I'm trying you use Copy value from another field and I have selected the correct fields, I have the post function set, I'm copying from a text field (255) to another text field (255), I've made sure both fields are showing the screens, I even tried making the two fields a transition screen. For some reason I still can not get the value to copy from one field to another. The value in question is an email address. Can someone give me a clue on why this isn't working?
Using v 1.3.5
Have you checked the logs? Do you see anything?
Hi Lathrop,
Converted comment to and answer. Glad it helped :)
Thank you
Bhushan
