JIRA Suite Utilities
Alok kumar Singh
JIRA Suite Utilities donot validates for the Attachements.
Jobin Kuruvilla [Adaptavist]
May 8, 2012
Better raise a feature request in the plugin page.
Nic Brough -Adaptavist-
May 8, 2012
Could you explain the question? I don't understand what you're saying. Which function in the utilities are you trying to use, and what's wrong with it?
May 8, 2012
Ok. Well, Jobin has already answered that, I think.
Alok kumar Singh
Well with the use of JIRA Suite Utilities you can't add validator for Attachment screen with Field validation.
Christian Czaia [Decadis AG]
May 8, 2012
He has and I wouldn't qualify this as a question at all. A question usually ends with a question mark which I can't see here. By the way Alok, a "Thank you for any help" doesn't hurt.
Alok kumar Singh
Well I have found a way to do this
1) Install the toolkit plugin>> add a custom field "Number of Attachments"
2) Create a validation in the workflow >> No of Attachments >0
@Christian Czaia:- Pardon me for this, If I ask any question here that itself with a sense of gratitude whether it is answered or not. So I think I explained the reason of your hurt. By the way "Thank everyone for your help"
