JIRA and Stash - Memory or CPU Cores
Aleksander Lyse
August 12, 2014
Im planning to run JIRA and Stash on the same server for a small business, but wondering what would gain the products the most by the two alternatives.
Say CPU is the same, disk is SSD.
Alt 1: 1024MB ram, 4 core
Alt 2: 2014MB ram, 2 core
or
Alt 3: (1024MB ram, 2 cores) X 2 (one server pr installation).
Its just supposed to run a few users so not really that extreme but dont want a slow product.
Tiago Comasseto
August 12, 2014
Hi Aleksander, I believe that it's very difficult to precise which one is best for you as it'll depend on a number of variables other than number of users. In any case, we have the following sizing guide for JIRA that you may be insterested in taking a look and it may help to define your hardware requirements.
I hope it helps.
Cheers
