developed to help Atlassian customers with our products. User Format : jira.user.format Version : 1.0 Status : enabled Vendor : Atlassian Description : This plugin renders a user in JIRA. User Profile Panels : jira.user.profile.panels Version : 1.0 Status : enabled Vendor : Atlassian Description : This library includes the panels included on the user profile page. Workflow Designer Plugin : com.atlassian.jira.plugins.jira-workflow-designer Version : 3.0.0-m14 Status : enabled Vendor : Atlassian Description : The visual way to edit JIRA Workflows. jira-help-tips : com.atlassian.plugins.helptips.jira-help-tips Version : 0.29 Status : enabled Vendor : Atlassian Description : Common way to display help tips in the UI of JIRA. ___ Listeners _____________________________ Instance Count : 3 Mail Listener : com.atlassian.jira.event.listeners.mail.MailListener Issue Assignment Listener : com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener Issue Index Listener : com.atlassian.jira.event.listeners.search.IssueIndexListener ___ Services ______________________________ Instance Count : 5 Backup Service : com.atlassian.jira.service.services.export.ExportService Service Delay : 43200000ms USE_DEFAULT_DIRECTORY : true Mail Queue Service : com.atlassian.jira.service.services.mail.MailQueueService Service Delay : 60000ms Service Provider Session Remover : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 28799997ms com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 60000ms com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 300000ms ___ Trusted Applications __________________ Instance Count : 0 ___ Java Class Paths ______________________ sun.boot.class.path : C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\resources.jar; C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\rt.jar; C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\sunrsasign.jar; C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\jsse.jar; C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\jce.jar; C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\charsets.jar; C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\modules\jdk.boot.jar; C:\PROGRA~1\ATLASS~1\JIRA\jre\classes java.library.path : C:\Program Files\Atlassian\JIRA\bin; C:\Windows\Sun\Java\bin; C:\Windows\system32; C:\Windows; C:\Windows\system32; C:\Windows; C:\Windows\System32\Wbem; C:\Windows\System32\WindowsPowerShell\v1.0\; ; . java.endorsed.dirs : C:\Program Files\Atlassian\JIRA\endorsed java.ext.dirs : C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\ext; C:\Windows\Sun\Java\lib\ext java.class.path : C:\Program Files\Atlassian\JIRA\bin\bootstrap.jar; C:\Program Files\Atlassian\JIRA\bin\tomcat-juli.jar; C:\Program Files\Atlassian\JIRA\bin\tomcat-juli.jar 2013-04-10 14:28:13,410 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] ********************************************************************************* JIRA 5.2.10 build: 853 started. You can now access JIRA through your web browser. ********************************************************************************* 2013-04-10 14:28:13,661 localhost-startStop-1 WARN [atlassian.jira.startup.JiraStartupLogger] ******************************************************************************************************************************************************************************************************** WARNING: The system property 'mail.mime.decodeparameters' is not set to true. This may result in e-mail attachments with non-Latin filenames being dropped. For more information please see https://docs.atlassian.com/jira/docs-052/__setting_mail.mime.decodeparameters. ******************************************************************************************************************************************************************************************************** 2013-04-10 14:28:13,692 localhost-startStop-1 FATAL [atlassian.jira.startup.JiraStartupLogger] ******************************************************************************************************************************************************************************************************** The following plugins are required by JIRA, but have not been started: Embedded Gadgets Plugin (com.atlassian.gadgets.embedded), Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard), Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin (com.atlassian.jira.lookandfeel), Opensocial Plugin (com.atlassian.gadgets.opensocial), Gadget Directory Plugin (com.atlassian.gadgets.directory), Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets) ******************************************************************************************************************************************************************************************************** 2013-04-10 14:28:13,692 localhost-startStop-1 FATAL [atlassian.jira.upgrade.UpgradeLauncher] Skipping, JIRA is locked. 2013-04-10 14:28:13,755 localhost-startStop-1 INFO [atlassian.jira.startup.NotificationInstanceKiller] Not deleting NotificationInstance table yet, will delete on first startup after Wed May 08 11:37:44 BST 2013 2013-04-10 14:28:13,755 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler not started: JIRA startup checklist failed. 2013-04-10 14:28:14,179 localhost-startStop-1 ERROR [jira.web.dispatcher.JiraWebworkActionDispatcher] ****************************************** JIRA startup failed, JIRA has been locked. ****************************************** 2013-04-10 14:28:29,339 Modification Check:thread-1 INFO [atlassian.jira.startup.JiraStartupLogger] ___ Modifications ___________________________ Modified Files : jira-application.properties Removed Files : None
Yes, the JVM is supported. I was able to troubleshoot the issue and here are my findings.
The option JVM_SUPPORT_RECOMMENDED_ARGS="-Datlassian.plugins.enable.wait=300"
is simply to tell the application, i.e. JIRA, how much time to wait for loading the plugins, but each plugin seems to have an internal non cofigurable timeout of 60 sec. This means that even though I'd put a crazy high plugins.enable.wait time, let's say 2hrs, the start-up will keep failing due to the time out of each of the plugins.
For us the issue was that we were trying to install JIRA into a m1.small instance in AWS. As you guys probably know, this type of instances do not have i) access to much bandwidth inside AWS and ii) CPU and RAM resources. I did some profiling and noticed that the bottleneck was the I/O wait for the EBS volume that at the end of the day keeps being a remote hard disk for the VM.
Anyways, the fix was simple, just move to a m1.medium instance and everything worked like a charm. So, I would recommend not installing JIRA neither on m1.micro or m1.small, they are simply too small for JIRA.
Exactly the same thing is currently happening to me. My set up is JIRA 6.1.2 on an EC2 instance m1.small with Xmx1024m and Xms1024 and XX:MaxPermSize:512m
I also increased the timeout in setenv.sh using
Scott, check out the following guides, that have a bit more info on this error and the possible culprits:
I hope this helps! :)
I'd followed all but one of these tips, which was to increase the JVM memory, but unfortunately that hasn't changed anything!
Could you try to increase the memory then (try setting it to Xmx1024 Xms512)? Also, how was the disk speed test?
what is the best solution for this issue?
Had the same issue on a on premise VM which had only 512Mb of RAM (Linux Debian Wheezy).
Upgraded it to 1024Mb and it rolls...
@GorkaI am having the same problem as you did you manage to get it working?
In my instance addind -Datlassian.plugins.enable.wait=300 to JVM_EXTRA_ARGS in /opt/atlassian/jira/bin/setenv.sh fixed it.
It is important a supported JVM. By the way, we move our JIRA instance to a AWS m1.medium instance and everything worked. Do you still have the problem?
I got the same error when trying to start JIRA using an unsupported JVM. Check if the JVM you are using is supported by your version of JIRA.
Do you have anti-virus application running? Try to disable it and restart JIRA
Nope, it's a completely fresh Windows 7 VM I've launched purely for running JIRA on so we can access over VPN. Stumped!
