I created a column that gives me the number of days of effort left on a task based on the remaining estimate field. this is working great. i am summing over subitems so that i can tell for the parent groupings i creating how may days of effort are left for the overall period.
the problem i am running into is that if the remaining estimate is filled out on a subtask, it also disaplys on the parent, which is then summed and doubling the data
example:
one task A with a subtask of B
subtask of B has 24hs (3days)
this shows on the parent task as well (just how jira works) so task A has 24hrs as well (3days)
this means that in structure, task A shows 6 days when really there is only 3 days of work left.
how do i fix this? I want to see that April-May 2023 only has 3 days of effort left.
i think i may have found a change that works by adding to my IF statement "if issuetype != subtask" - still investigating and open to any other suggestions
up
