×Hi folks,
in an specific workflow we got the dual control principle and for that
assignees schould not do a specific transition. Only other users that are not assigned to the Issue should be able to do. I found the "is assignee condition" in the JIRA Workflow configuration, but not the "is not condition" is there a workaround?
Thanks a lot and cheers,
Robert
I used an user picker field "previous assignee" (not in edit screen available) where I copied the current user into it during the transition A. Then I added a condtion in transition B that current user must not be "prevoius assignee". That's how I implemented the dual control principle.
Hey Udo,
thanks for this idea. I will test it.
Cheers Robert
