We have deployed JIRA and Confluence on a single server behind Apache. Using Reverse Proxy both systems respond on the following URLs without context path:
We would like to interlink them using Application Links (AppLink), but we have been adviced to add context path to both application to assure seamless way of working e.g.
We prefer not to use context path as the URLs are more clear and not containing any redundances.
Does somebody have any experice with JIRA and Confluence behind Apache on the same server, communicating with Application Links without context path?
Can we set up both systems in that way, that Application Links works even without Context Path?
Thanks!
Hi Mihail,
The main problem of not using context path (in general) is the SESSION_COOKIE_NAME being overwritten that can cause session timeout when you have the two applications on the same domain:
https://confluence.atlassian.com/display/JIRAKB/User+is+Constantly+Logged+out+of+JIRA
For application link, is not mandatory to have the context path set, although you can have it as the example below:
* Externally accessible (Apache) URL: http://confluence.example.com/
* Application server URL: http://app-server.internal.example.com:8090/confluence/
As you can see here: Complex configuration: https://confluence.atlassian.com/display/DOC/Using+Apache+with+mod_proxy
So the ambiguity for the URL will always exist anyway, since you can access locally and externally (through the proxy).
However in this case, your local access will also have the context path, while the external access will not.
Thanks! This is exactly what I was looking for.
