JIRA/Stash build report for Jenkins
joshdanhall August 19, 2014
Is there any way to get a report of all JIRA items included in a particular Jenkins build?
Currently I have integration set up between JIRA and Stash and I am triggering Jenkins builds based on pushes to Stash. From the build in Jenkins under 'Changes' I have the commit logs, which is kind of what I want, only better would be links back to the JIRA items themselves and/or a report containing same.
Larry Shatzer
August 19, 2014
Have you looked a the JIRA Plugin for Jenkins? It will hyperlink it to JIRA. There are other features you can look at on that page for the plugin, like release notes.
joshdanhall August 20, 2014
OK. Will look into that. Thanks!
