JIRA and MySql 5.7 with SSL
Ion McCusker
December 14, 2019
I'm trying to setup a JIRA instance on gcloud which connects to a BYOD MySql 5.7 server.
I've created the keystore and truststore and validated connectivity with a simple Java main but when I try set the JAVA_OPTS with the corresponding -Djavax.net.ssl.keyStore= and -Djavax.net.ssl.trustStore= values, I get the following warning:
WARN: Establishing SSL connection without server's identity verification is not recommended. According to MySQL 5.5.45+, 5.6.26+ and 5.7.6+ requirements SSL connection must be established by default if explicit option isn't set. For compliance with existing applications not using SSL the verifyServerCertificate property is set to 'false'. You need either to explicitly disable SSL by setting useSSL=false, or set useSSL=true and provide truststore for server certificate
Varma Gadiraju October 30, 2020
Ion - You need to add "useSSL=false&" this parameters in the dbconfig file.
Example: <url>jdbc:mysql://localhost:3003/jiradatabase?useUnicode=true&amp;"---ADD HERE---"characterEncoding=UTF8&amp;sessionVariables=default_storage_engine=InnoDB</url>
Earl McCutcheon
December 16, 2019
Hello @Ion McCusker ,
Thank for reaching out and as covered in the error message you are going to want to add "useSSL=false" value.  The location to place this is going to be in your dbconfig.xml file via adding the following to the end of the db URL:
&amp;useSSL=false
 and this is discussed a bit further in the following Thread:
Earl
