×We have upgraded jira from v8.5.3 to v8.13.7 and after upgrade i am facing problem in postfunction/validator of workflow
workflow -during create transition postfuntion is using few Scripts which are stored in server and now with latest version they are not supporting due to some deprecated libraries .
Hi @Amit Anand
did you make sure to upgrade the Apps also? In this case the first example looks looks like coming from "Jira Automation Suite".
Here you could check if you have the latest version of it installed:
https://marketplace.atlassian.com/apps/5048/jsu-automation-suite-for-jira-workflows?hosting=server&tab=versions
Daniel
Type: class
Class: com.fca.jira.plugins.workflowToolbox.InitializedValidator
Arguments:
