With JIRA Studio being restrictive (imports, customization, etc) is my company better off just using the individual applictions?
And if we do use the individuals, is there a way to link them all together to create a "virtual Studio", minus teh Google Apps integration?
Even if you decide to use Individual Application, you can integrate them. For example - http://confluence.atlassian.com/display/JIRA/Integrating+JIRA+with+FishEye
You can even use Crowd to integrate with LDAP.
There are a few things to keep in mind though before selecting the on Premise version -
These were the factors that we considered when we decided to go for Studio. Moreover, you always have the option to move from Studio to onPremise anytime.
Be careful as you will *not* get the nice studio integrated look and feel, or navigation bar. Each tool will look slightly different and users must manaully jump between tools.
