We use a JIRA structure of Initiative > Epic > User Story. We have added a custom field 'Customer Name' at both the Initiative and Epic levels.
We need JIRA automation for the following scenarios:
Hello @Arvind ,
Automation for Jira will do the Job here.
Considering, your trigger pint to be When Ticket is created and "Customer Name" is a user field.
Based on above 2 Consideration please find below Automation Rule, which will do the Job.
NOTE:
In Automation Rule, under user condition, Approvers is to be replaced by "Customer Name" field and the specific role you are checking against.
My Portfolio epic is your Initiative
These are based on my Consideration and Assumptions, these rules can be modified as per your requirement by changing trigger points or adding more conditions
Hi @Arvind ,
Have you tested or created automation that isn't working or having issues with? It would be good to let us know about that so we can help you to tweak it.
Question here is: What's the trigger? Where the custom name is which will check and trigger the actions?
