JIRA Startup Failed : Plugins are required by JIRA, but have not been started.
Scott Thomson April 9, 2013
Having trouble getting JIRA to start up again after stopping / starting the service on Windows. Getting the following message:
JIRA Startup Failed
You cannot access JIRA at present. Look at the table below to identify the reasons
Description
The following plugins are required by JIRA, but have not been started:
  • Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)
  • Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
  • Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin (com.atlassian.jira.lookandfeel)
  • Opensocial Plugin (com.atlassian.gadgets.opensocial)
  • Gadget Directory Plugin (com.atlassian.gadgets.directory)
  • Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
I've looked around on this site and followed the instructions given but no avail.  The steps I've taken so far are:
  • Ensure I'm JDK 6 (or 1.6 depending on how you look at it)
  • Deleted everything cached in the "work" folder as well as the .osgi and bundled plugin folder.
  • Set the timeout to 300 in the startup script for JIRA.
Totally stuck now - below is my log.
Thanks in advance!
2013-04-10 14:23:58,784 localhost-startStop-1 INFO      [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2013-04-10 14:24:01,507 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
JIRA starting...
2013-04-10 14:24:01,642 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
___ Environment _____________________________
     JIRA Build                                    : 5.2.10#853-sha1:c0ba2680a6a588d5657e1aadb3169a8dbf69984f
     Build Date                                    : Tue Apr 02 00:00:00 BST 2013
     JIRA Installation Type                        : Standalone
     Application Server                            : Apache Tomcat/7.0.29 - Servlet API 3.0
     Java Version                                  : 1.6.0_43 - Sun Microsystems Inc.
     Current Working Directory                     : C:\Program Files\Atlassian\JIRA\bin
     Maximum Allowable Memory                      : 742MB
     Total Memory                                  : 247MB
     Free Memory                                   : 217MB
     Used Memory                                   : 30MB
     Memory Pool: Code Cache                       : Code Cache: init = 2555904(2496K) used = 1770688(1729K) committed = 2555904(2496K) max = 50331648(49152K)
     Memory Pool: Eden Space                       : Eden Space: init = 71630848(69952K) used = 25926024(25318K) committed = 71630848(69952K) max = 214827008(209792K)
     Memory Pool: Survivor Space                   : Survivor Space: init = 8912896(8704K) used = 1454072(1419K) committed = 8912896(8704K) max = 26804224(26176K)
     Memory Pool: Tenured Gen                      : Tenured Gen: init = 178978816(174784K) used = 4042248(3947K) committed = 178978816(174784K) max = 536870912(524288K)
     Memory Pool: Perm Gen                         : Perm Gen: init = 21757952(21248K) used = 20445784(19966K) committed = 21757952(21248K) max = 268435456(262144K)
     JVM Input Arguments                           : -Dcatalina.base=C:\Program Files\Atlassian\JIRA -Dcatalina.home=C:\Program Files\Atlassian\JIRA -Djava.endorsed.dirs=C:\Program Files\Atlassian\JIRA\endorsed -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dmail.mime.decodeparameters=true -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Djava.io.tmpdir=C:\Program Files\Atlassian\JIRA\temp -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.util.logging.config.file=C:\Program Files\Atlassian\JIRA\conf\logging.properties -XX:MaxPermSize=256m -Xms256m -Xmx768m
___ Java System Properties ________________
     awt.toolkit                                   : sun.awt.windows.WToolkit
     catalina.base                                 : C:\Program Files\Atlassian\JIRA
     catalina.home                                 : C:\Program Files\Atlassian\JIRA
     catalina.useNaming                            : true
     common.loader                                 : ${catalina.base}/lib,
                                                     ${catalina.base}/lib/*.jar,
                                                     ${catalina.home}/lib,
                                                     ${catalina.home}/lib/*.jar
     file.encoding                                 : Cp1252
     file.encoding.pkg                             : sun.io
     java.awt.graphicsenv                          : sun.awt.Win32GraphicsEnvironment
     java.awt.headless                             : true -Datlassian.standalone=JIRA -Dmail.mime.decodeparameters=true
     java.awt.printerjob                           : sun.awt.windows.WPrinterJob
     java.class.version                            : 50.0
     java.home                                     : C:\PROGRA~1\ATLASS~1\JIRA\jre
     java.io.tmpdir                                : C:\Program Files\Atlassian\JIRA\temp
     java.naming.factory.initial                   : org.apache.naming.java.javaURLContextFactory
     java.naming.factory.url.pkgs                  : org.apache.naming
     java.runtime.name                             : Java(TM) SE Runtime Environment
     java.runtime.version                          : 1.6.0_43-b01
     java.specification.name                       : Java Platform API Specification
     java.specification.vendor                     : Sun Microsystems Inc.
     java.specification.version                    : 1.6
     java.util.logging.config.file                 : C:\Program Files\Atlassian\JIRA\conf\logging.properties
     java.util.logging.manager                     : org.apache.juli.ClassLoaderLogManager
     java.vendor                                   : Sun Microsystems Inc.
     java.vendor.url                               : http://java.sun.com/
     java.vendor.url.bug                           : http://java.sun.com/cgi-bin/bugreport.cgi
     java.version                                  : 1.6.0_43
     java.vm.info                                  : mixed mode
     java.vm.name                                  : Java HotSpot(TM) 64-Bit Server VM
     java.vm.specification.name                    : Java Virtual Machine Specification
     java.vm.specification.vendor                  : Sun Microsystems Inc.
     java.vm.specification.version                 : 1.0
     java.vm.vendor                                : Sun Microsystems Inc.
     java.vm.version                               : 20.14-b01
     org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
     os.arch                                       : amd64
     os.name                                       : Windows 7
     os.version                                    : 6.1
     package.access                                : sun.,
                                                     org.apache.catalina.,
                                                     org.apache.coyote.,
                                                     org.apache.tomcat.,
                                                     org.apache.jasper.
     package.definition                            : sun.,
                                                     java.,
                                                     org.apache.coyote.,
                                                     org.apache.tomcat.,
                                                     org.apache.jasper.
     server.loader                                 :
     shared.loader                                 :
     sun.arch.data.model                           : 64
     sun.boot.library.path                         : C:\PROGRA~1\ATLASS~1\JIRA\jre\bin
     sun.cpu.endian                                : little
     sun.cpu.isalist                               : amd64
     sun.desktop                                   : windows
     sun.io.unicode.encoding                       : UnicodeLittle
     sun.jnu.encoding                              : Cp1252
     sun.management.compiler                       : HotSpot 64-Bit Tiered Compilers
     sun.os.patch.level                            :
     tomcat.util.buf.StringCache.byte.enabled      : true
     tomcat.util.scan.DefaultJarScanner.jarsToSkip : bootstrap.jar,
                                                     commons-daemon.jar,
                                                     tomcat-juli.jar,
                                                     annotations-api.jar,
                                                     el-api.jar,
                                                     jsp-api.jar,
                                                     servlet-api.jar,
                                                     catalina.jar,
                                                     catalina-ant.jar,
                                                     catalina-ha.jar,
                                                     catalina-tribes.jar,
                                                     jasper.jar,
                                                     jasper-el.jar,
                                                     ecj-*.jar,
                                                     tomcat-api.jar,
                                                     tomcat-util.jar,
                                                     tomcat-coyote.jar,
                                                     tomcat-dbcp.jar,
                                                     tomcat-jni.jar,
                                                     tomcat-spdy.jar,
                                                     tomcat-i18n-en.jar,
                                                     tomcat-i18n-es.jar,
                                                     tomcat-i18n-fr.jar,
                                                     tomcat-i18n-ja.jar,
                                                     tomcat-juli-adapters.jar,
                                                     catalina-jmx-remote.jar,
                                                     catalina-ws.jar,
                                                     tomcat-jdbc.jar,
                                                     commons-beanutils*.jar,
                                                     commons-codec*.jar,
                                                     commons-collections*.jar,
                                                     commons-dbcp*.jar,
                                                     commons-digester*.jar,
                                                     commons-fileupload*.jar,
                                                     commons-httpclient*.jar,
                                                     commons-io*.jar,
                                                     commons-lang*.jar,
                                                     commons-logging*.jar,
                                                     commons-math*.jar,
                                                     commons-pool*.jar,
                                                     jstl.jar,
                                                     geronimo-spec-jaxrpc*.jar,
                                                     wsdl4j*.jar,
                                                     ant.jar,
                                                     ant-junit*.jar,
                                                     aspectj*.jar,
                                                     jmx.jar,
                                                     h2*.jar,
                                                     hibernate*.jar,
                                                     httpclient*.jar,
                                                     jmx-tools.jar,
                                                     jta*.jar,
                                                     log4j*.jar,
                                                     mail*.jar,
                                                     slf4j*.jar,
                                                     xercesImpl.jar,
                                                     xmlParserAPIs.jar,
                                                     xml-apis.jar,
                                                     dnsns.jar,
                                                     ldapsec.jar,
                                                     localedata.jar,
                                                     sunjce_provider.jar,
                                                     sunmscapi.jar,
                                                     sunpkcs11.jar,
                                                     jhall.jar,
                                                     tools.jar,
                                                     sunec.jar,
                                                     zipfs.jar,
                                                     apple_provider.jar,
                                                     AppleScriptEngine.jar,
                                                     CoreAudio.jar,
                                                     dns_sd.jar,
                                                     j3daudio.jar,
                                                     j3dcore.jar,
                                                     j3dutils.jar,
                                                     jai_core.jar,
                                                     jai_codec.jar,
                                                     mlibwrapper_jai.jar,
                                                     MRJToolkit.jar,
                                                     vecmath.jar,
                                                     junit.jar,
                                                     junit-*.jar,
                                                     ant-launcher.jar
     user.country                                  : GB
     user.dir                                      : C:\Program Files\Atlassian\JIRA\bin
     user.home                                     : C:\
     user.language                                 : en
     user.name                                     : S8JIRA$
     user.timezone                                 : Europe/London
     user.variant                                  :
2013-04-10 14:24:01,874 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2013-04-10 14:24:02,350 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory 'C:\Program Files\Atlassian\Application Data\JIRA' is validated and locked for exclusive use by this instance.
2013-04-10 14:24:02,355 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2013-04-10 14:24:04,314 localhost-startStop-1 INFO      [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2013-04-10 14:24:05,133 localhost-startStop-1 INFO      [jira.config.database.DatabaseConfigurationManagerImpl] Now running Database Checklist Launcher
2013-04-10 14:24:21,661 localhost-startStop-1 INFO      [core.entity.jdbc.DatabaseUtil] Database Product Name is MySQL
2013-04-10 14:24:21,662 localhost-startStop-1 INFO      [core.entity.jdbc.DatabaseUtil] Database Product Version is 5.5.27
2013-04-10 14:24:21,662 localhost-startStop-1 INFO      [core.entity.jdbc.DatabaseUtil] Database Driver Name is MySQL-AB JDBC Driver
2013-04-10 14:24:21,662 localhost-startStop-1 INFO      [core.entity.jdbc.DatabaseUtil] Database Driver Version is mysql-connector-java-5.1.23 ( Revision: ${bzr.revision-id} )
2013-04-10 14:24:32,432 localhost-startStop-1 INFO      [atlassian.jira.startup.DatabaseChecklistLauncher] JIRA database startup checks completed successfully.
2013-04-10 14:24:32,440 localhost-startStop-1 INFO      [jira.config.database.DatabaseConfigurationManagerImpl] Now running Post database-configuration launchers
2013-04-10 14:24:42,092 localhost-startStop-1 INFO      [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2013-04-10 14:24:50,183 localhost-startStop-1 INFO      [atlassian.jira.startup.DatabaseLauncher] Database transactions enabled: true
2013-04-10 14:24:50,191 localhost-startStop-1 INFO      [atlassian.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2
2013-04-10 14:24:50,196 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
Database configuration OK
___ Database Configuration ________________
     Loading entityengine.xml from                 : file:/C:/Program%20Files/Atlassian/JIRA/atlassian-jira/WEB-INF/classes/entityengine.xml
     Entity model field type name                  : mysql
     Entity model schema name                      :
     Database Version                              : MySQL - 5.5.27
     Database Driver                               : MySQL-AB JDBC Driver - mysql-connector-java-5.1.23 ( Revision: ${bzr.revision-id} )
     Database URL                                  : jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB
     Database JDBC config                          : mysql jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB
2013-04-10 14:24:54,794 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
___ Starting the JIRA Plugin System _________________
2013-04-10 14:24:54,799 localhost-startStop-1 INFO      [atlassian.plugin.manager.DefaultPluginManager] Initialising the plugin system
2013-04-10 14:25:55,698 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\activeobjects-jira-spi-0.19.16.jar (1364883414000) created
2013-04-10 14:25:56,010 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\activeobjects-plugin-0.19.16.jar (1364883412000) created
2013-04-10 14:25:56,939 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\applinks-plugin-3.10.4.jar (1364883384000) created
2013-04-10 14:25:57,058 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-admin-quicksearch-jira-1.1.1.jar (1364883410000) created
2013-04-10 14:25:57,069 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-bot-killer-1.7.2.1.jar (1364883410000) created
2013-04-10 14:25:57,089 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-custom-apps-plugin-1.15.jar (1364883414000) created
2013-04-10 14:25:57,132 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-dashboard-plugin-3.2.0-m2-1.jar (1364883412000) created
2013-04-10 14:25:57,153 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-directory-plugin-3.2.0-m2-1.jar (1364883414000) created
2013-04-10 14:25:57,168 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-embedded-plugin-3.2.0-m2-1.jar (1364883414000) created
2013-04-10 14:25:57,187 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-oauth-service-provider-plugin-3.2.0-m2-1.jar (1364883414000) created
2013-04-10 14:25:57,306 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-opensocial-plugin-3.2.0-m2-1.jar (1364883414000) created
2013-04-10 14:25:57,524 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-publisher-plugin-3.2.0-m2-1.jar (1364883414000) created
2013-04-10 14:25:57,760 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-jira-rpc-plugin-5.1.3.jar (1364883414000) created
2013-04-10 14:25:57,813 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-nav-links-plugin-1.3.16.jar (1364883414000) created
2013-04-10 14:25:57,851 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-admin-plugin-1.6.1.jar (1364883414000) created
2013-04-10 14:25:57,863 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-consumer-plugin-1.6.1.jar (1364883412000) created
2013-04-10 14:25:57,933 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-consumer-spi-1.6.1.jar (1364883282000) created
2013-04-10 14:25:57,961 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-service-provider-plugin-1.6.1.jar (1364883414000) created
2013-04-10 14:25:58,020 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-oauth-service-provider-spi-1.6.1.jar (1364883278000) created
2013-04-10 14:25:58,102 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-rest-module-compat25-5.2.10.jar (1364883848000) created
2013-04-10 14:25:58,139 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-template-renderer-api-1.4.2.2.jar (1364883266000) created
2013-04-10 14:25:58,435 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-template-renderer-velocity16-plugin-1.4.2.2.jar (1364883266000) created
2013-04-10 14:25:58,641 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-universal-plugin-manager-plugin-2.7.10.jar (1364883410000) created
2013-04-10 14:25:58,932 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\auiplugin-5.0-m10.jar (1364883412000) created
2013-04-10 14:25:58,957 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\com.springsource.com.sun.syndication-0.9.0.jar (1364883410000) created
2013-04-10 14:25:58,982 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\com.springsource.org.jdom-1.0.0.jar (1364883410000) created
2013-04-10 14:25:59,016 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\crowd-rest-application-management-2.4.9.jar (1364883324000) created
2013-04-10 14:25:59,033 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\crowd-rest-plugin-2.4.9.jar (1364883324000) created
2013-04-10 14:25:59,063 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\embedded-crowd-admin-plugin-1.4.5.jar (1364883414000) created
2013-04-10 14:25:59,086 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\hipchat-for-jira-plugin-1.1.13.jar (1364883410000) created
2013-04-10 14:25:59,158 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\httpclient-osgi-4.0.jar (1364883414000) created
2013-04-10 14:25:59,215 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\httpcore-osgi-4.0.jar (1364883412000) created
2013-04-10 14:25:59,271 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\icu4j-3.8-1.jar (1364883412000) created
2013-04-10 14:25:59,306 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-admin-helper-plugin-1.6.jar (1364883414000) created
2013-04-10 14:25:59,342 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-admin-summary-plugin-5.2.10.jar (1364883870000) created
2013-04-10 14:25:59,369 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-application-properties-plugin-5.2.10.jar (1364883870000) created
2013-04-10 14:25:59,565 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-bamboo-plugin-5.2.1.jar (1364883412000) created
2013-04-10 14:25:59,576 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-baseurl-plugin-1.9.jar (1364883414000) created
2013-04-10 14:25:59,979 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-fisheye-plugin-5.2.9.jar (1364883412000) created
2013-04-10 14:26:00,029 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-gadgets-plugin-5.2.10.jar (1364883866000) created
2013-04-10 14:26:00,073 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-header-plugin-5.2.10.jar (1364883894000) created
2013-04-10 14:26:00,091 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-help-tips-0.29.jar (1364883410000) created
2013-04-10 14:26:00,100 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-ical-feed-1.0.12.jar (1364883410000) created
2013-04-10 14:26:00,216 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-importers-plugin-5.0.3.jar (1364883414000) created
2013-04-10 14:26:00,237 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-invite-user-plugin-1.6.jar (1364883414000) created
2013-04-10 14:26:00,293 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-collector-plugin-1.2.9.jar (1364883410000) created
2013-04-10 14:26:00,369 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-applinks-common-plugin-5.2.10.jar (1364883902000) created
2013-04-10 14:26:00,477 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-confluence-plugin-5.2.10.jar (1364883908000) created
2013-04-10 14:26:00,542 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-remote-jira-plugin-5.2.10.jar (1364883902000) created
2013-04-10 14:26:00,566 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-web-plugin-5.2.10.jar (1364883904000) created
2013-04-10 14:26:00,759 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-nav-plugin-1.1.25.21.jar (1364883414000) created
2013-04-10 14:26:00,780 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-json-rpc-plugin-1.0.4.jar (1364883410000) created
2013-04-10 14:26:00,918 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-de_DE-5.2.8-v2r5721-2013-03-15.jar (1364883412000) created
2013-04-10 14:26:00,938 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-es_ES-5.2.8-v2r12795-2013-03-15.jar (1364883412000) created
2013-04-10 14:26:01,094 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-fr_FR-5.2.8-v2r2373-2013-03-15.jar (1364883412000) created
2013-04-10 14:26:01,109 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-language-pack-ja_JP-5.2.8-v2r15554-2013-03-18.jar (1364883410000) created
2013-04-10 14:26:01,125 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-languages-5.2.10-en_UK.jar (1364883832000) created
2013-04-10 14:26:01,134 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-languages-5.2.10-en_US.jar (1364883832000) created
2013-04-10 14:26:01,164 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-lookandfeel-plugin-5.2.10.jar (1364883874000) created
2013-04-10 14:26:01,232 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-mail-plugin-5.2.21.1.jar (1364883414000) created
2013-04-10 14:26:01,259 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-monitoring-plugin-05.5.4.jar (1364883414000) created
2013-04-10 14:26:01,275 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-my-home-plugin-5.2.10.jar (1364883898000) created
2013-04-10 14:26:01,282 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-oauth-consumer-spi-plugin-5.2.10.jar (1364883852000) created
2013-04-10 14:26:01,292 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-oauth-service-provider-spi-plugin-5.2.10.jar (1364883850000) created
2013-04-10 14:26:01,450 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-project-config-plugin-5.2.10.jar (1364883868000) created
2013-04-10 14:26:01,469 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-quick-edit-plugin-1.0.54.jar (1364883414000) created
2013-04-10 14:26:01,501 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-rest-plugin-5.2.10.jar (1364883864000) created
2013-04-10 14:26:01,519 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-sal-plugin-5.2.10.jar (1364883868000) created
2013-04-10 14:26:01,536 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-share-plugin-5.2.10.jar (1364883900000) created
2013-04-10 14:26:01,545 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-soy-plugin-5.2.10.jar (1364883870000) created
2013-04-10 14:26:01,560 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-tzdetect-plugin-1.6.jar (1364883414000) created
2013-04-10 14:26:01,577 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-user-profile-plugin-1.1.0.jar (1364883414000) created
2013-04-10 14:26:02,278 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-view-issue-plugin-5.2.10.jar (1364883872000) created
2013-04-10 14:26:02,383 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-webhooks-plugin-1.0.8.jar (1364883410000) created
2013-04-10 14:26:02,412 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-welcome-plugin-1.1.34.jar (1364883410000) created
2013-04-10 14:26:02,436 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\json-20070829-1.jar (1364883410000) created
2013-04-10 14:26:02,478 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\mywork-common-plugin-1.1.9.jar (1364883412000) created
2013-04-10 14:26:02,490 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\mywork-jira-provider-plugin-1.1.9.jar (1364883410000) created
2013-04-10 14:26:02,512 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\nekohtml-1.9.12-1.jar (1364883412000) created
2013-04-10 14:26:02,568 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\remoteapps-plugin-0.4.518.3.jar (1364883412000) created
2013-04-10 14:26:02,604 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\rome-1.0.jar (1364883410000) created
2013-04-10 14:26:02,648 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\soy-template-plugin-1.1.3.jar (1364883312000) created
2013-04-10 14:26:02,686 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\stp-3.0.11.jar (1364883410000) created
2013-04-10 14:26:03,093 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-aggregator-plugin-5.2.0.jar (1364883414000) created
2013-04-10 14:26:03,109 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-api-5.2.0.jar (1364883304000) created
2013-04-10 14:26:03,119 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-core-plugin-5.2.0.jar (1364883414000) created
2013-04-10 14:26:03,132 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-inline-actions-plugin-5.2.0.jar (1364883414000) created
2013-04-10 14:26:03,145 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-jira-inline-actions-plugin-5.2.0.jar (1364883414000) created
2013-04-10 14:26:03,558 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-jira-plugin-5.2.0.jar (1364883410000) created
2013-04-10 14:26:03,603 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-spi-5.2.0.jar (1364883304000) created
2013-04-10 14:26:03,618 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-thirdparty-plugin-5.2.0.jar (1364883414000) created
2013-04-10 14:26:03,647 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\workflow-designer-plugin-3.0.0-m14.jar (1364883410000) created
2013-04-10 14:26:49,883 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.jira.rpc.jira-json-rpc-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-header-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-monitoring-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 59 seconds remaining
2013-04-10 14:26:50,959 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-monitoring-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 58 seconds remaining
2013-04-10 14:26:52,680 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 57 seconds remaining
2013-04-10 14:26:53,979 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.labs.atlassian-bot-killer, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 55 seconds remaining
2013-04-10 14:26:55,218 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 54 seconds remaining
2013-04-10 14:26:56,285 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 53 seconds remaining
2013-04-10 14:26:57,323 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, crowd-rest-application-management, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.plugins.jira-admin-helper-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.templaterenderer.api, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 52 seconds remaining
2013-04-10 14:26:58,388 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.plugins.jira-workflow-designer, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, crowd-rest-plugin], 51 seconds remaining
2013-04-10 14:26:59,396 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.sal.jira, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 50 seconds remaining
2013-04-10 14:27:00,495 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.gadgets.publisher, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 49 seconds remaining
2013-04-10 14:27:01,562 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 48 seconds remaining
2013-04-10 14:27:02,637 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-application-properties-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 47 seconds remaining
2013-04-10 14:27:04,152 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.consumer, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 45 seconds remaining
2013-04-10 14:27:05,390 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 44 seconds remaining
2013-04-10 14:27:06,600 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.streams.core, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 43 seconds remaining
2013-04-10 14:27:07,851 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 42 seconds remaining
2013-04-10 14:27:08,962 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.support.stp, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 40 seconds remaining
2013-04-10 14:27:11,260 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 38 seconds remaining
2013-04-10 14:27:12,546 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 37 seconds remaining
2013-04-10 14:27:13,658 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 36 seconds remaining
2013-04-10 14:27:15,043 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 34 seconds remaining
2013-04-10 14:27:16,131 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 33 seconds remaining
2013-04-10 14:27:17,154 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 32 seconds remaining
2013-04-10 14:27:18,299 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.rest, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 31 seconds remaining
2013-04-10 14:27:19,364 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 30 seconds remaining
2013-04-10 14:27:18,819 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:20,482 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.collector.plugin.jira-issue-collector-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' has timed out
	at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
	at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
	at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
	at java.util.TimerThread.mainLoop(Unknown Source)
	at java.util.TimerThread.run(Unknown Source)
2013-04-10 14:27:20,979 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-10 14:27:20,979 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-10 14:27:20,979 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.collector.plugin.jira-issue-collector-plugin
2013-04-10 14:27:20,980 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:20,981 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:20,982 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.directory], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.directory' has timed out
2013-04-10 14:27:20,983 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.directory' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-10 14:27:20,983 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.directory
2013-04-10 14:27:20,984 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:20,985 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.opensocial, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:20,986 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.opensocial], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&appLinksService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.opensocial' has timed out
2013-04-10 14:27:20,988 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&appLinksService' for plugin 'com.atlassian.gadgets.opensocial' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2013-04-10 14:27:20,988 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.opensocial
2013-04-10 14:27:20,989 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.opensocial, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:20,990 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:20,991 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.embedded], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)] (from bean [&securityTokenFactory]), Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.embedded' has timed out
2013-04-10 14:27:20,992 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&securityTokenFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)
2013-04-10 14:27:20,992 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2013-04-10 14:27:20,992 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.embedded
2013-04-10 14:27:20,992 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:20,993 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:20,550 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.gadgets.embedded, com.atlassian.gadgets.directory, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.gadgets, com.atlassian.gadgets.dashboard, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 29 seconds remaining
2013-04-10 14:27:21,128 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.oauth.serviceprovider], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.oauth.serviceprovider' has timed out
2013-04-10 14:27:21,129 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2013-04-10 14:27:21,129 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-10 14:27:21,129 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.oauth.serviceprovider
2013-04-10 14:27:21,130 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:21,176 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.dashboard, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:21,177 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.dashboard], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker)] (from bean [&gadgetSpecUrlChecker]), Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)] (from bean [&renderedGadgetUriBuilder]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.dashboard' has timed out
2013-04-10 14:27:21,177 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecUrlChecker' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker)
2013-04-10 14:27:21,178 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2013-04-10 14:27:21,178 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-10 14:27:21,178 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&renderedGadgetUriBuilder' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)
2013-04-10 14:27:21,178 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-10 14:27:21,178 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.dashboard
2013-04-10 14:27:21,179 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.dashboard, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:21,179 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:21,179 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.gadgets-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.dashboard.DashboardService)] (from bean [&dashboardService]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.gadgets-plugin' has timed out
2013-04-10 14:27:21,180 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-10 14:27:21,180 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&dashboardService' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.dashboard.DashboardService)
2013-04-10 14:27:21,180 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-10 14:27:21,180 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.gadgets
2013-04-10 14:27:21,181 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:21,181 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-applinks-common-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:21,181 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.issue-link-applinks-common-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.issue-link-applinks-common-plugin' has timed out
2013-04-10 14:27:21,182 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.jira.jira-issue-link-applinks-common-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2013-04-10 14:27:21,182 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.jira-issue-link-applinks-common-plugin
2013-04-10 14:27:21,182 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-applinks-common-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:22,277 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 27 seconds remaining
2013-04-10 14:27:23,525 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 26 seconds remaining
2013-04-10 14:27:25,308 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 24 seconds remaining
2013-04-10 14:27:26,190 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.lookandfeel-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:26,568 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.plugins.atlassian-nav-links-plugin], 23 seconds remaining
2013-04-10 14:27:27,524 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.lookandfeel-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.soy.renderer.SoyTemplateRenderer)] (from bean [&soyTemplateRenderer])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.lookandfeel-plugin' has timed out
2013-04-10 14:27:27,530 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&soyTemplateRenderer' for plugin 'com.atlassian.jira.lookandfeel' with filter (objectClass=com.atlassian.soy.renderer.SoyTemplateRenderer)
2013-04-10 14:27:27,530 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.lookandfeel
2013-04-10 14:27:27,530 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.lookandfeel-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:28,619 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 21 seconds remaining
2013-04-10 14:27:29,824 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 20 seconds remaining
2013-04-10 14:27:30,942 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 18 seconds remaining
2013-04-10 14:27:32,815 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 17 seconds remaining
2013-04-10 14:27:33,924 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 15 seconds remaining
2013-04-10 14:27:35,105 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 14 seconds remaining
2013-04-10 14:27:36,192 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.streams, com.atlassian.mywork.mywork-common-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.plugins.atlassian-nav-links-plugin], 13 seconds remaining
2013-04-10 14:27:37,518 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.streams, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.actions, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 12 seconds remaining
2013-04-10 14:27:37,735 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:38,413 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.inline-actions-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)] (from bean [&streamsLocaleProvider])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out
2013-04-10 14:27:38,414 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsLocaleProvider' for plugin 'com.atlassian.streams.actions' with filter (objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)
2013-04-10 14:27:38,414 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.actions
2013-04-10 14:27:38,416 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:38,538 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.streams, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 11 seconds remaining
2013-04-10 14:27:38,610 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:38,611 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.aggregator-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)] (from bean [&formatPreferenceProvider]), Dependency on [(objectClass=com.atlassian.streams.spi.EntityResolver)] (from bean [&entityResolvers])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out
2013-04-10 14:27:38,612 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&formatPreferenceProvider' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)
2013-04-10 14:27:38,612 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityResolvers' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.EntityResolver)
2013-04-10 14:27:38,612 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams
2013-04-10 14:27:38,612 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:39,444 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:39,445 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.thirdparty-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.UserProfileAccessor)] (from bean [&userProfileAccessor])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out
2013-04-10 14:27:39,447 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userProfileAccessor' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.spi.UserProfileAccessor)
2013-04-10 14:27:39,449 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-thirdparty-plugin
2013-04-10 14:27:39,557 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:39,558 Timer-1 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-10 14:27:39,559 Timer-1 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.jira-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out
2013-04-10 14:27:39,560 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-10 14:27:39,561 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-10 14:27:39,562 Timer-1 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-jira-plugin
2013-04-10 14:27:39,568 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 10 seconds remaining
2013-04-10 14:27:39,614 Timer-1 ERROR      [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-10 14:27:40,794 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin], 9 seconds remaining
2013-04-10 14:27:41,822 localhost-startStop-1 INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.labs.remoteapps-plugin], 8 seconds remaining
2013-04-10 14:27:46,884 localhost-startStop-1 INFO      [jira.plugins.monitor.MonitoringScheduler] Scheduling metrics collector to run every 10000ms...
2013-04-10 14:27:46,976 localhost-startStop-1 INFO      [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\Program Files\Atlassian\Application Data\JIRA\monitor\ConnectionPoolGraph.rrd4j
2013-04-10 14:27:47,135 localhost-startStop-1 INFO      [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\Program Files\Atlassian\Application Data\JIRA\monitor\DatabaseReadWritesGraph.rrd4j
2013-04-10 14:27:47,137 localhost-startStop-1 INFO      [jira.plugins.monitor.MonitorLauncher] Started JIRA monitoring
2013-04-10 14:27:56,931 localhost-startStop-1 INFO      [atlassian.plugin.loaders.ScanningPluginLoader] No plugins found to be deployed
2013-04-10 14:27:57,073 localhost-startStop-1 INFO      [atlassian.plugin.manager.DefaultPluginManager] Plugin system started in 0:03:02.258
2013-04-10 14:27:57,277 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
___ Plugin System Started _________________
2013-04-10 14:27:58,720 localhost-startStop-1 INFO      [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2013-04-10 14:27:58,815 localhost-startStop-1 INFO      [jira.instrumentation.external.DatabaseExternalGauges] Installing DBCP monitoring instruments: DatabaseExternalGauges.JiraDbcpInstruments[instruments=[DBCP_MAX, DBCP_ACTIVE, DBCP_IDLE],objectName=com.atlassian.jira:name=BasicDataSource]
2013-04-10 14:28:11,401 localhost-startStop-1 INFO      [atlassian.jira.upgrade.ConsistencyCheckImpl] Checking JIRA consistency
2013-04-10 14:28:11,479 localhost-startStop-1 INFO      [atlassian.jira.upgrade.ConsistencyCheckImpl] The Server ID for this JIRA instance is: [BGV6-KFMN-LT5P-GTK1]
2013-04-10 14:28:13,394 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
___ User Directories (Ordered) ______________
     INTERNAL                                      : JIRA Internal Directory
          Implementing Class                            : com.atlassian.crowd.directory.InternalDirectory
          Allowed Operations                            : CREATE_GROUP,
                                                          CREATE_ROLE,
                                                          CREATE_USER,
                                                          DELETE_GROUP,
                                                          DELETE_ROLE,
                                                          DELETE_USER,
                                                          UPDATE_GROUP,
                                                          UPDATE_GROUP_ATTRIBUTE,
                                                          UPDATE_ROLE,
                                                          UPDATE_ROLE_ATTRIBUTE,
                                                          UPDATE_USER,
                                                          UPDATE_USER_ATTRIBUTE
          Encryption Type                               : atlassian-security
          Active                                        : true
          Attributes                                    :
               user_encryption_method                        : atlassian-security
___ Core Application Properties ___________
     Version                                       : 5.2.10
     Build #                                       : 853
     Build Date                                    : Tue Apr 02 00:00:00 BST 2013
     Installation Type                             : Standalone
     Server ID                                     : BGV6-KFMN-LT5P-GTK1
     Base URL                                      : http://s8jira:8080
     Default Language                              : English (United Kingdom)
     External User Management                      : OFF
___ Application Properties ________________
     AO_4AEACD_#                                   : 1
     com.atlassian.activeobjects.admin.ActiveObjectsPluginToTablesMapping : null
     com.atlassian.jira.jira-mail-plugin:build     : 1
     com.atlassian.jira.lookandfeel.customizeColors : false
     com.atlassian.jira.lookandfeel.logoChoice     : UPLOAD
     com.atlassian.jira.lookandfeel:build          : 1
     com.atlassian.jira.lookandfeel:customDefaultFaviconHiresURL : /images/64jira.png
     com.atlassian.jira.lookandfeel:customDefaultFaviconURL : /favicon.ico
     com.atlassian.jira.lookandfeel:faviconHeight  : 64
     com.atlassian.jira.lookandfeel:faviconWidth   : 64
     com.atlassian.jira.lookandfeel:isDefaultFavicon : false
     com.atlassian.jira.lookandfeel:usingCustomFavicon : false
     com.atlassian.jira.lookandfeel:usingCustomLogo : true
     com.atlassian.jira.plugin.ext.bamboo:build    : 1
     com.atlassian.jira.plugins.jira-importers-plugin:build : 1
     com.atlassian.jira.plugins.jira-workflow-designer:build : 1
     com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin:build : 1
     com.atlassian.sal.jira:build                  : 2
     com.atlassian.upm.atlassian-universal-plugin-manager-plugin:build : 1
     com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR8bdca18bb1b7389d0a2d834a01247d76 : null
     com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRepository:licenses:plugin.jep : null
     com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRfdbfad06c2f1036a60cb955d7e285d69 : #java.util.List
com.pyxis.greenhopper.jira
plugin.jep
     com.atlassian.upm.log.PluginSettingsAuditLogService:log:upm_audit_log_v2 : null
     com.atlassian.upm:notifications:dismissal-evaluation.expired : #java.util.List
     com.atlassian.upm:notifications:dismissal-evaluation.expired:com.eazybi.jira.plugins.eazybi-jira : #java.util.List
     com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired : #java.util.List
     com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired:c6186ce90eb33d166f155aaa75fdcff10 : #java.util.List
     com.atlassian.upm:notifications:dismissal-maintenance.expired:com.eazybi.jira.plugins.eazybi-jira : #java.util.List
     com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired : #java.util.List
     com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired:32539fe8238209d3041c0f97a1d95665 : #java.util.List
     com.atlassian.upm:notifications:dismissal-update : #java.util.List
     com.atlassian.upm:notifications:dismissal-update:com.eazybi.jira.plugins.eazybi-jira : #java.util.List
     com.atlassian.upm:notifications:dismissal-user.mismatch:com.eazybi.jira.plugins.eazybi-jira : #java.util.List
     com.atlassian.upm:notifications:notification-edition.mismatch : #java.util.List
     com.atlassian.upm:notifications:notification-evaluation.expired : #java.util.List
     com.atlassian.upm:notifications:notification-evaluation.nearlyexpired : #java.util.List
     com.atlassian.upm:notifications:notification-maintenance.expired : #java.util.List
     com.atlassian.upm:notifications:notification-maintenance.nearlyexpired : #java.util.List
     com.atlassian.upm:notifications:notification-plugin.request : #java.util.List
     com.atlassian.upm:notifications:notification-update : #java.util.List
     com.atlassian.upm:notifications:notification-user.mismatch : #java.util.List
     com.pyxis.greenhopper.jira:build              : 24
     eazybi.database                               : #java.util.Map
adapter?mysql
host?localhost
database?eazybi_jira
username?root
     eazybi.license_type                           : atlassian_marketplace
     jira.ajax.autocomplete.issuepicker.enabled    : true
     jira.ajax.autocomplete.labelsuggestion.limit  : 20
     jira.ajax.autocomplete.limit                  : 20
     jira.alertheader.visibility                   : private
     jira.assignee.change.is.sent.to.both.parties  : true
     jira.attachment.allow.zip.support             : true
     jira.attachment.do.not.expand.as.zip.extensions.list : docx, docm, dotx, dotm, xlsx, xlsm, xltx, xltm, xlsb, xlam, pptx, pptm, potx, potm, ppam, ppsx, ppsm, sldx, sldm, thmx, odt, odp, ods, odg, odb, odf, ott, otp, ots, otg, odm, sxw, stw, sxc, stc, sxi, sti, sxd, std, sxg
     jira.attachment.download.mime.sniffing.workaround : workaround
     jira.attachment.number.of.zip.entries         : 30
     jira.autoexport                               : true
     jira.avatar.default.id                        : 10011
     jira.avatar.megapixels                        : 10
     jira.avatar.user.anonymous.id                 : 10123
     jira.avatar.user.default.id                   : 10122
     jira.baseurl                                  : http://s8jira:8080
     jira.browser.unsupported.warnings.disabled    : false
     jira.bulk.edit.limit.issue.count              : 1000
     jira.chart.days.previous.limit.daily          : 300
     jira.chart.days.previous.limit.hourly         : 10
     jira.chart.days.previous.limit.monthly        : 7500
     jira.chart.days.previous.limit.quarterly      : 22500
     jira.chart.days.previous.limit.weekly         : 1750
     jira.chart.days.previous.limit.yearly         : 36500
     jira.clone.linktype.name                      : Cloners
     jira.clone.prefix                             : CLONE -
     jira.comment.level.visibility.groups          : false
     jira.constant.default.resolution              : 1
     jira.contact.administrators.message           : null
     jira.dashboard.max.gadgets                    : 20
     jira.databasequery.batch.size                 : 100
     jira.date.picker.java.format                  : d/MMM/yy
     jira.date.picker.javascript.format            : %e/%b/%y
     jira.date.time.picker.java.format             : dd/MMM/yy h:mm a
     jira.date.time.picker.javascript.format       : %e/%b/%y %I:%M %p
     jira.date.time.picker.use.iso8061             : false
     jira.db.txns.disabled                         : false
     jira.default.jndi.name                        : java:comp/env/jdbc/JiraDS
     jira.disable.login.gadget                     : false
     jira.disable.multipart.get.http.request       : true
     jira.edition                                  : enterprise
     jira.email.fromheader.format                  : ${fullname} (JIRA)
     jira.enabled.dark.features                    :
     jira.export.fetchsize                         : -1
     jira.exportimport.cleanxml                    : true
     jira.home                                     :
     jira.i18n.include.meta-data                   : true
     jira.i18n.language.index                      : english
     jira.import.maxqueuesize                      : 100
     jira.import.threads                           : 10
     jira.index.background.batch.size              : 1000
     jira.index.batch.maxbuffereddocs              : 300
     jira.index.batch.maxmergedocs                 : 2147483647
     jira.index.batch.mergefactor                  : 50
     jira.index.interactive.maxbuffereddocs        : 300
     jira.index.interactive.maxmergedocs           : 2147483647
     jira.index.interactive.mergefactor            : 4
     jira.index.issue.maxqueuesize                 : 1000
     jira.index.issue.minbatchsize                 : 50
     jira.index.issue.threads                      : 10
     jira.index.lock.waittime                      : 30000
     jira.index.max.reindexes                      : 2147483647
     jira.index.maxfieldlength                     : 10000
     jira.index.mergepolicy.expungedeletespctallowed : 10
     jira.index.mergepolicy.floorsegmentmb         : 2
     jira.index.mergepolicy.maxmergeatonce         : 10
     jira.index.mergepolicy.maxmergeatonceexplicit : 30
     jira.index.mergepolicy.maxmergedsegmentmb     : 512
     jira.index.mergepolicy.nocfspct               : 10
     jira.index.mergepolicy.segmentspertier        : 10
     jira.index.mergepolicy.usecompoundfile        : true
     jira.index.sharedentity.maxqueuesize          : 1000
     jira.index.sharedentity.minbatchsize          : 50
     jira.index.sharedentity.threads               : 10
     jira.index.update.bulk.optimization           : 400
     jira.issue.actions.order                      : asc
     jira.issue.inline.edit.disabled               : false
     jira.issueindex.fetch.size                    : 200
     jira.issuenav.criteria.autoupdate             : true
     jira.jql.autocomplete.disabled                : false
     jira.lf.application.id                        : jira
     jira.lf.date.complete                         : dd/MMM/yy h:mm a
     jira.lf.date.day                              : EEEE h:mm a
     jira.lf.date.dmy                              : dd/MMM/yy
     jira.lf.date.relativize                       : true
     jira.lf.date.time                             : h:mm a
     jira.lf.favicon.hires.url                     : /images/64jira.png
     jira.lf.favicon.url                           : /favicon.ico
     jira.lf.gadget.color1                         : #369
     jira.lf.gadget.color2                         : #900925
     jira.lf.gadget.color3                         : #d94625
     jira.lf.gadget.color4                         : #346006
     jira.lf.gadget.color5                         : #003366
     jira.lf.gadget.color6                         : #411E66
     jira.lf.gadget.color7                         : #bbb
     jira.lf.hero.button.base.bg.colour            : #3b7fc4
     jira.lf.hero.button.text.colour               : #ffffff
     jira.lf.logo.height                           : 47
     jira.lf.logo.show.application.title           : false
     jira.lf.logo.url                              : /jira-logo-scaled.png
     jira.lf.logo.width                            : 142
     jira.lf.menu.bgcolour                         : #326ca6
     jira.lf.menu.separator                        : #f0f0f0
     jira.lf.menu.textcolour                       : #ffffff
     jira.lf.text.activelinkcolour                 : #326ca6
     jira.lf.text.headingcolour                    : #292929
     jira.lf.text.linkcolour                       : #326ca6
     jira.lf.top.bgcolour                          : #205081
     jira.lf.top.hilightcolour                     : #296CA3
     jira.lf.top.separator.bgcolor                 : #2E3D54
     jira.lf.top.textcolour                        : #ffffff
     jira.lf.top.texthilightcolour                 : #f0f0f0
     jira.mail.fetch.disabled                      : false
     jira.mail.send.disabled                       : true
     jira.max.AdminPage.history.items              : 5
     jira.max.Issue.history.items                  : 50
     jira.max.JQLQuery.history.items               : 10
     jira.max.history.items                        : 10
     jira.max.issue.filter.dropdown.items          : 10
     jira.max.issue.history.dropdown.items         : 6
     jira.maximum.authentication.attempts.allowed  : 3
     jira.mode                                     : public
     jira.option.allowattachments                  : true
     jira.option.allowcookies                      : true
     jira.option.allowsubtasks                     : true
     jira.option.allowthumbnails                   : true
     jira.option.allowunassigned                   : true
     jira.option.captcha.on.signup                 : false
     jira.option.emailvisible                      : show
     jira.option.ignore.url.with.key               : true
     jira.option.indexing                          : true
     jira.option.issuelinking                      : true
     jira.option.logoutconfirm                     : never
     jira.option.precedence.header.exclude         : false
     jira.option.rpc.allow                         : true
     jira.option.timetracking                      : true
     jira.option.user.externalmanagement           : false
     jira.option.voting                            : true
     jira.option.watching                          : true
     jira.option.web.usegzip                       : true
     jira.path.attachments                         : C:\Program Files\Atlassian\Application Data\JIRA\data\attachments
     jira.path.attachments.use.default.directory   : true
     jira.path.backup                              : C:\Program Files\Atlassian\Application Data\JIRA\export
     jira.path.index.use.default.directory         : true
     jira.plugin.state-.com.atlassian.jira.welcome.jira-welcome-plugin:show-whats-new-flag : true
     jira.project.summary.max.issues               : 3
     jira.projectkey.description                   : admin.projects.key.description
     jira.projectkey.pattern                       : ([A-Z][A-Z]+)
     jira.projectkey.reservedwords.list            : PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7, COM8, COM9, CON, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, LPT9
     jira.projectkey.warning                       : admin.errors.must.specify.unique.project.key
     jira.releasenotes.default                     : Html
     jira.releasenotes.templatenames               : Html, Text
     jira.releasenotes.templates                   : releasenotes-html.vm, releasenotes-text.vm
     jira.scheme.default.issue.type                : 10000
     jira.schemes.comparison.max                   : 5
     jira.screenshotapplet.enabled                 : true
     jira.screenshotapplet.linux.enabled           : false
     jira.search.fullcontentview.pagebreaks        : true
     jira.search.maxclauses                        : 65000
     jira.search.views.default.max                 : 1000
     jira.search.views.max.limit                   : 1000
     jira.search.views.max.unlimited.group         :
     jira.sendmail.recipient.batch.size            : 100
     jira.setup                                    : true
     jira.show.contact.administrators.form         : false
     jira.subscription.email.max.issues            : 200
     jira.table.cols.dashboard                     : issuetype, issuekey, summary, priority
     jira.table.cols.subtasks                      : issuetype, status, assignee, progress
     jira.table.cols.voted                         : issuetype, issuekey, summary, priority, status
     jira.table.cols.watched                       : issuetype, issuekey, summary, priority, status
     jira.table.gadget.max.rows                    : 50
     jira.text.field.character.limit               : 0
     jira.thumbnail.maxheight                      : 200
     jira.thumbnail.maxwidth                       : 200
     jira.timetracking.copy.comment.to.work.desc.on.transition : true
     jira.timetracking.days.per.week               : 5
     jira.timetracking.default.unit                : MINUTE
     jira.timetracking.estimates.legacy.behaviour  : false
     jira.timetracking.format                      : pretty
     jira.timetracking.hours.per.day               : 8
     jira.title                                    : SIMUL8 JIRA
     jira.trustedapp.key.private.data              : null
     jira.trustedapp.key.public.data               : null
     jira.trustedapp.uid                           : jira:7959625
     jira.trustedapps.timeout.default              : 10000
     jira.trustedapps.urlmatch.default             : /sr/jira.issueviews:searchrequest
/secure/RunPortlet
/rest
/rpc/soap
/plugins/servlet/streams
/plugins/servlet/applinks
     jira.user.avatar.gravatar.enabled             : false
     jira.usermanagement.maxdisplaymembers         : 200
     jira.version.patched                          : 853
     jira.view.issue.links.sort.order              : type, status, priority
     jira.view.issue.show.quicksubtask.when.no.subtasks : false
     jira.viewcvs.root.type                        : cvsroot
     jira.webresource.flushcounter                 : 4
     jira.webresource.superbatch.flushcounter      : 1
     jira.websudo.is.disabled                      : false
     jira.websudo.timeout                          : 10
     jira.whitelist.disabled                       : false
     jira.whitelist.rules                          : null
     jira.xsrf.enabled                             : true
     notification.instance.upgrade.date            : 1365590264507
     remoteapps.lastVersion.remoteapps             : 0.4.518.3
     remoteapps.lastVersion.server                 : 853
     show.plugin.marketing.hints                   : true
     user.default.share.private                    : true
     user.issues.per.page                          : 50
     user.keyboard.shortcuts.disabled              : false
     user.notifications.mimetype                   : html
     user.notify.own.changes                       : false
     user.show.actions.in.navigator                : true
     webwork.i18n.encoding                         : UTF-8
     webwork.multipart.maxSize                     : 10485760
___ License Details _______________________
     License Set                                   : true
     Entitled To Support                           : true
     Evaluation                                    : false
     Description                                   : JIRA 10 Users: Starter License
     SEN                                           : SEN-2387720
     Organisation                                  : SIMUL8 Corporation
     Partner                                       :
     Maximum Number Of Users                       : 10
___ Database Statistics ___________________
     Issues                                        : 448
     Projects                                      : 6
     Custom Fields                                 : 12
     Workflows                                     : 8
     Users                                         : 10
     Groups                                        : 3
     Attachments                                   : 62
     Comments                                      : 173
___ Upgrade History _______________________
     5.2.10#853
          Time Performed                                : 2013-04-10 11:37:45.0
          Original Version                              : 5.1.6#785
     5.1.6#785
          Time Performed                                : 2012-10-16 16:19:52.0
___ File Paths ____________________________
     JIRA Home                                     : C:\Program Files\Atlassian\Application Data\JIRA
     Location of atlassian-jira.log                : C:\Program Files\Atlassian\Application Data\JIRA\log\atlassian-jira.log
     Index Path                                    : C:\Program Files\Atlassian\Application Data\JIRA\caches\indexes
     Attachment Path                               : C:\Program Files\Atlassian\Application Data\JIRA\data\attachments
___ User Plugins ____________________________
     Number                                        : 0
___ System Plugins __________________________
     Number                                        : 98
     ActiveObjects Plugin - OSGi Bundle            : com.atlassian.activeobjects.activeobjects-plugin
          Version                                       : 0.19.16
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : An OSGi bundle that provides a service that allows plugins to persist objects using the ActiveObjects framework
     Apache HttpClient OSGi bundle                 : org.apache.httpcomponents.httpclient-4.0
          Version                                       : 4.0
          Status                                        : enabled
          Vendor                                        : Apache Software Foundation
          Description                                   : HttpComponents Client (OSGi bundle)
     Apache HttpCore OSGi bundle                   : org.apache.httpcomponents.httpcore-4.0
          Version                                       : 4.0
          Status                                        : enabled
          Description                                   : HttpComponents Core (OSGi bundle)
     Applinks Product Plugin                       : com.atlassian.applinks.applinks-plugin
          Version                                       : 3.10.4
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Plugin that facilitates discovery, connections and authentication with remote applications
     Atlassian - Administration - Quick Search - JIRA : com.atlassian.administration.atlassian-admin-quicksearch-jira
          Version                                       : 1.1.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Administration Quick Search plugin for JIRA
     Atlassian Bot Session Killer                  : com.atlassian.labs.atlassian-bot-killer
          Version                                       : 1.7.2.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This will remove unwanted http sessions for requests that exhibit Bot like behaviour. That is they make a single request, don't preserve cookies and never call again.
     Atlassian Custom Apps Plugin                  : com.atlassian.plugins.atlassian-custom-apps-plugin
          Version                                       : 1.15
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Create and edit custom applications shown in the application switcher.
     Atlassian Embedded Crowd - Administration Plugin : com.atlassian.crowd.embedded.admin
          Version                                       : 1.4.5
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides the administration of local and remote user directories.
     Atlassian Gadgets OAuth Service Provider Plugin : com.atlassian.gadgets.oauth.serviceprovider
          Version                                       : 3.2.0-m2-1
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Plugin that makes OAuth Service Providers Gadget aware.
     Atlassian JIRA - Admin Helper Plugin          : com.atlassian.jira.plugins.jira-admin-helper-plugin
          Version                                       : 1.6
          Status                                        : enabled
          Vendor                                        : Atlassian Pty Ltd
          Description                                   : The Admin Helper plugin helps admins determine visibility of custom fields and also provides reasons for why a user does not have certain permissions on an issue or does not receive notifications for that issue.
     Atlassian JIRA - Plugins - Admin Summary Component : com.atlassian.jira.jira-admin-summary-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Supplies Content to the JIRA Administration Summary Page
     Atlassian JIRA - Plugins - Application Properties : com.atlassian.jira.jira-application-properties-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides advanced application properties configuration
     Atlassian JIRA - Plugins - Closure Template Renderer : com.atlassian.jira.jira-soy-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides renderer for Closure templates
     Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin : com.atlassian.jira.jira-issue-link-applinks-common-plugin
          Version                                       : 5.2.10
          Status                                        : disabled
          Vendor                                        : ${project.organization.name}
          Description                                   : Provides the common utilities for AppLinks based issue link plugins
     Atlassian JIRA - Plugins - Confluence Link    : com.atlassian.jira.jira-issue-link-confluence-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Description                                   : Provides creation and rendering of issue links to Confluence pages
     Atlassian JIRA - Plugins - Gadgets Plugin     : com.atlassian.jira.gadgets
          Version                                       : 5.2.10
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Provides Gadgets and REST endpoints bundled with JIRA
     Atlassian JIRA - Plugins - Header Plugin      : com.atlassian.jira.jira-header-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides markup/styles/behaviour/plugin points for the header
     Atlassian JIRA - Plugins - Invite User        : com.atlassian.jira.jira-invite-user-plugin
          Version                                       : 1.6
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Allows administrators to invite users to sign up for an account
     Atlassian JIRA - Plugins - Issue Navigation   : com.atlassian.jira.jira-issue-nav-plugin
          Version                                       : 1.1.25.21
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides issue search and navigation
     Atlassian JIRA - Plugins - Issue Web Link     : com.atlassian.jira.jira-issue-link-web-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Description                                   : Provides creation and rendering of issue links to web pages
     Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin : com.atlassian.jira.lookandfeel
          Version                                       : 5.2.10
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Provides logo upload capabilities
     Atlassian JIRA - Plugins - Mail Plugin        : com.atlassian.jira.jira-mail-plugin
          Version                                       : 5.2.21.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Handles incoming and outgoing mail
     Atlassian JIRA - Plugins - My JIRA Home       : com.atlassian.jira.jira-my-home-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Lets the user pick a landing page.
     Atlassian JIRA - Plugins - OAuth Consumer SPI : com.atlassian.jira.oauth.consumer
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides the Consumer SPI implementation required for OAuth in JIRA.
     Atlassian JIRA - Plugins - OAuth Service Provider SPI : com.atlassian.jira.oauth.serviceprovider
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides the OAuth Service Provider SPI implementation required for OAuth in JIRA.
     Atlassian JIRA - Plugins - Project Config Plugin : com.atlassian.jira.jira-project-config-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides easier project administration with JIRA
     Atlassian JIRA - Plugins - Quick Edit Plugin  : com.atlassian.jira.jira-quick-edit-plugin
          Version                                       : 1.0.54
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This is the com.atlassian.jira:jira-quick-edit-plugin plugin for Atlassian JIRA.
     Atlassian JIRA - Plugins - REST Plugin        : com.atlassian.jira.rest
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides a REST interface for JIRA
     Atlassian JIRA - Plugins - Remote JIRA Link   : com.atlassian.jira.jira-issue-link-remote-jira-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Description                                   : Provides creation and rendering of links to local and remote JIRA issues
     Atlassian JIRA - Plugins - SAL Plugin         : com.atlassian.sal.jira
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian Software Systems
          Description                                   : JIRA implementation of the Shared Application Access Layer (SAL)
     Atlassian JIRA - Plugins - Share Content Component : com.atlassian.jira.jira-share-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Allows users to share issue and searches
     Atlassian JIRA - Plugins - User Profile Plugin : com.atlassian.jira.jira-user-profile-plugin
          Version                                       : 1.1.0
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Plugin uses web-panels to encapsulate details and preferences modules from user profile page.
     Atlassian JIRA - Plugins - View Issue Panels  : com.atlassian.jira.jira-view-issue-plugin
          Version                                       : 5.2.10
          Status                                        : enabled
          Description                                   : Provides WebPanels for the View Issue Page
     Atlassian Navigation Links Plugin             : com.atlassian.plugins.atlassian-nav-links-plugin
          Version                                       : 1.3.16
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Capabilities and Navigation API client and server implementation
     Atlassian OAuth Admin Plugin                  : com.atlassian.oauth.admin
          Version                                       : 1.6.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Plugin that provides a single tabbed view for administering OAuth consumers and service provider information.
     Atlassian OAuth Consumer Plugin               : com.atlassian.oauth.consumer
          Version                                       : 1.6.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Plugin that makes it possible for applications to become Consumers.
     Atlassian OAuth Consumer SPI                  : com.atlassian.oauth.atlassian-oauth-consumer-spi-1.6.1
          Version                                       : 1.6.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Consumer SPIs to allow applications to provide custom implementations of storing token and consumer info
     Atlassian OAuth Service Provider Plugin       : com.atlassian.oauth.serviceprovider
          Version                                       : 1.6.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Plugin that makes it possible for applications to become Service Providers.
     Atlassian OAuth Service Provider SPI          : com.atlassian.oauth.atlassian-oauth-service-provider-spi-1.6.1
          Version                                       : 1.6.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Service Provider SPIs to allow applications to provide custom implementations of storing token consumer info
     Atlassian REST - Module Types                 : com.atlassian.plugins.rest.atlassian-rest-module
          Version                                       : 2.7.1
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : A plugin that contains REST module types
     Atlassian Remote Apps - Plugin                : com.atlassian.labs.remoteapps-plugin
          Version                                       : 0.4.518.3
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This is the parent for the Atlassian Remote Apps project
     Atlassian Soy Templates - Plugin              : com.atlassian.soy.soy-template-plugin
          Version                                       : 1.1.3
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Base POM for Atlassian projects
     Atlassian Template Renderer API               : com.atlassian.templaterenderer.api
          Version                                       : 1.4.2.2
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : API and plugins for easily rendering content from different template engines.
     Atlassian Template Renderer Velocity 1.6 Plugin : com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin
          Version                                       : 1.4.2.2
          Status                                        : enabled
          Vendor                                        : Atlassian
     Atlassian UI Plugin                           : com.atlassian.auiplugin
          Version                                       : 5.0-m10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : An Atlassian plugin that contains the core javascript files used in Atlassian products.
     Atlassian Universal Plugin Manager Plugin     : com.atlassian.upm.atlassian-universal-plugin-manager-plugin
          Version                                       : 2.7.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This is the plugin that provides the Atlassian Universal Plugin Manager.
     Crowd REST API                                : crowd-rest-application-management
          Version                                       : 1.0
          Status                                        : enabled
          Description                                   : Crowd REST API - Application Management
     Crowd REST API                                : crowd-rest-plugin
          Version                                       : 1.0
          Status                                        : enabled
     Crowd System Password Encoders                : crowd.system.passwordencoders
          Version                                       : 1.0
          Status                                        : enabled
          Description                                   : Crowd Password Encoders shipped with Crowd
     Embedded Gadgets Plugin                       : com.atlassian.gadgets.embedded
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Plugin which allows gadgets to be embedded in pages
     English (United Kingdom) Language Pack        : com.atlassian.jira.jira-languages.en_UK
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This plugin contains translations the core keys in JIRA for English (United Kingdom).
     English (United States) Language Pack         : com.atlassian.jira.jira-languages.en_US
          Version                                       : 5.2.10
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This plugin contains translations the core keys in JIRA for English (United States).
     FishEye Plugin                                : com.atlassian.jirafisheyeplugin
          Version                                       : 5.2.9
          Status                                        : enabled
          Description                                   : JIRA Fisheye Plugin
     Gadget Dashboard Plugin                       : com.atlassian.gadgets.dashboard
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Plugin which renders a dashboard of gadgets
     Gadget Directory Plugin                       : com.atlassian.gadgets.directory
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Plugin which renders a directory of gadgets
     Gadget Spec Publisher Plugin                  : com.atlassian.gadgets.publisher
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Plugin which provides a way to publish gadget specs found in plugins
     HipChat                                       : com.atlassian.labs.hipchat.hipchat-for-jira-plugin
          Version                                       : 1.1.13
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This is the HipChat plugin for JIRA.
     ICU4J                                         : com.atlassian.bundles.icu4j-3.8.0.1
          Version                                       : 3.8.0.1
          Status                                        : enabled
          Description                                   : ICU4J as an OSGi bundle
     JDOM DOM Processor                            : com.springsource.org.jdom-1.0.0
          Version                                       : 1.0.0
          Status                                        : enabled
          Vendor                                        : SpringSource
          Description                                   :
     JIRA Active Objects SPI implementation        : com.atlassian.activeobjects.jira.spi
          Version                                       : 0.19.16
          Status                                        : enabled
          Description                                   : A plugin that provides the DataSourceProvider service
     JIRA Activity Stream Plugin                   : com.atlassian.streams.streams-jira-plugin
          Version                                       : 5.2.0
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Lists recent activity in a single project, or in all projects.
     JIRA Bamboo Plugin                            : com.atlassian.jira.plugin.ext.bamboo
          Version                                       : 5.2.1
          Status                                        : enabled
          Vendor                                        : Atlassian Software Systems Pty Ltd
          Description                                   : Allows you to see builds and telemetry from a remote Bamboo server
     JIRA Base URL Plugin                          : com.atlassian.jira.jira-baseurl-plugin
          Version                                       : 1.9
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Detects incorrectly-set base URLs in JIRA.
     JIRA French (France) Language Pack            : tac.jira.languages.fr_FR
          Version                                       : 5.2.8-v2r2373-2013-03-15
          Status                                        : enabled
          Vendor                                        : Atlassian Community
          Description                                   : This plugin contains translations for fr_FR
     JIRA German (Germany) Language Pack           : tac.jira.languages.de_DE
          Version                                       : 5.2.8-v2r5721-2013-03-15
          Status                                        : enabled
          Description                                   : This plugin contains translations for de_DE
     JIRA Importers Plugin (JIM)                   : com.atlassian.jira.plugins.jira-importers-plugin
          Version                                       : 5.0.3
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : A plugin (originally part of JIRA 4.2 and older) which provides capability to import to JIRA issues from 3rd party issue trackers: Bugzilla, FogBugz and Mantis.
     JIRA Issue Collector Plugin                   : com.atlassian.jira.collector.plugin.jira-issue-collector-plugin
          Version                                       : 1.2.9
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : This plugin provides the ability to create issues from remote applications
     JIRA JSON-RPC Plugin                          : com.atlassian.jira.rpc.jira-json-rpc-plugin
          Version                                       : 1.0.4
          Status                                        : enabled
          Description                                   : Exposes JIRA SOAP services using JSON-RPC
     JIRA Japanese (Japan) Language Pack           : tac.jira.languages.ja_JP
          Version                                       : 5.2.8-v2r15554-2013-03-18
          Status                                        : enabled
          Description                                   : This plugin contains translations for ja_JP
     JIRA Monitoring Plugin                        : com.atlassian.jira.jira-monitoring-plugin
          Version                                       : 05.5.4
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Records and exposes JIRA key performance metrics
     JIRA Spanish (Spain) Language Pack            : tac.jira.languages.es_ES
          Version                                       : 5.2.8-v2r12795-2013-03-15
          Status                                        : enabled
          Description                                   : This plugin contains translations for es_ES
     JIRA Streams Inline Actions Plugin            : com.atlassian.streams.jira.inlineactions
          Version                                       : 5.2.0
          Status                                        : enabled
          Description                                   : JIRA Streams Inline Actions Plugin
     JIRA Time Zone Detection plugin               : com.atlassian.jira.jira-tzdetect-plugin
          Version                                       : 1.6
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Performs client-side time zone detection for JIRA.
     JIRA Usage Hints                              : jira.usage.hints
          Version                                       : 1.0
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This library includes the web fragments for JIRA usage hints displayed on issue operation dialogs. It should never be disabled.
     JIRA WebHooks Plugin                          : com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin
          Version                                       : 1.0.8
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This plugin provides the ability to register Web Hooks for events in JIRA
     JIRA Welcome Plugin                           : com.atlassian.jira.welcome.jira-welcome-plugin
          Version                                       : 1.1.34
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Displays a welcome dialog for first-time usage of JIRA, as well as a whats new dialog for users just having upgraded to this version of JIRA.
     JIRA iCalendar Plugin                         : com.atlassian.jira.extra.jira-ical-feed
          Version                                       : 1.0.12
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides an iCal feed of JIRA issues and versions
     JQL Functions                                 : jira.jql.function
          Version                                       : 1.0
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This plugin implements a JQL function in JIRA.
     JSON Library                                  : com.atlassian.bundles.json-20070829.0.0.1
          Version                                       : 20070829.0.0.1
          Status                                        : enabled
          Description                                   : Library for manipulating JSON
     Keyboard Shortcuts Plugin                     : jira.keyboard.shortcuts
          Version                                       : 1.0
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : A plugin that defines a number of keyboard shortcuts.
     Neko HTML                                     : com.atlassian.bundles.nekohtml-1.9.12.1
          Version                                       : 1.9.12.1
          Status                                        : enabled
          Description                                   : Neko HTML library as an OSGi bundle
     Notifications and Tasks - Common Plugin       : com.atlassian.mywork.mywork-common-plugin
          Version                                       : 1.1.9
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Provides Common Services to Notifications and Tasks
     Notifications and Tasks - JIRA Provider Plugin : com.atlassian.mywork.mywork-jira-provider-plugin
          Version                                       : 1.1.9
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Generates Notifications and Tasks from JIRA
     Opensocial Plugin                             : com.atlassian.gadgets.opensocial
          Status                                        : disabled
          Vendor                                        : Atlassian
          Description                                   : Plugin for OpenSocial API Support and Gadget Rendering
     ROME, RSS and atOM utilitiEs for Java         : rome.rome-1.0
          Version                                       : 1.0
          Status                                        : enabled
          Vendor                                        : Sun Microsystems
          Description                                   : All Roads Lead to ROME. ROME is a set of Atom/RSS Java utilities that make it		easy to work in Java with most syndication formats. Today it accepts all flavors of RSS		(0.90, 0.91, 0.92, 0.93, 0.94, 1.0 and 2.0), Atom 0.3 and Atom 1.0 feeds. Rome includes		a set of parsers and generators for the various flavors of feeds, as well as converters		to convert from one format to another. The parsers can give you back Java objects that		are either specific for the format you want to work with, or a generic normalized		SyndFeed object that lets you work on with the data without bothering about the		underlying format.
     ROME: RSS/Atom syndication and publishing tools : com.springsource.com.sun.syndication-0.9.0
          Version                                       : 0.9.0
          Status                                        : enabled
          Description                                   :
     RPC JIRA Plugin                               : com.atlassian.jira.ext.rpc
          Version                                       : 5.1.3
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : The standard JIRA RPC services, both SOAP and XML-RPC.
     Streams API                                   : com.atlassian.streams.streams-api-5.2.0
          Version                                       : 5.2.0
          Status                                        : enabled
          Vendor                                        : Atlassian
     Streams Core Plugin                           : com.atlassian.streams.core
          Version                                       : 5.2.0
          Status                                        : enabled
          Description                                   : Streams Core Plugin
     Streams Inline Actions Plugin                 : com.atlassian.streams.actions
          Version                                       : 5.2.0
          Status                                        : disabled
          Description                                   : Streams Inline Actions Plugin
     Streams Plugin                                : com.atlassian.streams
          Version                                       : 5.2.0
          Status                                        : disabled
          Description                                   : Streams Plugin
     Streams SPI                                   : com.atlassian.streams.streams-spi-5.2.0
          Version                                       : 5.2.0
          Status                                        : enabled
          Vendor                                        : Atlassian
     Streams Third Party Provider Plugin           : com.atlassian.streams.streams-thirdparty-plugin
          Version                                       : 5.2.0
          Status                                        : disabled
          Vendor                                        : Atlassian
     Support Tools Plugin                          : com.atlassian.support.stp
          Version                                       : 3.0.11
          Status                                        : enabled
          Vendor                                        : Atlassian Support
          Description                                   : This is the Support Tools Plugin, developed to help Atlassian customers with our products.
     User Format                                   : jira.user.format
          Version                                       : 1.0
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This plugin renders a user in JIRA.
     User Profile Panels                           : jira.user.profile.panels
          Version                                       : 1.0
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : This library includes the panels included on the user profile page.
     Workflow Designer Plugin                      : com.atlassian.jira.plugins.jira-workflow-designer
          Version                                       : 3.0.0-m14
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : The visual way to edit JIRA Workflows.
     jira-help-tips                                : com.atlassian.plugins.helptips.jira-help-tips
          Version                                       : 0.29
          Status                                        : enabled
          Vendor                                        : Atlassian
          Description                                   : Common way to display help tips in the UI of JIRA.
___ Listeners _____________________________
     Instance Count                                : 3
     Mail Listener                                 : com.atlassian.jira.event.listeners.mail.MailListener
     Issue Assignment Listener                     : com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener
     Issue Index Listener                          : com.atlassian.jira.event.listeners.search.IssueIndexListener
___ Services ______________________________
     Instance Count                                : 5
     Backup Service                                : com.atlassian.jira.service.services.export.ExportService
          Service Delay                                 : 43200000ms
          USE_DEFAULT_DIRECTORY                         : true
     Mail Queue Service                            : com.atlassian.jira.service.services.mail.MailQueueService
          Service Delay                                 : 60000ms
     Service Provider Session Remover              : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
          Service Delay                                 : 28799997ms
     com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
     com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
          Service Delay                                 : 300000ms
___ Trusted Applications __________________
     Instance Count                                : 0
___ Java Class Paths ______________________
     sun.boot.class.path                           : C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\resources.jar;
                                                     C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\rt.jar;
                                                     C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\sunrsasign.jar;
                                                     C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\jsse.jar;
                                                     C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\jce.jar;
                                                     C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\charsets.jar;
                                                     C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\modules\jdk.boot.jar;
                                                     C:\PROGRA~1\ATLASS~1\JIRA\jre\classes
     java.library.path                             : C:\Program Files\Atlassian\JIRA\bin;
                                                     C:\Windows\Sun\Java\bin;
                                                     C:\Windows\system32;
                                                     C:\Windows;
                                                     C:\Windows;
                                                     C:\Windows\System32\Wbem;
                                                     C:\Windows\System32\WindowsPowerShell\v1.0\;
     java.endorsed.dirs                            : C:\Program Files\Atlassian\JIRA\endorsed
     java.ext.dirs                                 : C:\PROGRA~1\ATLASS~1\JIRA\jre\lib\ext;
                                                     C:\Windows\Sun\Java\lib\ext
     java.class.path                               : C:\Program Files\Atlassian\JIRA\bin\bootstrap.jar;
                                                     C:\Program Files\Atlassian\JIRA\bin\tomcat-juli.jar;
2013-04-10 14:28:13,410 localhost-startStop-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
JIRA 5.2.10 build: 853 started. You can now access JIRA through your web browser.
2013-04-10 14:28:13,661 localhost-startStop-1 WARN      [atlassian.jira.startup.JiraStartupLogger]
WARNING: The system property 'mail.mime.decodeparameters' is not set to true. This may result in e-mail attachments with non-Latin filenames being dropped. For more information please see https://docs.atlassian.com/jira/docs-052/__setting_mail.mime.decodeparameters.
2013-04-10 14:28:13,692 localhost-startStop-1 FATAL      [atlassian.jira.startup.JiraStartupLogger]
The following plugins are required by JIRA, but have not been started: Embedded Gadgets Plugin (com.atlassian.gadgets.embedded), Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard), Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin (com.atlassian.jira.lookandfeel), Opensocial Plugin (com.atlassian.gadgets.opensocial), Gadget Directory Plugin (com.atlassian.gadgets.directory), Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
2013-04-10 14:28:13,692 localhost-startStop-1 FATAL      [atlassian.jira.upgrade.UpgradeLauncher] Skipping, JIRA is locked.
2013-04-10 14:28:13,755 localhost-startStop-1 INFO      [atlassian.jira.startup.NotificationInstanceKiller] Not deleting NotificationInstance table yet, will delete on first startup after Wed May 08 11:37:44 BST 2013
2013-04-10 14:28:13,755 localhost-startStop-1 INFO      [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler not started: JIRA startup checklist failed.
2013-04-10 14:28:14,179 localhost-startStop-1 ERROR      [jira.web.dispatcher.JiraWebworkActionDispatcher]
JIRA startup failed, JIRA has been locked.
2013-04-10 14:28:29,339 Modification Check:thread-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
___ Modifications ___________________________
     Modified Files                                : jira-application.properties
     Removed Files                                 : None
8 votes
Gorka Puente _Appfire_
Yes, the JVM is supported. I was able to troubleshoot the issue and here are my findings.
The option JVM_SUPPORT_RECOMMENDED_ARGS="-Datlassian.plugins.enable.wait=300"
is simply to tell the application, i.e. JIRA, how much time to wait for loading the plugins, but each plugin seems to have an internal non cofigurable timeout of 60 sec. This means that even though I'd put a crazy high plugins.enable.wait time, let's say 2hrs, the start-up will keep failing due to the time out of each of the plugins.
For us the issue was that we were trying to install JIRA into a m1.small instance in AWS. As you guys probably know, this type of instances do not have i) access to much bandwidth inside AWS and ii) CPU and RAM resources. I did some profiling and noticed that the bottleneck was the I/O wait for the EBS volume that at the end of the day keeps being a remote hard disk for the VM.
Anyways, the fix was simple, just move to a m1.medium instance and everything worked like a charm. So, I would recommend not installing JIRA neither on m1.micro or m1.small, they are simply too small for JIRA.
Exactly the same thing is currently happening to me. My set up is JIRA 6.1.2 on an EC2 instance m1.small with Xmx1024m and Xms1024 and XX:MaxPermSize:512m
I also increased the timeout in setenv.sh using
but what this sets is the total time the start-up application waits for the plugins to be enabled not the internal timeout from each of the plugins with keeps being 60sec
I also tried several times deleting the directories .bundled-plugins and .osgi-plugins without success
I'm totally stuck at this point, any hints on this?
Iker
Matheus Fernandes
April 9, 2013
Scott, check out the following guides, that have a bit more info on this error and the possible culprits:
I hope this helps! :)
Scott Thomson April 9, 2013
I'd followed all but one of these tips, which was to increase the JVM memory, but unfortunately that hasn't changed anything!
Matheus Fernandes
April 9, 2013
Could you try to increase the memory then (try setting it to Xmx1024 Xms512)? Also, how was the disk speed test?
Larry Daniele June 23, 2013
Mike Aldin
January 22, 2018
what is the best solution for this issue?
L FORGET June 4, 2014
Had the same issue on a on premise VM which had only 512Mb of RAM (Linux Debian Wheezy).
Upgraded it to 1024Mb and it rolls...
Chris Baigorri February 24, 2014
@GorkaI am having the same problem as you did you manage to get it working?
In my instance addind -Datlassian.plugins.enable.wait=300 to JVM_EXTRA_ARGS in /opt/atlassian/jira/bin/setenv.sh fixed it.
It is important a supported JVM. By the way, we move our JIRA instance to a AWS m1.medium instance and everything worked. Do you still have the problem?
Alejandro Conde Carrillo
November 4, 2013
I got the same error when trying to start JIRA using an unsupported JVM. Check if the JVM you are using is supported by your version of JIRA.
Tansu Kahyaoglu
Do you have anti-virus application running? Try to disable it and restart JIRA
Nope, it's a completely fresh Windows 7 VM I've launched purely for running JIRA on so we can access over VPN. Stumped!
