JIRA Suite Utilities
Lathrop [PSU]
I'm trying you use Copy value from another field and I have selected the correct fields, I have the post function set, I'm copying from a text field (255) to another text field (255), I've made sure both fields are showing the screens, I even tried making the two fields a transition screen. For some reason I still can not get the value to copy from one field to another. The value in question is an email address. Can someone give me a clue on why this isn't working?
Using v 1.3.5
Bhushan Nagaraj
July 24, 2013
Have you checked the logs? Do you see anything?
Lathrop [PSU]
I got a copy of the logs this morning. It is the common two custom fields with the same name error. I should have seen that before. Thanks for the assist!
Bhushan Nagaraj
July 25, 2013
Hi Lathrop,
Converted comment to and answer. Glad it helped :)
Thank you
Bhushan
