JIRA connectivity with SQL 2008 R2
Simon Genet March 14, 2013
We are trying to migrate from to an SQL2008R2 database.
I have created the DB, User and Schema however the config utility fails with 'unable to connect'.
The driver is in place and I have followed all the other steps multiple times without success...
Also tested windows odbc connection to BD from app server and it worked....
Please help ;-)
Theinvisibleman
March 14, 2013
Hi Simon,
Have you checked out the documentation for this process here? Please check it out, especially the parts about TCP/IP as well as the ports.
Joe
Simon Genet March 17, 2013
Hi Joe,
That is the documentation I was using. Our SQL box is fairly vanilla and ports are default.
Nic Brough -Adaptavist-
March 14, 2013
What does the application logs say? They'll have more detail about the specific error.
Do you have another tool that tries to connect using a jdbc connection? What connection strings are you using?
Hi Nic,
Not really sure what to look for in the logs. Tried searching for both SQL & JTDS but neither were mentioned.
At present we are not using any other jdbc connections... ODBC is connecting correctly however.
March 17, 2013
You really do need to read the logs - they will have connection errors in them.
ODBC is not JDBC - you may well have the right settings for ODBC, but that doesn't matter - you need to get the right settings for JDBC and test with those.
